Need a code for ABS Passat 3C 1.6FSI BLF
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
Hello there,
I replace the ABS pump on a Passat B6 and i need a code for ABS.
I attached here the scan from the car.
I try several codes but without any results
Monday,02,December,2019,19:48:10:32554
Workshop Code: 022 21992 002029
VIN: WVWZZZ3CZ6E084427   License Plate:
Mileage: 227200km-141175mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 65 69 77
VIN: WVWZZZ3CZ6E084427   Mileage: 227200km-141175miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 EE    HW: Hardware No
   Component: MED9.5.10       G00 5856
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 46345 142 86456
   VCID: 6A98374E4500C31F19-803E
               P1653 - 004 -
                    Fault Frequency: 9
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:00:07
                    Load: 0.0 %
                    Temperature: 39.0°C
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low
                    Fault Status: 01100010
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:00:08
                    Load: 0.0 %
                    Temperature: 39.0°C
               P1653 - 001 -
                    Fault Status: 01100001
                    Fault Frequency: 9
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:02:22
                    Load: 0.0 %
                    Temperature: 39.0°C
Readiness: 1110 0101
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000775987731
   Coding: 0001282
   Shop #: WSC 21992 022 02029
   VCID: 1E702B9EC9C8FFBFB5-804A
8 Faults Found:
                    Fault Priority: 9
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:47
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00000000
                    Count: 228
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 199
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 149
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:07:35
   Part No: 1K0 820 047 DG
   Component: Climatic PQ35   090 0505
   VCID: 6C9431564FF4DD2F6B-8038
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000002103908
   Coding: E18C8F0700041A00000A00000F00000000095D435C0000
   Shop #: WSC 05311 000 00000
   VCID: 302CE526A35C79CF17-8064
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:00:00
                    Voltage: 11.95 V
   Part No SW: 3C0 909 605 G    HW: 3C0 909 605 G
   Component: 01 AIRBAG VW8R  029 2421
   Revision: 09029000    Serial number: 0039VSG4AG1W
   Coding: 0012337
   VCID: 2A18F74E8580031FD9-807E
   Subsystem 1 - Serial number: 6332MSME0B75200C8
   Subsystem 2 - Serial number: 6342MSME0A747679M
   Subsystem 3 - Serial number: 6351HTS65CHMT463L
   Subsystem 4 - Serial number: 6361HTS614FELO339
   Subsystem 5 - Serial number: 6371VTS68SDA4LG2+
01219 - Rear Side Airbag Igniter; Driver Side (N201)
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C9953507C
   Coding: 0000014
   Part No SW: 3C0 920 870 F    HW: 3C0 920 870 F
   Component: KOMBIINSTRUMENT VD1 4038
   Revision: V0032000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 11111 111 11111
   VCID: 2600037E9198277FFD-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C058230397
   Coding: 3D3D8E04C62002
   VCID: 210A1062F8B6C04788-8074
   Part No SW: 3C0 959 433 B    HW: 3C0 959 433 B
   Component:    IMMO         043 0364
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 291A084280860807D0-807C
   Subsystem 1 - Part No: 3C0 905 861 C
   Component:    ELV          023 0350
   3C0905861C     ELV          023 0350
02827 - Wake-Up request via ESP
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:00:33
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 233
                    Mileage: 227201 km
                    Date: 2019.09.19
                    Time: 07:00:33
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0000181
   VCID: 3620D33E413857FF4D-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3228EF2EAD504BDF61-8066
   Component:    KSG PQ46 RDK 043 0212
   Coding: 0091020851030E763804941570084B0E701C00
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 373EDE3A4632AEF756-8062
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
            002 - Lower Limit Exceeded
   Revision:   013
   Coding: 0010000
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 233
                    Mileage: 227200 km
                    Date: 2019.09.19
                    Time: 07:02:20
                    Voltage: 11.90 V
                    Count: 171
02443 - Control Head
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 233
                    Mileage: 227200 km
                    Date: 2019.09.19
                    Time: 07:03:53
                    Voltage: 11.90 V
                    Count: 46
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 233
                    Mileage: 227200 km
                    Date: 2019.09.19
                    Time: 07:02:20
                    Voltage: 11.90 V
                    Count: 236
            000 - - - MIL ON
                    Reset counter: 233
                    Mileage: 227200 km
                    Date: 2019.09.19
                    Time: 07:02:20
                    Voltage: 11.90 V
                    Count: 170
   Part No: 1K0 035 186 P
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2E1983029
   Coding: 0022200
   Shop #: WSC 05311 000 08193
   VCID: 3326EA2A524A42D76A-8066
   Component:    RDK              0391
   Coding: 0161211
Address 69: Trailer        Labels: 1K0-907-383-V1.clb
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 001 0020
   Coding: 0000001
   Shop #: WSC 05314 000 00000
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
   Component: Telefon             6919
   Revision: 00008000    Serial number: 0000000647376
   Coding: 0016023
   VCID: 25020472EC9E2C67F4-8070
End----------(Elapsed Time: 01:09, VBatt start/end: 12.0V/12.0V)-----------
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics#Coding
Vehicle Identification No.WVWZZZ3CZ6E084427
Modelpassat squareback
PA
Date of production08.09.2005
Model year2006
Sales type3C50E2
Engine CodeBLF
Transmission CodeHPB
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0HGVehicle class differentiation -3C0-
Emission standard0GGEmission standard EU4
Trailer hitch1D2Trailer hitch, removable and lockable
airbag4UEdriver and front passanger airbags
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Tray areas packageQE0Without tray areas package/box
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SLLeft exterior mirror, aspherical
Right exterior mirror5RQRight exterior mirror: convex
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8Bbasic outfit
Brake type in rear1KUDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Brake type, front1LJDisc brakes in front
Beverage holders4M5Beverage holders
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VCInformation kit in German
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
General operating permit, alterationsC04Operating permit, alteration
Roof rails/roof load rack3S2Black roof rails
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG02Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0EMInstallation differentiation for transmission MQ 200 -- vehicle components --
Theft protection system7ARElectronic immobilizer, with anti-theft alarm system and backup horn
Inserts5MADecorative inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X0Without park distance control
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R5Power windows with comfort operation and circuit breaker, mechanical window regulators rear
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL1extended pedestrian protection measures
Headlight activation8K8Low beam assistant with "Coming Home" function
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G4Cable gearshift
Weight category rear axle0YEWeight range 5 installation control only, no requirement forecast
Weight category front axleL23Suspension range 23 installation control only, no requirement forecast
Base engineT724-cyl. petrol engine 1.6 l assembly 03C.E (ALU)
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Exterior noise suppression measures2B0without additional exterior noise insulation
Garage door openerVC0without Garage door opener
Transmission specificationsG0K6-speed manual transmission
Cruise control system and speed limiter6Y9without cruise control system
Brackets3P1Bracket for first aid kit and warning triangle
Rear seats3NERear seat bench/backrest, split folding with center armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8BGTwin-headlamps for driving on the right, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5AInstrument insert, km/h speedometer
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8DWagon/Avant
Luggage compartment floor covering6SMReversible floor covering, Nadelvlies (Dilours)
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C0Without special body measures
Radiator grille6KARadiator grille
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K1Transit coating (wax)
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Load edge protection2P1Plastic loading edge protection
Lumbar support7P0Without lumbar support in seat backrests
steering wheels1MASteering wheel
Speaker installation8RE4 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E0Without center armrest in front
Multi-function display/trip computer9Q5Multi-function display with control
center console3D1center console
Engine cooling8Z5not hot country
Engine specificationsD4K4-cylinder SI engine 1.6 l/85 kW (16V) FSI, homogeneous base engine is T72
Left vanity mirror4SGLeft vanity mirror illuminated, extractable sun visor
Right vanity mirror4TLVanity mirror, right, illuminated extractable sun visor
Navigation device7Q0without navigation system
rear fog lamp8TCRear fog light for driving on the right
Front fog lamp/additional headlamp8WDIntegrated front fog light
Hubcaps1NHFull wheel covers
WheelsC1GSteel wheels 6.5J x 16
Radios8YLRadio with CD player
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K3Tire pressure monitoring system 433 MHz High
umbrellaNS0Without umbrella(s)
tireHD8Tires 205/55 R16 91H
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G8Breakdown kit
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
P30tire pressure control system
PAKTowing attachment, removable
RAB"RCD 300" 2 x 20 W, 4 loudspeakers
WBL"Business" package
Side airbag4X4Side airbag in front and rear with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates2KWLabels in German, French and Dutch
Tail lamp assemblies8SKTaillight assemblies with diodes (LED)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TBStandard seat in front, left
Front seat, right3SBStandard seat in front, right
Seat belt check9P1Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN4CSeat trim covers in fabric
Seat adjustment3L1Manual height adjustment for left front seat
seat heater4A3seat heating for front seats separat controlable
Side lights8F2side-mounted turn signals
Control number (no PR family)S3SControl (in-plant)
Control number (no PR family)SF4Control PR code for vehicle tracking
Control number (no PR family)SX8Model update, week 22
Control number (no PR family)SZ9Delivery "Autostadt Wolfsburg"
Audio-response system/voice controlQH0without voice control
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B1Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
power outlet7B0without socket
Bumper2JBStandard bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Nameplate set0PKNameplate set "FSI"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB01Type approval country Germany
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Transit coatingNT0Transit coating (type 1)
Door and side trim panels3LCDoor and side trim panel in foam film and woven fabric
TV reception/digital radio receptionQV0without TV/digital radio reception
Assembly parts for engine (drive bearing)1VGAssembly part for 4-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
First aid kit / warning triangle1T2warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W8Preparation for telephone
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2XAAdditional winter tyres
floor mats0TDFront and rear floor mats
Decorative trims4ZEBlack decorative trims
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
PA
Model year2006
Sales type3C50E2
Engine CodeBLF
and the code will be?
[h=2]
I don't have access to this software.
Can't you calculate it for me?
Coding[/h]Coding for this Control Module is normally done via Software Version Management (SVM). If the old Control Module is still accessible read/copy it's Coding to the new Module. In case this is not possible please contact us directly and we will assist you with the Coding Process.
Every inquiry on this topic has to include a full Auto-Scan as well as which parts have been replaced and why, also make sure the Auto-Scan includes the complete VIN of the vehicle in question.
https://forums.ross-tech.com/showth...abs-vw-passat-3C&p=88343&viewfull=1#post88343
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
Go search the web it's not that hard and next time archive your scans or go get SVM..........
Look for scans with BLF type or 1.6 hardware.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
The ABS unit it's broked and that's way i dont have the coding.
Thanks!
Have you tried opening up the old ABS unit and attaching alligator clips and bench communication to extract the old coding?
Jef
HQ
Vehicle Identification No. WVWZZZ3CZ6E084427
Model passat squareback
PA
Date of production 08.09.2005
Model year 2006
Are you sure you have the correct ABS part number. A 2006 Passat I'd expect to have a "C2" ABS, not a "C4". The soft coding value Jack provided is for the C2 variant.
Zoinks!
oh no FOD again?
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
You are right.
The original part number was 3C0614095Q.
I ll try to find one ABS pump like this tomorrow and try to adapt it again on the car.
Thanks all for your involvement!
You are right.
So are you going to dissect the old one and see if you can fire up on bench to grab coding?
Jef
HQ
VCDS has really good documentation built into it for coding these types of ABS modules. Just match up your PR codes, check the boxes as needed and then select the proper engine/trans package from a drop down menu... and with that, coding is generated.
Badea_Cristian
Verified VCDS-User
Romania
C?ID=334174
It doesn’s show me any information regarding coding .
