Good morning everyone,
I am new to the forum & VCDS family and I am excited to both help with others problems and hopefully get some guidance on some of mine.
My car is a 2004 VW Touareg V6 3.2L gasoline that I bought used recently knowing that it had bad fuel pumps. It had the typical start for 30 seconds and die.
I replaced both fuel pumps and the fuel filter housing and everything ran perfectly on the car.
However, recently as my wife was driving our son to preschool the car mysteriously died while she was driving and would not restart. Cranks but no start.
I had the car towed home and charged the battery over night.
Went out the Touareg the next morning and started fine after a few cranks. I drove it no a short trip and it died a few blocks away and again would crank but not restart.
After towing it home and doing some investigation I noticed that the under hood fuse/relay panal had a pool of water because the cover was not secured properly.
I vacuumed out the water & dried it out over several days and closed the lid.
Now the car still will crank but not start and it will only crank if I let it sit in the key on / car off position until the EPC and Check engine light come on.
Also, the fuel pumps do not prime when I open the driver's door as they should. I can prime them manually so I know that they are still good.
Any idea of computer issues or relays that may cause this problem? I will post two scans that I took recently. The first is after the car died, but I had not cleared the codes and the second is after it died twice & I cleared the codes to get a fresh car scan as the car sits not.
THANK YOU ALL VERY MUCH IN ADVANCE AND HAVE A GREAT DAY!!!
FIRST SCAN:
SECOND SCAN AS THE CAR SITS NOW:
FIRST SCAN:
Saturday,16,November,2019,15:49:59:54382
Dealer/Shop Name: Dave and Joey's Bone-Yard
VIN: WVGBC77L34D064021 License Plate: 854KHL
Mileage: 252670km-157001mi Repair Order: 001
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBC77L34D064021 Mileage: 252670km-157001miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 9779
Coding: 0000133
Shop #: WSC 19226 444 59215
VCID: 50F97738A6FE7567197-5160
10 Faults Found:
17069 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground - Intermittent
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground - Intermittent
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground - Intermittent
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground - Intermittent
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground - Intermittent
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1049 - 002 - Short to Ground - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BD
Component: AL 600 6Q 0582
Coding: 0004153
Shop #: WSC 19419 444 53362
VCID: 71BFD2BC0DB45C6F369-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 3A2D35901042DF37C73-5160
65534 - Unknown Error Code
015 - Cannot Be Tested at this Time - MIL ON
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D070ECCD10C788F521-5160
Component: ELV XXXX
00166 - Access/Start Authorization Switch (E415)
00172 - Key 2 not learned
00087 - Terminal 30 for Starting Relevant Consumers
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 353726AC395C304F2A1-5160
00898 - Control Circuit A/C compressor
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0101599
Shop #: WSC 19400 444 85723
VCID: 44D14B68628699C7ADF-5160
02088 - Lights for Auxiliary High Beams
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00009760
Coding: 0012341
VCID: 2313E8F487C8BEFFF45-5160
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
01316 - ABS Control Module
Date: 2063.15.31
Time: 31:60:00
Date: 2063.15.31
Time: 31:60:00
00532 - Supply Voltage B+
Fault Frequency: 15
Reset counter: 39
Date: 2063.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 40D94778769E85E7897-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 RX
Component: KOMBIINSTRUMENT RB0 2035
Coding: 0007231
VCID: 1E65D900ACAA9317DBB-5160
00438 - Fuel Supply Sensor 2 (G169)
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D7B806BE5567397-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04518B68220659C7EDF-5160
00926 - Terminal 30
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F5B04844BE03A1FB0D-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
VCID: 6695B1E0347A8BD753B-5184
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABECA463D0025FF8D-5160
02327 - Position Sensor for Front Seat Height Adjustment (G438)
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
006 - Short to Plus
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
VCID: 678BBCE4337092DF68D-5160
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2K HSG 0201
Coding: 0000085
VCID: 3E2539800C6AF317FBB-4B1E
Subsystem 1 - Part No: 7L0 959 701 A
Subsystem 2 - Part No: 7L0 959 702 A
Subsystem 3 - Part No: 7L0 959 703
Subsystem 4 - Part No: 7L0 959 704
12 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180 B
Component: Radio DE2 0016
Coding: 0000401
VCID: 2C0103C8EA16718745F-5160
00879 - Connection to Speaker Front Right
00881 - Connection to Speaker Rear Right
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0211390
VCID: 75B7E6AC79DC704FEA1-5160
01312 - Powertrain Data Bus
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 372B2CA42350C25F38D-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
End----(Elapsed Time: 08:47, VBatt start/end: 12.9V/10.5V. VIgn 10.6V)-----
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,16,November,2019,16:37:26:54382
Mileage: 252670km-157001mi Repair Order: 002
------------------------------------------------------------------------------- Address 01: Engine Labels: 022-906-032-BMX.lbl
Coding: 0000133
------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.clb
Coding: 0004153
Self-Diagnosis Log
Page 2
Coding: 0014337
------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Coding: 0000232
Component: ELV XXXX
005 - No or Incorrect Basic Setting / Adaptation - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 3
Coding: 0000030
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Component: 2703
Coding: 0101599
008 - Implausible Signal - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 4
Coding: 0012341
Date: 2063.15.31
Time: 31:60:00
Date: 2063.15.31
Time: 31:60:00
Fault Frequency: 15
Reset counter: 39
Date: 2063.15.31
Time: 31:60:00
Self-Diagnosis Log
Page 5
Coding: 0000031
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Coding: 0007231
004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Coding: 0000006
004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 1C: Position Sensing Labels: 7L6-919-879.lbl
00926 - Terminal 30
002 - Lower Limit Exceeded - Intermittent -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 6
002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 29: Left Light Labels: 3D0-909-157.lbl
No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None
006 - Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 39: Right Light Labels: 3D0-909-158.lbl
Self-Diagnosis Log
Page 7
Coding: 0000085
12 Faults Found:
00926 - Terminal 30
008 - Implausible Signal -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 8
Coding: 0000401
00878 - Connection to Speaker Front Left
------------------------------------------------------------------------------- Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Coding: 0211390
------------------------------------------------------------------------------- Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Coding: 0000004
No fault code found. ------------------------------------------------------------------------------- Address 6E: Ctrl Head Roof Labels: None
End----(Elapsed Time: 08:39, VBatt start/end: 12.9
