Results 1 to 10 of 14
Thread: A6 C6 Electric seat wont go up
    Apr 2019
    The electric drivers front seat in my 2009 A6 3.0 TDI Lemans wont go up or down on the button. The front section under the knees will move but not the main up and down of the seat
    All other functions of the seat work ok.
    Are the motors fused separately ? or would it be likely to be the switch itself ?
    Would be grateful for any help
    Oct 2017
    Northwest UK
    Can you post a scan please. If the motor's gone it should point to an electrical failure
    Apr 2019
    I ran a scan last night and there were no fault codes.
    I will run another scan later and post the results
    You probably don't need to run another scan. Post the one from last night. Even if you didn't explicitly save it, VCDS did so anyway. Look in the Scans sub-folder.
    Apr 2019
    Here is my scan
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62
              72 76
    VIN: WAUZZZ4F09N045307   Mileage: 296830km-184441miles
    Address 01: Engine (CDY)       Labels: Redir Fail!
       Part No SW: 4F9 910 402 A    HW: 4F0 907 401 E
       Component: 3.0TDI EDC17G000AG  0080
       Revision: 16H01---    Serial number:
       Coding: 010D002C190F0128
       Shop #: WSC 26214 051 00000
       VCID: 2447D91CE74A8E6FDD-8070
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 000 - Restricted/Clogged
                        Mileage: 294857 km
                        Date: 2019.11.11
                        Time: 17:55:11
                        (no units): 4.5
                        (no units): 18.0
                        Mileage: 160 km
                        Time: 0.00 s
                        (no units): 3.0
       Part No SW: 4F2 910 156 Q    HW: 09L 927 156 C
       Component: AG6 09L 3,0 TDI RdW 0030
       Revision: --H04---    Serial number:        4510608
       Shop #: WSC 02325 785 00200
       VCID: 33652A4052A419D754-8066
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
       Component: ESP8 quattro    H03 0060
       Coding: 0020876
       VCID: 6ED3FB347906743F7B-803A
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601274903
       Coding: 0000147
       Shop #: WSC 02324 785 00200
       VCID: 2541C418EC707767CA-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
       Component: KLIMABETAETIGUNGH30 0070
       Revision: 00000073    Serial number: 00000000608027
       Coding: 0001302
       VCID: 1D31ECF8C420BFA792-8048
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Coding: 0013121
       Shop #: WSC 02335 785 00200
       VCID: 3467295C57AA1EEF4D-8060
       Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H47 0050
       Revision: 00000012
       VCID: 2149D00838589B47B6-8074
    Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003CH003NS55
       Coding: 30314236303630303033554A305234463053
       ROD: EV_Airba10AURB4.rod
       VCID: 306F254C6BB222CF29-8064
       Serial number: 3574SRB400008114F15
       Serial number: 3584SRB40000812CF2EF
       Serial number: 35152RB402V7IPVCTCV+
       Serial number: 35252RB40318CLJAR47%
       Serial number: 3554NRB4000047ED220
       Serial number: 3564NRB4000047E2C698
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90055090230548
       Coding: 0102142
       VCID: 275DCE10967C6577F8-8072
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 B    HW: 4F0 920 983 B
       Component: KOMBIINSTR.   H06 0135
       Revision: 00100000    Serial number: AE920AKD8
       Coding: 2357120502002600010400
       Shop #: WSC 02391 823 56573
       VCID: 2B5532204A9441171C-807E
       Part No SW: 4F0 907 468 K    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0025
       Revision: 4LA80024    Serial number: 2400L092088093
       Coding: 000303
       VCID: 377D1E5086DCF5F768-8062
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140443244
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000100723307
       Coding: 011F06204041410001
       VCID: 46836394F1369C7FE3-8012
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H27 0220
       Revision: 02200027    Serial number: 01171317770000
       Coding: 0140027
       VCID: 31692048A8B82BC726-8064
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000617163
       Coding: 0001103
       VCID: 5EB3ABF489A6E4BFCB-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000100763730
       VCID: 45816498CC309767EA-8010
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000321
       Shop #: WSC 02145 785 00200
       VCID: 2149D008F8589B47B6-8074
       Part No: 8P0 907 357 H
       Coding: 0000003
       VCID: 3F8D76706EECCDB7A0-806A
       Part No SW: 4F0 035 061 B    HW: 4F0 035 061
       Component: Radio U DAB   H45 0020
       Revision: AB001007    Serial number: 343BU097517680
       Coding: 010103020100000000
       VCID: 1B35E2E01A34B1976C-804E
       Part No SW: 4E0 035 666 B    HW: 4E0 035 666
       Component: H-BN-EU       H64 0047
       Revision: --------    Serial number: 345BY097547184
       Coding: 010101010302C3ED01000715EF6300030001
       Shop #: WSC 00441 210 91426
       VCID: 2541C4182C707767CA-8070
       Subsystem 1 - Part No: 8R0 060 884 C
       Component: EUROPE 2008  5608
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356BU091064784
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 M
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001262251
       Revision:             Serial number: 0000100761897
       Coding: 010E04204041220001
       VCID: 43857A80C204A957C4-8016
       Revision:             Serial number: 0000100760875
       Part No SW: 4L0 910 283     HW: 4L0 919 283
       Component: Parkhilfe 4-Kan H02 0400
       Revision: 00H02000    Serial number: 13730904203450
       Coding: 0201016
       VCID: 67DD8E1056FCA57738-8032
    Jul 2014
    Tallinn, Estonia
    Are the seats fully electric? From the factory, these have their own diagnostic addresses 06 and 36. Since these are completely missing in your autoscan, I'd presume these seats are retrofitted at some point?
    Should have only one fuse, which can mean the up-down motor itself can be faulty.
  7. Likes Uwe liked this post
    Oct 2017
    Northwest UK
    Mmm. When you press the button can you hear the motor spinning? If so then it's likely to be mechanical, if not then it's a case of removal and testing the wires for power.
    Sometimes removal and refit of plugs and cleaning contacts sorts the problem out.
  9. Likes Uwe liked this post
  10. #8
    Apr 2019
    Quote Originally Posted by siLc View Post
    I assumed they were but I don't know that for sure
  11. #9
    Apr 2019
    Quote Originally Posted by myounus View Post
    There's no noise at all when you press the button.
    I will try removing and refitting the wires
  12. #10
    Apr 2019
    After testing and cleaning connections I have come to the conclusion the motor is faulty
    Would anyone be able to help out with a part number for the motor ?
