Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Need help! 04 Audi A8l won't start
  1. #21
    T81/26=G70 (Mass Air Flow (MAF) Sensor). It draws large current or am i wrong? sorry I'm just learning lol
    Very good I'm proud of you OP!
    Did you know that no normally G70 it does NOT draw a significant amount of current, however, it makes me wonder why a 15 AMP fuse is used in WD for this and the consumers on the track in 87 and 87a huh, especially when those circuits which are burned are rated at 4 AMPS or less within the ECU, sigh?
    In addition to the aforementioned question, I'm still puzzled myself & further trying to understand why two separate heated OXS sensor supply fuses would be 15 Amp each too & when they only draw about an amp each & makes for no wonder why controllers are sacrificed?
    Did you trace everything on each consumer BUS and find out what is using the ECU as a fuse yet or did someone make a boo boo and induce this travesty of FOD?
    Also i just found out that the MAF sensor plug was unplug if that counts.
    Why was the MAF unplugged?
  2. #22
    Report?
    Any news
    FYI:
    When I extract the data in that old controller, there will indeed most likely be a forensic & of what happened before it went straight to DEAD!
  3. #23
    Well.............?
  4. #24
    Nov 2019
    Connecticut, USA
    Well.............?
    I apologized for the late response but I didn't want to respond without knowing what really happened, but I'm sure now, I might of put some voltage to one of the ground points of the car when installing the air ride cause I found my air ride relay to be connected wrong and to be specific i ran the ground from the relay where the remote wire was suppose to be and the remote where the ground was suppose to be. And I also bought an use ecm from the junk yard for $26 to make sure it wasn't going to damage it, so it worked and the car cranked and all the fuses were good. Now I can go ahead and buy the ecm from you lol
  5. Likes Jack@European_Parts liked this post
  6. #25
    While you might think that's a valid diagnosis did you know it is not?
    Ask yourself these questions please, okay?
    Did you know & I would like to point out, that heated OXS oxygen sensors, do not initially turn on or reach a critical mass load shed, nor do other switched consumers to ground when ECU is only ran for 2 seconds to blow a fuse?
    Don't you think it would be recommended to load test each consumer for actual draw?
    Were there any blown fuses when ECU burned down?
    What track exactly did you back feed B+ to ground through ECU and how would the ECU of switched it?
  7. #26
    Fixed yet.........?
