Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Need help! 04 Audi A8l won't start
  1. #21
    T81/26=G70 (Mass Air Flow (MAF) Sensor). It draws large current or am i wrong? sorry I'm just learning lol
    Very good I'm proud of you OP!
    Did you know that no normally G70 it does NOT draw a significant amount of current, however, it makes me wonder why a 15 AMP fuse is used in WD for this and the consumers on the track in 87 and 87a huh, especially when those circuits which are burned are rated at 4 AMPS or less within the ECU, sigh?
    In addition to the aforementioned question, I'm still puzzled myself & further trying to understand why two separate heated OXS sensor supply fuses would be 15 Amp each too & when they only draw about an amp each & makes for no wonder why controllers are sacrificed?
    Did you trace everything on each consumer BUS and find out what is using the ECU as a fuse yet or did someone make a boo boo and induce this travesty of FOD?
    Also i just found out that the MAF sensor plug was unplug if that counts.
    Why was the MAF unplugged?
  2. #22
    Report?
    Any news
    FYI:
    When I extract the data in that old controller, there will indeed most likely be a forensic & of what happened before it went straight to DEAD!
