Hi guys, hoping you can help with a few suggestions. My car has a really annoying light assist function which is way too sensitive for my liking and wondering if there is a way to delay its operation as evening/daylight approaches. As the light begins to fall, a message appears on my Digital dashboard to switch on the dipped headlamps. While this message is displayed, and until you actually turn the headlights on, no other settings or displays are visible in the digital cockpit any longer. This is really frustrating as I drive quite a bit in very slow traffic at dusk/dawn and don’t want to have my dipped headlights on when I don’t need them, in particular in almost daylight conditions !!
I have looked in the 09 Central electrics module and channel map attached. Did a lot of converting German into English from there, and eventually found and played around a bit with the default lux settings I found (dumped below fyi) but it made no difference to the functionality of this dipped headlight warning at all regardless of trial changed values.
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 0 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity frueh
Assume its controlled by the slave HLRS coding in this channel, but could not find a deactivate option in there either.
Wondering if anyone has any knowledge of how I might be able to delay this warning till much later, (the vehicles head units “Late” option is also selected), but still the warning to switch my headlights comes on in almost full dayligh, or how to just deactivate the warning completely.
Tuesday,26,November,2019,21:05:49:15093
VIN: WVWZZZAUZHW345558 License Plate:
Mileage:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
VIN: WVWZZZAUZHW345558 Mileage: 33573km-20861miles
4B-Multifunc. Module -- Status: Malfunction 0010
Monday,02,December,2019,18:16:18:15093
Mileage: 33607km-20882mi Repair Order:
VIN: WVWZZZAUZHW345558 Mileage: 33607km-20882miles
Address 01: Engine (J623-DGCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 HA HW: 04L 907 309 R
Component: R4 2.0l TDI H24 4010
Revision: B5H24---
Coding: 01190012034405082000
ASAM Dataset: EV_ECM20TDI01104L906026HA 004003
ROD: EV_ECM20TDI01104L906026HA_004.rod
VCID: 70B9D08D6A20BCD7397-8024
5169 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [036] - Signal too High
Mileage: 33607 km
Date: 2019.12.02
Time: 16:47:19
Coolant temperature: 60 °C
Intake air temperature: 50 °C
Voltage terminal 30: 12.500 V
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 50637000001901
Coding: 01FA8AA134240971477C060540CB2980512C90E26002947534605078C009430000000012121212B835351919323200
VCID: 76B5E695084492E7E3B-8022
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012010420211001100500400010102A
VCID: 6D87C9F97D12513F121-8038
Air quality sensor:
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001706901834
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA5FEB52074DAA7BBB-802A
Component: WWS 170216 042 0551
Serial number: 170303212708
Component: RLHS 042 0105
Serial number: S4Y17M03D15H00M58S45
Coding: 00A8DD
Serial number: 000000000ZY170521MZF
Serial number: 00000000000068295429
204546 - Remote key 2
Reset counter: 110
Mileage: 33589 km
Date: 2019.12.02
Time: 11:47:17
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617076
Coding: 0471051001
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4ACD62652C3CA607573-801E
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Coding: 2B00608159FFC728949C810560400600000000000000000000
VCID: 3C2134BD76E808B7D5F-8068
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2RYHT9
Coding: 98CCC000000000005C0000CF008800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1079B00D0AE0DCD7597-8044
Belt Pretensioner left:
Serial number: 34169677E14031741182
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E15031751315
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 203 17
Serial number: 35700000000727283225
Subsystem 4 - Part No SW: ----------- HW: 480 001 303 17
Serial number: 3580000000077738D12L
Subsystem 5 - Part No SW: ----------- HW: 480 400 803 17
Serial number: 3510001C124A43A6272U
Subsystem 6 - Part No SW: ----------- HW: 480 401 403 17
Serial number: 3520001A72507FC327C7
Subsystem 7 - Part No SW: ----------- HW: 480 401 303 17
Component: FrontSensor_D 000 6149
Serial number: 3550001BF24CDB14E35N
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 13031708490654
Coding: 0400
VCID: 0D47A9791DD2F13FB21-8058
Part No SW: 5G1 920 791 HW: 5G1 920 791
Component: KOMBI 409 2180
Coding: 23AD21002F802E0001886F011400000000000000
VCID: 698FBDE949FA4D1F7E9-803C
13639427 - Databus
[Steuergerät für Motor: bitte Fehlerspeicher auslesen]
Reset counter: 151
Mileage: 33607 km
Date: 2019.12.02
Time: 16:47:19
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0006070503
Coding: 030100045F086800FB00027E080F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2F3B13F1B79EE32F60D-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170000474240067082
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6176703304
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
Reset counter: 151
Mileage: 33601 km
Date: 2019.12.02
Time: 15:02:00
Supply voltage: Terminal 30: 13.1 V
Terminal 15: On
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47CB5B513F2E5B6F48D-8012
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 210217EBK22908
Coding: 003F0220D001048000001000
VCID: 43D34F410B16774F945-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013778192
Coding: 0D0000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2D32A57CDC3687C73-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 10031710803312
Coding: 000000050100164E01100F01020000000000000000000000000000000000
VCID: 72BDDA85642C8EC7CF3-8026
Component: TSG BFS 020 0041
Serial number: 080317EC802954
Coding: 003F0020DE01048000801000
VCID: 42DD4A45140C7E479F3-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013708881
Coding: 150000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0757
Coding: 02731001FF00000051110101008808001F0502E601200000CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 313F1589A1AAF5DF769-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H41 8077
Serial number: VWZ6ZET0770380
Subsystem 2 - Part No SW: 5NA 919 866 H HW: -----------
Component: ECE1 2019/20 --- 1115
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 170217200138
VCID: 6B83C7E143065F0F0C5-803E
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2DA979DA3D9FCE9-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
