P1570-35 Polo 1.4 2001
DocScirocco
Sweden
C?ID=240304
Greetings!
We have a Polo 1.4 75 hp 2001 Color Concept, which refuses to start.
The scan (see below) says P1570-35, indicating on immo. But, it doesn't fire at all. Immo-blocks usually allow the engine to shortly ignite, before cut out. So we changed to another ECM with its pairing immo and key. This returned several other codes, but not the P15770-35 "immo-fault". Still, not spark at all.
How to address this? Is it the combi instrument?
Thank you in advance!
sincerely, Tobias, Sweden
Original box scan:
Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: Release 15.7.4 Data version: 20160216
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,21,October,2019,13:26:44:25054
VIN: WVWZZZ6NZ1Y308079 License Plate: SNC780
Mileage: Repair Order: 191101-1
Chassis Type: 6N (6N - VW Polo (1995 > 2002))
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 D
Component: MARELLI 4LV 3458
Coding: 00031
Shop #: WSC 00788
VCID: 131DFD2A611456A6D3-FFFE
P1570 - 35-00 -
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 6X0-907-379.lbl
Part No: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
VCID: 43BD0D6A51F4062623-FFFE
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 04000
Shop #: WSC 00788
VCID: 2171A7E2ABA8343651-FFFE
Self-Diagnosis Log
Page 2
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 2P AIRBAG VW5 03 0006
Coding: 12880
Shop #: WSC 00788
VCID: 355963B20F20A8969D-FFFE
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6N0-920-xxx-17.lbl
Part No: 6N0 920 804 D
Component: KOMBIINSTRUMENT TRW V12
Coding: 00141
VCID: 2F5551DAED7C9246D7-FFFE
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
VCID: 70D792A630C2CDBE8E-FFFE
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
VCID: 7DC9BB927790B0D615-FFFE
WVWZZZ6NZ1Y308079 VWZ1Z0A1507948
End-------------------------(Elapsed Time: 04:18)--------------------------
Scan engine replacement box:
Dealer/Shop Name:
Diagnostic Trouble Code Report
Monday,21,October,2019,14:34:35:25054
VIN: WVWZZZ6XZ2B022879 License Plate: SNC780
Mileage: Repair Order: 191102-2
Control Module Part Number: 036 906 034 AQ
Component and/or Version: MARELLI 4LV 3420
Software Coding: 00011
Work Shop Code: WSC 00046
VCID: 61F1E7E2EB28743611-FFFE
Additional Info: WVWZZZ6XZ2B022879 VWZ1Z0A1860028
10 Faults Found:
16845 - Fuel Level Sensor Circuit
P0461 - 35-00 - Implausible Signal
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 -
18099 - Malfunction Indication Light (K83)
P1691 - 35-00 - Open Circuit
18087 - EPC Warning Lamp (K132) Circuit
P1679 - 35-00 - Open
17851 - Potentiometer for EGR (G212)
P1443 - 35-10 - Signal too Low - Intermittent
17564 - Manifold Pressure Sensor (G71)
P1156 - 35-10 - Open/Short to Ground - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187)
P1544 - 35-10 - Signal too Large - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
17949 - Fuel Pump Relay (J17)
P1541 - 35-10 - Open Circuit - Intermittent
Admin Request 1: Please do not use the [Print] function in VCDS to post data here. The native .txt data that VCDS produces directly using [Copy] or [Save] is considerably easier to read here in the forum.
Admin Request 2: VCDS 15.7.4? Really? Updates are free.
Is 036-906-034-AQ an appropriate replacement for 036-906-034-D?
I notice they are coded differently and the new ECU complains it is incorrectly coded.
Vehicle Identification No.WVWZZZ6NZ1Y308079
ModelPolo 16V
PO
Date of production02.05.2001
Model year2001
Sales type6N20Q4
Engine CodeAUA
Transmission CodeETD
IS CAR IN TIME AND SEEING BOTH G28 & G40?
PART NUMBERDESCRIPTIONREMARKMODEL
* 030 957 147 H impulse sender
AUA,AHW,APE,
AFK,AUB
Dropped: Dec 1, 2003 (EKZ: L)
[h=1]Supersession[/h]
030 957 147 T impulse sender
* 032 905 106 B ignition transformer ALD,AUC,AKK,
AKP,AUD,AHW,
AUA,AFK,AUB,
ARC,AVY,APE
Dropped: Jan 31, 2011 (EKZ: L)
PART NUMBERDESCRIPTIONREMARKMODELRRP
032 905 106 F ignition transformer
DocScirocco
Sweden
C?ID=240304
Request 1: certainly, my apologies. It won't happen again.
Request 2: The XP-laptop isn't fond of more updates, but next time I'll download it to a newer computer. However, won't the old version do for an old car?
Tried to recode the replacement. However it seems it did not accept the change. Reading an old thread here, it is suggested one also must login in order to get the ECM to accept the new code. Haven't had the guts yet to try.
Yes but why is the old one bad or diagnosed as bad?
When you crank engine can you see RPM ref in VCDS blocks & is there a pulse to coil with LED probe on trigger?
PetrolDave
Westbury, UK
C?ID=1423
It's ALWAYS worth keeping VCDS updated, it doesn't cost anything and it gets you bug fixes and updates to data files - even those for older cars as the community discover more information. There really is no good reason not to be using the latest VCDS - unless you don't have a genuine Ross-Tech cable of course?
MartinsX
Riga, Latvia
C?ID=268515
There may be some reason but it does not fit in this topic and I will start a new one when I got enough data collected.
No, he has a legitimately licensed cable. Trust me, I checked quite carefully in this case! :D
I can't stress enough that if you have G28 and G40 but in some ECU's if the timing is out of phase, it can indeed stop a spark pulse and this used to happen in old distributor motors way back when too or waste spark type coil drivers.
Be absolutely sure you have terminal 15 to coil during being cranked too because if an ignition switch is FUBAR this can happen too.
The fuel pump relay DTC also bothers me.
DocScirocco
Sweden
C?ID=240304
as I answered above - my old laptop doesn't accept further VCDS updates. Next time though, I'll run the scans on my new laptop with latest specs of VCDS. Peace
DocScirocco
Sweden
C?ID=240304
Thank you all for your input!
The car has yet to start.
The reason for trying another box/immo/key is due to scan says "blocked by immo" thinking maybe the key has lost its connection to transponder or something. By changing box/immo/key we wanted to solve the problem. And I believe it's a great clue, since car is equally dead using box no2, but no "blocked by immo"-error code.
We will check all new clues and return here with more info or even better the news that car is ok. Since we run no business - this is friend of mine's car - we might progress slowly.
Sincerely /Tobias
DocScirocco
Sweden
C?ID=240304
Thank you. I thought so too. Car cranks, but doesn't start at all.
Yes we know that, that is why I want you to see it is another underlined condition in addition to possible battery or immobilizer issues too?
Have you checked phase timing of the G28 and G40 yet + compression?
DocScirocco
Sweden
C?ID=240304
Hi again,
we gave it another go, and got the following reading from the original ECU:
VCDS Version: Release 15.7.4 Running on Windows XP x86
Friday,01,May,2020,17:28:41:25054
   Coding: 00031
   Shop #: WSC 00788
            P1570 - 35-10 -  - Intermittent
   Coding: 05603
   Shop #: WSC 00788
   Coding: 04000
   Shop #: WSC 00788
   Coding: 12880
   Shop #: WSC 00788
   Coding: 00141
00771 - Fuel Level Sensor (G)
   Coding: 00022
   Coding: 00001
End-------------------------(Elapsed Time: 04:22)--------------------------
Then changes the ECU and immo since reading says engine was blocked by immo.
This is reading from box 2
Friday,01,May,2020,18:04:39:25054
Chassis Type: 6X (6N - VW Polo (1995 > 2002))
   Part No: 036 906 034 AQ
   Component:  MARELLI 4LV       3420
   Coding: 00031
   Shop #: WSC 00788
            P1612 - 35-00 -
   Coding: 05603
   Shop #: WSC 00788
   Coding: 04000
   Shop #: WSC 00788
   Coding: 12880
   Shop #: WSC 00788
   Coding: 00141
   Coding: 00022
   Coding: 00001
   Shop #: WSC 00046
End-------------------------(Elapsed Time: 04:23)--------------------------
But still, cranking but not starting.
Change to box 3, which is also a D-box, like original.
Here is its readings:
Friday,01,May,2020,18:30:23:25054
Chassis Type: 6N - VW Polo (1995 > 2002)
   Coding: 05603
   Shop #: WSC 00788
   Coding: 04000
   Shop #: WSC 00788
   Coding: 12880
   Shop #: WSC 00788
   Coding: 00141
   Coding: 00022
End-------------------------(Elapsed Time: 04:54)--------------------------
But still it doesn't start.
Yes, I still run the VCDS on my old XP-laptop, since win10-laptop with latest version can't find the dongle, my apologies.
/Tobias
You have an Auto-Intern Auto-COM or Multi-Scan. They have a driver for it here:
https://www.auto-intern.de/downloads/treiber-firmware/
It's the second download on that page. Or try this direct/deep link:
https://www.auto-intern.de/media/archive/dc/04/7b/usb-driver.zip
That immo appears to be dead. It doesn't respond (no address 25 in that scan) and it doesn't let the K-line through to the W-line either, as indicated by the lack of response from 01-Engine.
Between scans 1 and 2 you also swapped ECUs?
Given the age of this car, maybe the best approach would be to send the correct ECU out to someone who can do an immo defeat on it?
DocScirocco
Sweden
C?ID=240304
immo defeated, 3 complete sets of ECU + immos
Thank you, I will try it.
Between scan 1 and scan 2, we swapped ECU and immo-unit. The ECU and Immo-unit were harvested from the same donor car.
Between scan 2 and scan 3, we again swapped ECU together with corresponding immo.
So all in all, the complete sets of ECU+immo with its keys.
We tried that too, sending original box to immo defeaters. It was reinstalled with exactly the same VCDC readings and same no starting car.
So the immo defeat was undone, still no change in VCDC or starting.
However, might it be another problem, than immo? Some people says that with immo fault, engine should fire and run for two seconds, before cut out. This one doesn't run at all.
/Tobias
Good point. I would also expect a car of this age to fire momentarily before cutting out if the Immo was the only issue.
