Results 1 to 7 of 7
Thread: New week new error message
    Sep 2019
    Northern Ireland
    Mid week poor wife was out driving and the Audi A6 decided to through a hissy fit again....it un-nerved her due to the odd behaviour of the car.
    The code is below. I see lots of references to the ABS module " No Communication with ABS Brake Control Module"
    Thinking there may be a problem with ground near the ABS module. Anyone have any suggestions or knowledge in regard the attached log to help me avoid following any blind alleys?
    Thanks in advance for your help.
    Ian
    Friday,08,November,2019,17:37:52:05709
    VIN: WAUZZZ4G7EN047221   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
              72
    VIN: WAUZZZ4G7EN047221   Mileage: 157086km-97608miles
    3B-Sensor Elect. -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H25 2023
       Revision: 45H25---
       Coding: 0A194012242401080000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM20TDI01103L906018LA 003009
       ROD: EV_ECM20TDI01103L906018GT.rod
       VCID: 74B1DD4DBE3A4B77DDF-8020
              U1113 00 [036] - -
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:08
                        Engine speed: 829.00 /min
                        Normed load value: 40.0 %
                        Coolant temperature: 61 °C
                        Intake air temperature: 6 °C
                        Voltage terminal 30: 14.240 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 237
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [036] - -
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:07
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:08
                        Engine speed: 975.50 /min
                        Normed load value: 97.6 %
                        Vehicle speed: 255 km/h
                        Coolant temperature: 56 °C
                        Intake air temperature: 18 °C
                        Voltage terminal 30: 13.680 V
                        Unlearning counter according OBD: 38
                        Longitudinal acceleration: raw value: 32.767 m/s²
                        Vehicle inclination acceleration angle: raw value: 32.767 m/s²
                        Status: incline angle-Bits 0-7: 1
                        Longitudinal acceleration sensor: status-Bits 0-7: 1
                        Vehicle lateral acceleration: raw value: 327.67 g
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [036] - -
              [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Engine speed: 2690.00 /min
                        Normed load value: 38.8 %
                        Vehicle speed: 68 km/h
                        Coolant temperature: 60 °C
                        Intake air temperature: 7 °C
                        Voltage terminal 30: 14.220 V
                        Limitation: accelerator pedal: 115.1 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        selected gear-Bits 0-7: 3
    18177 - Gear Reconition Sensor
              P181E 00 [101] - Gear Position Implausible
                        Mileage: 156664 km
                        Date: 2019.10.29
                        Time: 19:09:25
                        Engine speed: 2295.50 /min
                        Coolant temperature: 67 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 14.780 V
                        Neutral position sensor: current transmission angle: 20.00 °
                        Neutral position sensor: adapted transmission angle: 0.00 °
                        Transmission neutral position sensor voltage: 0 mV
                        selected gear-Bits 0-7: 0
       Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
       Component: ESP PREMIUM   H09 0450
       Coding: 06A09F016005F9809B00
       VCID: 3A2D3375DCDEFD07C73-806E
    0601 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Dst_EpsCommError]
                        Reset counter: 92
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:05
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 13
                        Uz: B5
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Ldm_ApbFailureState]
                        Reset counter: 92
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 08
                        Uz: 9E
    0519 - FlexRay Databus
              U1031 00 [008] - No Synchronization
              [NET09_SyncLost_FlxrA]
                        Reset counter: 91
                        Mileage: 156622 km
                        Date: 2019.10.28
                        Time: 12:20:20
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 69
                        Uz: 9F
    0834 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_MO_Timeout_ESP_Error]
                        Reset counter: 92
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:09
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 26
                        Uz: B5
       Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
       Component: BCM2 2.0      H35 0510
       Coding: 03B83046000000000000
       VCID: 78A9E97DA2D22F17F17-802C
       Serial number: 0213000277728007
                        Fault Status: 00101101
                        Fault Frequency: 16
                        Reset counter: 92
                        Mileage: 157041 km
                        Date: 2019.11.05
                        Time: 11:58:00
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
       Component: KLIMA 2 ZONEN H11 0087
       Serial number: 06081300111349
       Coding: 34210008A1
       ASAM Dataset: EV_AirCondiBasisUDS 002045
       VCID: 6099A11D1AC2C7D7A97-8034
    0247 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Motorsteuergerät: Fehlerspeicher auslesen]
                        Fault Frequency: 10
                        Reset counter: 92
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:10
                        Outside air temperature: 10.0 °C
                        Engine speed: 1188 /min
                        Vehicle speed: 80.00 km/h
    0330 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät: kein Signal/keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 91
                        Mileage: 157041 km
                        Date: 2019.11.05
                        Time: 11:57:59
                        Voltage terminal 30: 13.54 V
                        Outside air temperature: 19.0 °C
                        Engine speed: 1088 /min
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001473595
       Coding: 2600201040349F600481008300001D0C0F9D830827090201000004606100
       VCID: 6E85CF25D09661A72BB-803A
       Component: WWS57X 130724  H36 0080
       Serial number:         130730230906
       Coding: 0045F7
       Serial number: 21655456
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 13 08 2013  00000238
       Serial number: CDD804C6000000000001
    01316 - ABS Control Module
                        Reset counter: 91
                        Mileage: 157041 km
                        Date: 2019.11.05
                        Time: 11:58:00
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61031323802800
       Coding: 08C206
       VCID: 71BFD459C1287E5F369-8024
    12656912 - Databus
              [Bremsensteuergerät - ESP_01 - kein Signal/keine Kommunikation]
                        Fault Frequency: 14
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
       Revision: --------    Serial number: 003JG00EFNUY
       Coding: 3032343631324E303235554A305234473053
       VCID: 36352745E8C6196723B-8062
       Serial number: 3575HRB400450J5S495T
       Serial number: 3585HRB401050JEAE29P
       Serial number: 3515JRB401250KB2912%
       Serial number: 3525JRB400A50L36J0R
       Serial number: 3554VRB405B1ROCCG9TL
       Serial number: 3564VRB405F1ROCC516R
    7 Faults Found:
    1048832 - Databus
              [CAN: 0x100 ESP_01 Timeout]
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
    1049088 - Databus
              [CAN: 0x101 ESP_02 Timeout]
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
    1049093 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                        Reset counter: 90
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:08
    1049094 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                        Reset counter: 90
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:08
    1049095 - Databus
              [CAN: 0x101 ESP_02 error value ESP_Gierrate]
                        Reset counter: 90
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:08
    1049344 - Databus
              [CAN: 0x103 ESP_03 Timeout]
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
    1049866 - Databus
              [CAN: 0x39C Gateway_05 Old value from ESP_07]
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:23:55
       Revision: 00000000    Serial number: 20130830000008
       Coding: 000014
       VCID: 3039115D0A223757797-8064
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
                        Fault Frequency: 9
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0410
       Revision: 27450257    Serial number: 658140813592024
       Coding: 33A408000B412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3FDB4261C7FCD82FF0D-806A
    16776968 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ESP_02 keine Kommunikation]
                        Fault Frequency: 8
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
    16776973 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [RDK_01 keine Kommunikation]
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:16
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000001066582
       Coding: 00CD074400
       ASAM Dataset: EV_GatewPkoUDS 001018
       Serial number: 4266551203
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 13061000000000000349
    4352 - ABS Control Module on FlexRay Data Bus
              U10BD 00 [008] - No Communication
              [Lost Communication With Vehicle Dynamics Control Module]
                        Fault Frequency: 26
                        Reset counter: 92
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.6 V
                        Control Module temperature: 20 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA72064KTJ
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33331E51FBB40C4F045-8066
    3801346 - Databus
              [PDU Timeout]
                        Fault Frequency: 27
                        Reset counter: 92
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        DCU_Internal_DTC: 3A 01 02
                        Ignition Cycle Count: 29433
                        DCU Temperature: 16 °C
                        Voltage terminal 30: 14.6 V
                        Voltage VBG 22: 2.5 V
                        VIN received: WAUZZZ4G7EN047221
                        Debug Data: 00 00 00 00 00 00 00 00
       Coding: 011C16004001620002080002
       VCID: 47CB5A819FAC90EF48D-8012
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:32
       Component: RCEPS         H38 0010
       Revision: 00001000    Serial number: 0026797143
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1B5504AE05470F3-8066
    3158273 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Ausfall Botschaft "PDU_ESP_01"]
                        Fault Frequency: 12
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:10
                        Write only channel
       Revision: 00002001    Serial number: 0313099519
       Coding: 011B062280B900408320080400010E470000000000000000000000000000
    02615 - Fuel Tank Cap; Lock
                        Fault Status: 00101001
                        Reset counter: 68
                        Mileage: 155729 km
                        Date: 2019.10.13
                        Time: 16:20:16
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 17
                        Reset counter: 88
                        Mileage: 156155 km
                        Date: 2019.10.21
                        Time: 12:27:27
                        Fault Frequency: 16
                        Reset counter: 92
                        Mileage: 157041 km
                        Date: 2019.11.05
                        Time: 11:58:00
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000026821
       VCID: 1D67D8E96DB0AA3FC21-8048
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:39
                        Bin. Bits: 00001000
       VCID: 46D5578598A689E7B3B-8012
                        Fault Status: 00101100
                        Fault Frequency: 135
                        Reset counter: 92
                        Mileage: 156578 km
                        Date: 2019.10.27
                        Time: 15:16:19
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:32
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000789673
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C01052D268A53B745F-8078
    7 Faults Found:
    328448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_01_MESSAGE_TIMEOUT]
                        Fault Frequency: 14
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Voltage terminal 30: 14.8 V
                        Internal Fault ID: 89
                        Vehicle speed: 64 km/h
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: Dynamic
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    328704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_02_MESSAGE_TIMEOUT]
                        Fault Frequency: 8
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Internal Fault ID: 90
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    328960 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_03_MESSAGE_TIMEOUT]
                        Fault Frequency: 14
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Internal Fault ID: 91
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    329216 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_05_MESSAGE_TIMEOUT]
                        Fault Frequency: 10
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
                        Internal Fault ID: 92
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    459264 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
                        Reset counter: 90
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:07
                        Voltage terminal 30: 14.7 V
                        Internal Fault ID: 138
                        Vehicle speed: 510 km/h
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Emergency running mode
    463616 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                        Reset counter: 90
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:07
                        Internal Fault ID: 185
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    406528 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_ESP_07_FR_MESSAGE_TIMEOUT]
                        Fault Frequency: 55
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:07
                        Internal Fault ID: 215
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Serial number: 130821-0002-073
       Coding: 112196101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D0708291D905ABF521-8078
    337156 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Timeout CAN-Message ESP_03  (0x103)]
                        Fault Frequency: 13
                        Reset counter: 91
                        Mileage: 156663 km
                        Date: 2019.10.29
                        Time: 19:09:09
       Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H54 0801
       Coding: 0101000101415B47082B060301020100000000
       VCID: 270BFA013FEC70EFA8D-8072
       Subsystem 1 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
       Component: DU6 Basic  H43 0084
       Serial number: 9464GY0D2616712
       Subsystem 2 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
       Serial number: 90349MHQ000ML
                        Fault Frequency: 7
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:31
                        Bin. Bits: 00001101 00000000
                        Bin. Bits: 00000000 00000000
                        Reset counter: 91
                        Mileage: 157080 km
                        Date: 2019.11.06
                        Time: 19:24:06
                        Bin. Bits: 00000000 10000000
       Coding: 010814004001620002080002
       VCID: 49CF5CB989B8669F5E9-801C
    End----------(Elapsed Time: 01:48, VBatt start/end: 11.9V/12.1V)-----------
    HQ
    Any reason why you suspect the ground point for the ABS module? I'm not doubting you, but wondering why you suspect it right away? It is possible that if there is a poor electrical/mechanical connection it would create a voltage drop and that can/will make a module drop off dead... and can be a bit random.
    Jef
    Sep 2019
    Northern Ireland
    Hello Jeff,
    I could wax lyrical about the bathtub effect, random hardware failure rates of electrical components, etc but suffice to say....
    Previous experience in relation to this car but also in connection with my career. Most electronic faults are related to power connection. I know the battery is good. Ground points are the next best thing to check especially if they are in the engine bay exposed to moisture, vibration, chemicals ,etc. but of course anywhere on a vehicle is a pretty harsh environment. After this the plan would be to look for problems with supply connections and finally data lines. Where my knowledge lets me down is in experience with Audi diagnostics reading. I only had an Audi for 2 months now so am hoping that some bright spark on the forum would be able to point me to a particular module location. I know that there is some kind of module at the braking system in the engine bay but am not clear if there are other control modules inside the cab.
    If you (or anyone else) can help point to module location, I at least will have a good starting point....
    Ian
    Sep 2019
    Northern Ireland
    I have still got this intermittent fault. Still remain convinced that it may be related to ground or power to the module. Having a bit of difficulty in locating the ground point for the module. I have traced the wiring loom into the passenger side (RHD) footwell but of course lifting carpet and removing trim is necessary to trace the wiring loom any further.Does anyone in the forum know where the ground point is for this loom?
    Only get to tinker with the car at weekends and am getting frustrated.
    I'm sure it's described in the WD in the RTFB no?
  6. #6
    Sep 2019
    Northern Ireland
    I am afraid I have no idea where to find the 'RTFB' - pretty new to the forum and Audi in general - Can you point me to these Jack? (or someone else...)
    Thanks in advance.
  7. #7
  8. Likes Jack@European_Parts liked this post
