Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Need help! 04 Audi A8l won't start
    Nov 2019
    Connecticut, USA
    Here's a short description of what happened, bought the car last year, 1 owner, 82,000 miles and it was well maintained (owner bought same car but 2017) anyways everything was working fine and then I parked the car in my garage over the winter so this year around March I decided to turn the car on but the battery was dead, so I bought a new one but no from the dealership, it's a agm and it's suppose to be a direct fit. So I ran my Ross-tech tool to register the battery, I added a number in the serial number to trick the car into to think that I put a new battery and it worked the battery level shows 100%. I can turn the switch on and everything lights up but the car won't start or crank at all. Also windows go down but won't go up. I checked all the fuses and they're good.
    Sunday,10,November,2019,14:04:14:19032
    VIN: WAUML44E84N017656   License Plate:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
              47 4F 52 53 55 56 61 62 65 72 75 76
    VIN: WAUML44E84N017656   Mileage: 134170km-83369miles
    Address 01: Engine
       Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0110
       Revision: 00000001    Serial number:        0027415
       Shop #: WSC 02313 785 00200
       VCID: 2411EE5FE2DF5AA78E1-8070
    18258 - Powertrain Data Bus
                P1850 - 000 - Missing Message from ECU
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 17.0°C
                        T.B. Angle: 60.0°
                        Voltage: 10.08 V
    18005 - Powertrain Databus
                P1597 - 000 - Missing Message from Level Control System (J197) - Intermittent
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 17.0°C
                        T.B. Angle: 60.0°
                        Voltage: 10.08 V
    18289 - Powertrain Data Bus: Missing Message
                P1881 - 000 - Acceleration Request
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 17.0°C
                        T.B. Angle: 60.0°
                        Voltage: 10.08 V
    16944 - System Voltage
                P0560 - 000 - Malfunction - Intermittent
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 17.0°C
                        T.B. Angle: 60.0°
                        Voltage: 10.08 V
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
       Component: ESP 5.7 allrad  H44 0500
       Coding: 0007597
       Shop #: WSC 02313 000 00000
       VCID: 221DE847F8CB5497FCD-8076
    02083 - Message for Delay Request
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 A
       Component:     FBS AUDID3  H03 0140
       Revision: 01403903    Serial number: AUX3Z0CD531291
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58E98AAFEE17CE47D29-800C
                        Fault Frequency: 0
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:41:22
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940448
       Shop #: WSC 00000 785 00200
       VCID: 2313ED43E7D15D9FF7B-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 729 B    HW: 4E0 035 729
       Component: Interfacebox    H43 0150
       Revision: 00000000    Serial number: 346L/037508758
       Coding: 0000103
       VCID: 270BF95393E9B1BFAB3-8072
       Subsystem 1 - Part No: 4E0 910 609 A
       Component: Bedienteil MMI  H42 0020
       Subsystem 2 - Serial number: 301DR047536949
       Subsystem 3 - Serial number: 7407.04.040000000000010085ÿ
       Subsystem 4 - Serial number: 010085ÿ
                        Reset counter: 206
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:15:27
                        Bin. Bits: 00000000
                        Bin. Bits:  0100000
                        Bin. Bits:      000
       Part No SW: 4E0 910 043     HW: 4E0 820 043 A
       Component: KLIMAAUTOMAT    016 0240
       Revision: 00000022    Serial number: 00000000033022
       Coding: 1085697
       VCID: 5AED90A7901BDC57E4D-800E
                014 - Defective
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
       Component: ILM Fahrer      H11 0100
       Coding: 0111113
       VCID: 2A0D006780FB8CD7B4D-807E
       Subsystem 1 - Part No: 4E1 910 113 B
       Component: Wischer WWS D3  H30 0360
       Coding: 00000036
       Shop #: WSC 02313
                        Reset counter: 206
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:00:26
    01308 - Control Module for Roof Electronics (J528)
                        Reset counter: 206
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:05:15
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7173786
       VCID: 1B63D5A3DFA1655F3FB-804E
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Coding: 0012241
       VCID: 6597B35BA96563AF59F-8030
       Component: Lenkradmodul    H04 0080
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900     HW: 4E0 920 950 B
       Component: KOMBIINSTR. VDO H44 0090
       Revision: D15         Serial number: AUDID3CD006652
       Coding: 0016233
       Shop #: WSC 08310 444 92086
       VCID: 5CE196BF9A2F2267F61-8008
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0030
       Revision: 07          Serial number: 0200503C011191
       Coding: FCFE7BDD1B2304
       VCID: 2615F45794E3A8B7905-8072
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:31:37
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
       XXXXXXXXXXX ELV                 XXXX
                        Fault Frequency: 0
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:41:22
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
       Component: LUFTFDR.-CDC    H05 4290
       Coding: 0015510
       VCID: 2517F35BE9E5A3AF99F-8070
    8 Faults Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
                        Fault Frequency: 162
                        Reset counter: 199
                        Mileage: 126926 km
                        Date: 2004.09.17
                        Time: 14:28:12
                        Fault Status: 11100100
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:09:43
    01398 - Signal from Central Locking: Doors Open
                        Reset counter: 206
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:09:28
                        Fault Status: 11101000
                        Reset counter: 166
                        Mileage: 133022 km
                        Date: 2003.10.08
                        Time: 00:01:32
    00774 - Level Control System Sensor; Rear Left (G76)
                        Fault Status: 11101100
                        Reset counter: 166
    00775 - Level Control System Sensor; Rear Right (G77)
                        Reset counter: 166
                        Reset counter: 166
    01769 - Sensor for Vehicle Leveling; Front Right (G289)
                        Reset counter: 166
       Component: Sitzmemory FS  H07  0060
       Coding: 4071522
       Part No SW: 4E0 910 887 A    HW: 4E0 919 887 C
       Component: MNS US          H42 0150
       Revision: 00000000    Serial number: 355AM047514483
       VCID: 2B0305638F0195DF4FB-807E
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H01 0090
       Serial number: 00000333000055
       Coding: 0003973
       VCID: 1D67DBBBC1B56B6FC1F-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 801
       Component: Türsteuer.FS BRM005 0110
       Coding: 0028196
       VCID: 5EE59CB78C333077985-800A
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H03 0030
       Revision: 00300003    Serial number:  W040312160082
       Coding: 0064542
       Subsystem 1 - Part No: 4E0 907 719
       Component: Neigungssensor  H02 0020
    6 Faults Found:
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 166
                        Mileage: 89639 km
                        Date: 2004.01.09
                        Time: 13:39:36
                        Fault Frequency: 51
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:05:26
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Fault Frequency: 177
                        Reset counter: 166
    02198 - Bulb for Tail Light 2; Left (M49)
                        Fault Frequency: 202
                        Reset counter: 166
    01134 - Alarm Horn (H12)
                        Fault Frequency: 11
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 22:12:32
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 118
                        Reset counter: 166
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 B    HW: 4E0 035 223 B
       Component: DSP-High D3/AUX H13 0200
       Revision: Dev_D01     Serial number: 00000000678358
       Coding: 0000016
       VCID: 1C61D6BFDAAF6267361-8048
    00003 - Control Module
                        Fault Frequency: 0
                        Reset counter: 0
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H08 0020
       Revision:             Serial number: 00000000030715
       Coding: 0010111
       VCID: 1E65DCB7CCB37077D85-804A
       Subsystem 1 - Part No: 4E0 910 511 A
       Component: UGDO HL US      H02 0030
       Subsystem 2 - Serial number: VK4978T0A72E
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:31:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 802
       Component: Türsteuer.BF BRM005 0110
       Coding: 0028196
    02111 - Motor for Window Regulator
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:16:12
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revision: AV1C1010
       Coding: 0000532
                        Fault Frequency: 90
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:02:17
                        Voltage: 10.25 V
                        Count: 241
    02596 - Rear Brake Pads Worn
                        Fault Status: 01111000
                        Reset counter: 166
                        Voltage: 11.18 V
                        Count: 61
                        Reset counter: 206
                        Voltage: 0.00 V
                        Count: 188
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0040
       VCID: 629DA847B84B1497BCD-8036
                        Reset counter: 0
                        Mileage: 134184 km
                        Date: 2003.10.08
                        Time: 00:58:34
    01310 - Level Control System Control Module (J197)
                        Fault Frequency: 0
                        Reset counter: 206
                        Mileage: 134184 km
                        Date: 2003.10.08
                        Time: 00:58:35
    02233 - Left Headlight Power Output Stage (J667)
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 134184 km
                        Date: 2003.10.08
                        Time: 01:01:25
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 134184 km
                        Date: 2003.10.08
                        Time: 01:01:27
    00070 - Starting Battery Voltage
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 134184 km
                        Date: 2003.10.08
                        Time: 01:01:42
       Part No SW: 4E0 910 541 B    HW: 4E0 035 541
       Component: TUNER EU/US/RDW H41 0220
       Revision: 00000000    Serial number: 304AG047557161
       VCID: 1F1BE1B3CBB9797FD33-804A
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 B    HW: 4E0 915 181
       Component: ENERGIEMANAGER  H02 0240
       Revision: 00000000    Serial number: 00000005832723
       Shop #: WSC 01405 444 54257
       Subsystem 1 - Part No: 000 915 105 DL
       Component: von VA0  310314E04G
       Coding: 303030393135313035444C56413033313033313445303447
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:40:03
    02275 - Quiescent Current Stage 4
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:40:03
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 801 A
       Component: Türsteuer.HL BRM005 0110
       Coding: 0028196
       VCID: 5DE79BBB81352B6F81F-8008
                        Reset counter: 166
                        Mileage: 134176 km
                        Date: 2003.10.08
                        Time: 00:16:48
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273     HW: 4E0 907 273
       Component: Reifendruck 2   H01 0210
       Coding: 0212127
       VCID: 5F9BA1B38B39397F933-800A
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 166
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:33:06
                        Voltage: 11.30 V
                        (no units): 27.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    01477 - System Switched Off
                        Reset counter: 206
                        Mileage: 134178 km
                        Date: 2003.10.08
                        Time: 00:16:29
                        Temperature: 8.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 802 A
       Component: Türsteuer.HR BRM005 0110
       Coding: 0028196
    Address 75: Telematics        Labels: None
       Part No SW: 4E0 910 616     HW: 4E0 035 616 A
       Component: Telematik USA1      0070
       Revision: 00000004    Serial number: 0000ATD3007465
       Coding: 0000005
       VCID: 6099A24FB6570687AA9-5160
    01531 - Emergency Battery
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H11 0010
       Revision: --.--.--    Serial number: 00000400900235
       Coding: 0001208
       VCID: 211FE74BFDCD4F8FE57-8074
    End----------(Elapsed Time: 02:07, VBatt start/end: 12.4V/12.4V)-----------
    004 - No Signal/Communication[/QUOTE]
    Vehicle Identification No. WAUML44E84N017656
    Model Audi A8L qu. 4.2
    A8Q
    Date of production 20.01.2004
    Model year 2004
    Sales type 4E851L
    Engine Code BFM
    Transmission Code GQF
    Emission standard 0GM Emission standard LEV 1
    Hello OP and welcome to the VCDS forum.
    Engine control module 0x01 is offline........
    Did you check terminal outputs at engine control module directly using WD in RTFB yet?
    PART NUMBER DESCRIPTION REMARK MODEL
    4E0 910 560 A https://www.ebay.com/itm/331518281721 Control unit for petrol engine BFM
  3. Likes MartinsX, Uwe liked this post
    Nov 2019
    Connecticut, USA
    A8Q
    Model year 2004
    Sales type 4E851L
    Engine Code BFM
    [/QUOTE]
    Thanks for the response and I didn't RTFB cause I didn't had access nor didn't I know how to find a WD for these type of cars lol. I'm new to euro cars and besides you can get any WD book in any auto part store for any car other than euro cars. Anyways let's get back to business, my friend helped me out and yes the ECM is fried so my question is, do I need to send you my ECM first or make the ebay purchase first from the link you sent me?
    Nov 2019
    Connecticut, USA
    Also I didn't check terminal outputs at engine control module
  6. Likes Jack@European_Parts liked this post
    How do you know it's fried if you did not test stuff?
    I'd rather you diagnose it and tell me how you know it's fried please?
    Pictures if a visual was determined?
    You can use link or contact form in my signature for direct secure purchases.
  8. Likes Uwe liked this post
  9. #6
    Agreed -- it would be entirely premature to purchase a replacement ECU without doing more considerably more testing.
  10. Likes Jack@European_Parts, PetrolDave liked this post
  11. #7
    Oh... And this is just one of the reasons why we respect Jack and put up with some of his antics.
    He has the exact ECU that the OP might need, but he doesn't want the OP to throw money at the problem without a reasonable level of confidence that doing so will actually improve his situation.
  12. #8
    Thank you Uwe....
    Yup..... I may joke around about stuff, sometimes almost intolerable my stupid sarcasm, however, I don't mess around when it comes to diagnosis!
    People don't understand me, it's out of love for all people I joke or try to make you see my or another approach angle.
    If you ask a question again I already clearly answered like in the CAT filing his nails to scratch me thread and you try to dismiss or ask for a magic answers to try and circumvent a test or self verifiable information path and try to trade off my life experience instead, you will be in for a bad time.
    You have me here for absolutely free & for VCDS related major systems or even in some cases comprehensive guidance above the actual RTFB on mechanical or inadequate explanation of how something functions.
    That said I have an expectation that you, especially if a shop or industry tech have done their job too & if you have not I will break your balls so you never forget and actually learn something.
    It is always with this intent I roll.
    Now if you are seeking to circumvent a safety or SMOG system or what I deem an unreasonable retrofit hiding in the spirit of aforementioned, expect my apprehension or reveling in your failure!
  13. Likes Uwe, NZDubNurd, PetrolDave, mattylondon liked this post
  14. #9
    Nov 2019
    Connecticut, USA
    Thank you Uwe....
    I apologized, and I did saw your sarcasm lol I just didn't reply with the right response. I really appreciated the help and I went ahead and bought the erWin and tomorrow I'm going to be testing everything out and I'll keep you post it.
  15. Likes Uwe liked this post
  16. #10
    Did you measure for terminal 15, 30 and 31 yet at ecu plug directly?
    Hey what's this crap below?
    3 : +12V ( term.15 )
    1 : GND ( term. 31 )
    2 : GND ( term. 31 )
    21 : +12V ( term. 30 )
    43 : K Line
    60 : CAN High
    58 : CAN Low
  17. Likes Uwe liked this post
