Hi all. VCDS Noob here looking for a little guidance with troubleshooting.
CURRENT CONDITION
* The car will not crank and there are no dash lights.
* Power windows, DRL, and headlights do work.
* Battery is charged, 13Vdc, and appears to be ok.
HISTORY
* Car was operating normally.
* Car sat unused for months.
* Tried to start car but battery was too low to crank.
* Tried jump starting but engine only cranked slowly and did not start.
* Removed battery cables to charge battery.
* No backup power was used while cables were disconnected.
* Reconnected battery.
* While connecting + cable, wrench contacted ground and shorted out and sparked.
* Battery @ 13Vdc is now connected but engine will not crank.
TROUBLESHOOTING
* We are using the Audi service manual from Factory-Manuals.com and have tested all found fuses as good.
* Tested all found relay coils and they all "click."
* Ran Autoscan and attached output below.
It seems likely there is a power delivery problem or maybe the ECU has been damaged from the battery short?
Thanks for any advice in our next troubleshooting steps.
The Autoscan shows nothing but "Status: Malfunction" and "Cannot be reached".
CURRENT CONDITION
HISTORY
TROUBLESHOOTING
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUEFAFL3BN044315
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19---
Coding: 0104010A02070160
Shop #: WSC 07117 444 11185
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74B1DB401E331CA7DDF-8020
11 Faults Found:
7135 - Body Control Module (Central Electric)
U0140 00 [039] - No Communications
Time: 00:00:00
Coolant temperature: 12 °C
Intake air temperature: 15 °C
Voltage terminal 30: 12.957 V
7136 - No Communication with ABS Brake Control Module
U0121 00 [039] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
Time: 00:00:00
5558 - Body Control Module (Central Electric 2)
U0141 00 [039] - No Communications
Time: 00:00:00
Voltage terminal 30: 12.981 V
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [039] - -
Time: 00:00:00
Voltage terminal 30: 13.004 V
5615 - Door Control Module - Driver's Door
U0199 00 [039] - No Communications
Time: 00:00:00
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [039] - -
Time: 00:00:00
4713 - No Communication with ABS Brake Control Module
U0121 00 [167] - -
Time: 00:00:00
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
Time: 00:00:00
4715 - No Communication with Instrument Cluster
U0155 00 [039] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Time: 00:00:00
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Time: 00:00:00
4720 - Body Control Module (Central Electric 2)
Time: 00:00:00
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 K
Component: 0AW 20TAVSUSA H04 0004
Revision: --H04--- Serial number: 0000001268
Coding: 000001
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMVL381 A02018
ROD: EV_TCMVL381.rod
VCID: 3B23307C73ED93DFDC5-806E
6 Faults Found:
2223 - Load Signal
P1857 00 [047] - Error Message from ECU
Time: 00:00:00
Engine speed: 100.00 /min
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: -40 Nm
Transmission fluid temperature: 14 °C
Accelerator position: 0.0 %
Clutch status: 1
Occurrence_counter_over_length_of_life: 1
2265 - No Communication with ABS Brake Control Module
U0121 00 [167] - -
[Software Incompatibility with Anti-Lock No communication]
Time: 00:00:00
Clutch status: 1
2300 - No Communication with Instrument Cluster
U0155 00 [047] - -
[Control module for instrument panel insert No communication]
Fault Frequency: 19
Time: 00:00:00
Clutch status: 1
Occurrence_counter_over_length_of_life: 55
2309 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
[No communication with electrical brake system ECU]
Time: 00:00:00
Clutch status: 1
Occurrence_counter_over_length_of_life: 2
5676 - Steering Column Control Module
U0212 00 [047] - No Communications
[Lost Communication With Steering Column Control Module No communication]
Time: 00:00:00
Clutch status: 1
5677 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
[Steering angle sender -G85 No communication]
Time: 00:00:00
Clutch status: 1
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0N5UXF
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 45D756840529D52FBA1-8010
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100003QS4
Serial number: 6334MSME5C245957M
Serial number: 6344MSME5C245A65N
Serial number: 6352QSME767F0A26U
Serial number: 6362QSME7702184AH
Serial number: 63732SME4A051D582
Serial number: 63832SME4D05136C1
13697280 - Component Protection
U1101 00 [137] - Active
Fault Frequency: 19
Time: 00:00:00
12583424 - Powertrain Databus
U0002 00 [009] - No Communications
[High Speed CAN Communication Bus no signal/communication]
Reset counter: 97
Time: 00:00:00
9482752 - Seat Occupied Recognition
B10B2 00 [137] - Function Restriction due to Missing Message(s)
[Bladder Mat: functional restriction because of missing message]
Reset counter: 97
Time: 00:00:00
Address 16: Steering wheel
Address 17: Instruments
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1112186C0
Coding: 00C303
Shop #: WSC 02391 823 56573
VCID: 015F82945101390FC69-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 11006F52290111
20 Faults Found:
01304 - Radio
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.40 V
Count: 6
Bin. Bits: 10000
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.40 V
Count: 6
Bin. Bits: 10000
00456 - Control Module for Access and Start Control (J518)
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
02078 - Media Player Position 3 (R120)
Reset counter: 97
Bin. Bits: 00001
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Address 2E: Media Player 3
Address 46: Central Conv.
Address 47: Sound System
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000004
VCID: 392F2A747551A1CFCE9-806C
Fault Status: 11100100
Reset counter: 97
Mileage: 1048574 km
Reset counter: 97
Mileage: 1048574 km
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Address 77: Telephone
End----------(Elapsed Time: 00:45, VBatt start/end: 12.3V/12.3V)-----------
