02 Beetle Immo, Cluster, ECU
Bugman
New Member
H10-010657 (2nd hand?)
02 Beetle 1.8T
Problem started with LED's going out in the speedo. Next the odometer/trip display went out.
Then the immobilizer failed to read the key and the car would start/die.
Time and money (not enough of either) swayed me to have the immo delete performed.
The ECU came back and now the engine would crank (turn over), but not start/die.
Sprayed starting fluid in the airbox and the car started. Ok, no fuel. Fed 12 volts the fuel pump car started.
Traced back to the fuel pump relay, jumped the relay, car started. Changed the relay, no joy.
Fed ground to the 'Mot' (pin #1) on the FPR and the car started.
Seems to me the immo delete wasn't done correctly.
I bought a used cluster (matching part number), but need an interface.
Had a technician (not vw) come to adapt the cluster, he couldn't due to "no communication".
Bought another ECU.
Bought a Ross-Tech HEX-V2 cable and download VCDS. VCP drivers don't work with HEX-V2.
Sum it up, i have a replacement ECU, replacement cluster, a cable that doesn't support 3rd party software and software that doesn't support 3rd party "knockoff" cables. Also the radio is in "safe" mode and will not accept the code.
How do i retrieve the SKC pin for the new parts? Why is getting the SKC so difficult for the owner of the car?
How do i go about adapting the replacements with the "no communication" error?
First auto-scan is with original cluster. Second is with the replacement cluster.
Wednesday,27,November,2019,17:04:46:41593
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
   Mileage: 0km-0miles
Address 01: Engine        Labels: 06A-906-032-AWV.lbl
   Part No: 06A 997 012 A
   Component: 1.8l 5VT NB AG4 G   9776
   Coding: 00003
   Shop #: WSC 02415
   VCID: 2412E391A7C1D8B78DF-513C
   3VWDD21C12M452711     VWZ5Z0B2232139
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 MC
   Component: AG4 Getriebe 01M    4948
   Coding: 00000
   VCID: 7DA4F6F564EB497FA21-0962
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   VCID: 323E15C9E83546070F3-5160
   Part No: 1C0 909 605 A
   Component: 25 AIRBAG VW51 0E   0004
   Coding: 12853
   Shop #: WSC 00066
   VCID: 221EE589BDD5D687FF3-4B3C
Address 17: Instruments        Labels: None
   Part No: 1C0 920 ÿÿÿ ÿÿÿ
   Component: KOMBI+WEGFAHRS. M73 ÿÿÿ
   Coding: 32767
   VCID: 392C22E53043B55FCE9-4B00
   Subsystem 2 - Part No: 1C0920
   ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    ÿÿÿÿ
   Coding: 32767
   Shop #: WSC 131071
   VCID: 70BADFC123B93417397-4B00
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B2038ED3A7F874FDC5-4B00
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0004
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 C
   Component: Heckspoiler         0002
   VCID: 2B0008ADCA1F17CF4C5-51F2
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1C0 035 157 D
   Component:  Radio DE2         0006
   Coding: 06031
   Shop #: WSC 57383
   VCID: 1D64D67584ABE97FC21-51CE
00856 - Radio Antenna
            36-00 - Open Circuit
End----------(Elapsed Time: 03:47, VBatt start/end: 12.6V/12.5V)-----------
Wednesday,27,November,2019,22:50:07:41593
VIN: 3VWDD21C02M456877   License Plate:
Mileage: 224670km-139603mi   Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
VIN: 3VWDD21C02M456877   Mileage: 224670km-139603miles
   Coding: 00003
   Shop #: WSC 02415
17949 - Fuel Pump Relay (J17)
            P1541 - 35-00 - Open Circuit
Readiness: 0000 1101
   Coding: 00000
   Coding: 0018945
   VCID: 323E15C9E83546070F3-513C
   Coding: 12853
   Shop #: WSC 00066
   VCID: 221EE589BDD5D687FF3-4B1E
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 GX
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 07232
   Shop #: WSC 00020
   VCID: 7DA4F6F564EB497FA21-4B00
   3VWDD21C02M456877     VWZ5Z0B3187128
01176 - Key
            65-10 - Unauthorized - Intermittent
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 02156
   Coding: 00064
   Shop #: WSC 00066
Ask VW that question.
Neither of your scans shows any problem communicating with the clusters.
Bugman
New Member
Is it even possible to adapt a replacement cluster with immo delete?
I guess i am interpreting this wrong?
Coding: 07232
Shop #: WSC 00020
01176 - Key
PetrolDave
Westbury, UK
C?ID=1423
OP - if you look at your secondscn it's not only the Instruments that are having intermittent trouble communicating with some modules but also the CAN Gateway.
This suggests to me the problem isn't the Instruments - but the CAN bus segment to which the engine, transmission, ABS and airbag modules connect i.e. the Powertrain CAN.
Maybe there is a bad connection or maybe one of those modules is intermittently interfering with the communications?
MartinsX
Riga, Latvia
C?ID=268515
As for this model 0x17 and 0x19 are physically one module, it may or may not be true. In first scan IPC is bad - corrupted EEPROM content and/or MCU/flash content.
In second scan all comm DTC's are intermittent. Other modules don't have any comm related DTC's. Those may be left in memory from someone powering up IPC out of car, for example.
Bugman
New Member
MartinsX
This is most likely from bad immo delete?
The original cluster was never out of the car until it failed.
Here's a new scan from today, which doesn't jive with the other scan. (IMHO)
Saturday,30,November,2019,13:55:41:41593
Mileage: 224800km-139684mi   Repair Order:
Scan: 01 02 03 08 15 17 19 25 35 37 46 54 56 65 75
VIN: 3VWDD21C02M456877   Mileage: 224800km-139684miles
   Coding: 00003
   Shop #: WSC 02415
No Faults Found
   Coding: 00000
   Coding: 0018945
   Coding: 12853
   Shop #: WSC 00066
   Coding: 07232
   Shop #: WSC 00020
01176 - Key
   Coding: 00006
   Shop #: WSC 02156
   Coding: 00064
   Shop #: WSC 00066
End----(Elapsed Time: 03:06, VBatt start/end: 11.5V/11.5V. VIgn 11.2V)-----
MartinsX
Riga, Latvia
C?ID=268515
If You sent only ECU to tuner for immo-off, it couldn't affect cluster. It died by itself according info You provided in post #1. They use to do like this time by time.
Tuner must return Your money and revert ECU to stock SW, as his immo-off solution is not working, again according info You provided in post #1.
I was talking about scan #2 in post #1. According Your text in post #1 scan #2 is with donor parts installed.
Did You cleared all fault codes before running scan You provided in post #6?
Did You recoded GW with the same value to make it refresh internal installation list as it is installed in another car now?
PetrolDave
Westbury, UK
C?ID=1423
Good point, I had forgotten that the CAN Gateway was actually in the Instruments on some older models.
Bugman
New Member
I have not since the tech came to adapt the new cluster.
Nothing has been recoded or adapted at this point due to the comms error and the fact
that i don't have the SKC pin.
If he couldn't do immo off correctly i do not want to send my ECU back again.
Guess i need to find someone who can flash the ECU back to stock, if that's
possible and retrieve that PIN code.
MartinsX
Riga, Latvia
C?ID=268515
I have a feeling that You have not enough knowledge and some tools are missing, too (not all operations - relatively simple, but absolutely necessary to get Your car running again - can be done with VCDS).
So I'd suggest to contact Jack or Marin. They are located in US.
Bugman
New Member
The first scan i posted was literally the first time i used VCDS. Thank you for your time.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
1. Ok, What happen when you put that other ECu in car , does it car start and turn off after 2-3 sec or has same problem as original , just cranking ?
2. For this problem :
Coding: 12853
Shop #: WSC 00066
Coding: 07232
Shop #: WSC 00020
01176 - Key
Coding: 00006
Shop #: WSC 02156
Clear codes individually in each module and see will it come back , if you disconnect cluster with Battery connected you will get this codes and CAN communication still monitor and see module was missing.
