Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: P1570-35 Polo 1.4 2001
    Nov 2019
    Sweden
    It's ALWAYS worth keeping VCDS updated, it doesn't cost anything and it gets you bug fixes and updates to data files - even those for older cars as the community discover more information. There really is no good reason not to be using the latest VCDS - unless you don't have a genuine Ross-Tech cable of course?
    as I answered above - my old laptop doesn't accept further VCDS updates. Next time though, I'll run the scans on my new laptop with latest specs of VCDS. Peace
    //Tobias, Scirocco TDI'10. Polo 1.4'01. Scirocco GTI'82
  2. #12
    Nov 2019
    Sweden
    I can't stress enough that if you have G28 and G40 but in some ECU's if the timing is out of phase, it can indeed stop a spark pulse and this used to happen in old distributor motors way back when too or waste spark type coil drivers.
    Be absolutely sure you have terminal 15 to coil during being cranked too because if an ignition switch is FUBAR this can happen too.
    The fuel pump relay DTC also bothers me.
    Thank you all for your input!
    The car has yet to start.
    The reason for trying another box/immo/key is due to scan says "blocked by immo" thinking maybe the key has lost its connection to transponder or something. By changing box/immo/key we wanted to solve the problem. And I believe it's a great clue, since car is equally dead using box no2, but no "blocked by immo"-error code.
    We will check all new clues and return here with more info or even better the news that car is ok. Since we run no business - this is friend of mine's car - we might progress slowly.
    Sincerely /Tobias
  3. #13
    Even with blocked immobilizer car should crank, start and die after 2 seconds.
  4. Likes Uwe, MartinsX liked this post
  5. #14
    Nov 2019
    Sweden
    Thank you. I thought so too. Car cranks, but doesn't start at all.
  6. #15
    Yes we know that, that is why I want you to see it is another underlined condition in addition to possible battery or immobilizer issues too?
    Have you checked phase timing of the G28 and G40 yet + compression?
  7. #16
    Nov 2019
    Sweden
    Hi again,
    we gave it another go, and got the following reading from the original ECU:
    VCDS Version: Release 15.7.4 Running on Windows XP x86
    Data version: 20160216
    Friday,01,May,2020,17:28:41:25054
    Chassis Type: 6N (6N - VW Polo (1995 > 2002))
    Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
    VIN: WVWZZZ6NZ1Y308079
    Address 01: Engine        Labels: 036-906-034-APE.lbl
       Part No: 036 906 034 D
       Component:  MARELLI 4LV       3458
       Coding: 00031
       Shop #: WSC 00788
       VCID: 131DFD2A611456A6D3-FFFE
                P1570 - 35-10 -  - Intermittent
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 6X0-907-379.lbl
       Part No: 6X0 907 379 B
       Component: ABS     30 IE CAN  V004
       Coding: 05603
       Shop #: WSC 00788
       VCID: 43BD0D6A51F4062623-FFFE
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 1.0.0
       Coding: 04000
       Shop #: WSC 00788
       VCID: 2171A7E2ABA8343651-FFFE
       Part No: 6Q0 909 605 A
       Component: 2P AIRBAG VW5  03   0006
       Coding: 12880
       Shop #: WSC 00788
       VCID: 355963B20F20A8969D-FFFE
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 6N0-920-xxx-17.lbl
       Part No: 6N0 920 804 D
       Component: KOMBIINSTRUMENT TRW V12
       Coding: 00141
       VCID: 2F5551DAED7C9246D7-FFFE
    00771 - Fuel Level Sensor (G)
       Part No: 6N0 909 901
       Component: Gateway K<->CAN
       Coding: 00022
       VCID: 70D792A630C2CDBE8E-FFFE
    Address 25: Immobilizer        Labels: 6X0-953-257.lbl
       Part No: 6X0 953 257
       Component: IMMO                0008
       Coding: 00001
       VCID: 7DC9BB927790B0D615-FFFE
       WVWZZZ6NZ1Y308079     VWZ1Z0A1507948
    End-------------------------(Elapsed Time: 04:22)--------------------------
    Then changes the ECU and immo since reading says engine was blocked by immo.
    This is reading from box 2
    Friday,01,May,2020,18:04:39:25054
    Chassis Type: 6X (6N - VW Polo (1995 > 2002))
    VIN: WVWZZZ6XZ2B022879
       Part No: 036 906 034 AQ
       Component:  MARELLI 4LV       3420
       Coding: 00031
       Shop #: WSC 00788
       VCID: 61F1E7E2EB28743611-FFFE
       WVWZZZ6XZ2B022879     VWZ1Z0A1860028
    16845 - Fuel Level Sensor Circuit
                P0461 - 35-00 - Implausible Signal
    18020 - Engine Control Module Incorrectly Coded
                P1612 - 35-00 -
    18087 - EPC Warning Lamp (K132) Circuit
                P1679 - 35-00 - Open
    18099 - Malfunction Indication Light (K83)
                P1691 - 35-00 - Open Circuit
       Coding: 05603
       Shop #: WSC 00788
       Coding: 04000
       Shop #: WSC 00788
       Coding: 12880
       Shop #: WSC 00788
       Coding: 00141
       Coding: 00022
       Coding: 00001
       Shop #: WSC 00046
    End-------------------------(Elapsed Time: 04:23)--------------------------
    But still, cranking but not starting.
    Change to box 3, which is also a D-box, like original.
    Here is its readings:
    Friday,01,May,2020,18:30:23:25054
    Chassis Type: 6N - VW Polo (1995 > 2002)
       Coding: 05603
       Shop #: WSC 00788
       Coding: 04000
       Shop #: WSC 00788
       Coding: 12880
       Shop #: WSC 00788
       Coding: 00141
       Coding: 00022
    End-------------------------(Elapsed Time: 04:54)--------------------------
    But still it doesn't start.
    Yes, I still run the VCDS on my old XP-laptop, since win10-laptop with latest version can't find the dongle, my apologies.
    /Tobias
  8. #17
    Quote Originally Posted by DocScirocco View Post
    You have an Auto-Intern Auto-COM or Multi-Scan. They have a driver for it here:
    https://www.auto-intern.de/downloads/treiber-firmware/
    It's the second download on that page. Or try this direct/deep link:
    https://www.auto-intern.de/media/arc...usb-driver.zip
    That immo appears to be dead. It doesn't respond (no address 25 in that scan) and it doesn't let the K-line through to the W-line either, as indicated by the lack of response from 01-Engine.
    Between scans 1 and 2 you also swapped ECUs?
    Given the age of this car, maybe the best approach would be to send the correct ECU out to someone who can do an immo defeat on it?
  9. #18
    Nov 2019
    Sweden
    immo defeated, 3 complete sets of ECU + immos
    Thank you, I will try it.
    Between scan 1 and scan 2, we swapped ECU and immo-unit. The ECU and Immo-unit were harvested from the same donor car.
    Between scan 2 and scan 3, we again swapped ECU together with corresponding immo.
    So all in all, the complete sets of ECU+immo with its keys.
    We tried that too, sending original box to immo defeaters. It was reinstalled with exactly the same VCDC readings and same no starting car.
    So the immo defeat was undone, still no change in VCDC or starting.
    However, might it be another problem, than immo? Some people says that with immo fault, engine should fire and run for two seconds, before cut out. This one doesn't run at all.
    /Tobias
  10. #19
    Good point. I would also expect a car of this age to fire momentarily before cutting out if the Immo was the only issue.
