Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Need a code for ABS Passat 3C 1.6FSI BLF
  1. #21
    Verified VCDS-User
    Aug 2018
    Romania
    So are you going to dissect the old one and see if you can fire up on bench to grab coding?
    I will try with the original part number and then coding using the codes from you .
    If not I will try to read the eeprom in order to extract the old coding from the abs pump.
  2. #22
    HQ
    You should have something like this:
    Jack's coding suggestion looks to be the correct one... so 0013698 once you have the correct ABS part number installed.
    Jef
  3. #23
    Verified VCDS-User
    Aug 2018
    Romania
    I ve replaced the ABS module with another one with the same part number, coded with 0013698 and it works from first try.
    Thanks everyone!
  4. Likes Uwe, Jack@European_Parts, Jef liked this post
  5. #24
    Thanks everyone!
    https://forums.ross-tech.com/showthr...l=1#post184428
    Yupp.............FOD WINS AGAIN!
