Results 1 to 4 of 4
Thread: New User - Converting Beetle 5c from US to EURO specs
    New User
    Mar 2014
    hi there,
    i am about to convert my beetle to EURO spec, in order to take it back to germany.
    now i am in need of some help from you guys:
    1.) Need a rear fog light
    Already have the EURO light switch, and am about to run the trigger wire to the ECM.
    Need to do the coding for that, anyone an idea. I do have access to a friends VCDS at the moment.
    As an alternative: is it possible to change the rear lights to only one back up light on the right, and use the left back-up light as rear fog? (with a red bulb of course) so i wouldnt need a new reflector for the bumper...
    2.) Need to get the EURO light switch working right
    Currently as the DRL are on, they will turn off, if i switch to parklights. Anyone some ideas about coding?
    Most of the other stuff, like orange indicators will be handled with the original Euro taillights i got on order.
    Would appreciate your help here...
    Wolfgang
    Have you got VCDS? If so, please post an Auto-Scan, thanks!
    New User
    Mar 2014
    Just finished it...
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Tuesday,25,March,2014,19:27:58:42396
    Chassis Type: AT (6R0)
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 77 B9
    VIN: 3VWJL7ATXDM629472
    09-Cent. Elect. -- Status: Sporadic communication error 1000
    B9-Aux. Display -- Status: Malfunction 0010
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 AP    HW: 03L 907 309 AA
       Component: R4 2,0L EDC G000AG  4814
       Revision: 12H15---    Serial number:
       Coding: 0050078
       VCID: 79D73A1E307CCED6DC9-802C
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3524
       Revision: 05551213    Serial number: 00001208011538
       VCID: 24693B6AE77E633EDFF-8071
       Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
       Component: ESP MK60EC1   H31 0156
       Revision: 00H31001
       Coding: E14B401649240003870F02EB921B0042A71000
       VCID: 2E7DD94279B2D96E39B-807B
    Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
       Revision: 00085000    Serial number: 0182705623
       Coding: 030C0C
       ASAM Dataset: EV_KESSYPQ35G A02014
       ROD: EV_KESSYPQ35G.rod
       VCID: 3449CB2A9F9EF3BE4FF-8061
    133124 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:42:20
    1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
              U1093 00 [008] - Short to GND
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:38:04
       Part No SW: 5C0 820 047 BC    HW: 5C0 820 047 BC
       Component: J301  Klimaanlage   0204
       Revision: 2001111S    Serial number: 00000001183802
       VCID: 62E57D72BDEA2D0EED3-8037
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 6R0 937 088 G    HW: 6R0 937 088 A
       Component: BCM PQ25 Re3  H50 0353
       Revision: BT050001    Serial number: 04551241120432
       Coding: 3BBC6918088B080000A82930240D84C5AD82622F60000C51B2E004000000
       VCID: 42A59DF2DD2A4D0ECD3-8017
       Subsystem 1 - Part No SW: 5C5 959 801 M    HW: 5C5 959 801 M
       Component: J386__TSG_FT  011 1032
       Coding: 800000
       Subsystem 2 - Part No SW: 5C5 959 802 P    HW: 5C5 959 802 P
       Component: J387__TSG_BT  011 1032
       Coding: 800000
       Subsystem 3 - Part No SW: 5C0 959 442     HW: 5C0 959 442
       Component: E221__MFL-YVJ  H02 0103
       Coding: E30000
       Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
       Component: AirbagVW10G   013 0851
       Serial number: 003LKM022DXU
       Coding: 00004E45
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 40A197FADB265F1EDB7-8015
       Serial number: 6940000Y120000HTTR0T
       Coding: 30304C
       Serial number: 3572MSME793A056EZZZ4
       Serial number: 3582MSME2841056EZZZY
       Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3556LSME0B645C1CZZZ2
       Crash sensor for front airbag; passenger side:
       Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3566LSME324A5C1CZZZ1
       Part No SW: 5C5 920 970 G    HW: 5C5 920 970 G
       Component: KOMBI         H23 0103
       Revision: X0023005    Serial number:
       Coding: 250E01
       Shop #: WSC 00066 000 00125
       ASAM Dataset: EV_KombiUDSMM9RM10 A04712
       ROD: EV_KombiUDSMM9RM10_SE12.rod
       VCID: 2F43C44676B8D06632D-807A
    Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 E    HW: 1K0 907 951
       Component: J533  Gateway H38 0041
       Revision:   H38       Serial number: 17091203300297
       Coding: 254080
       VCID: 354FF62E9CE4EAB6781-8060
                        Fault Status: 00110100
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:42:21
       Part No SW: 5K0 953 234     HW: 5C5 920 970 G
       Component: IMMO          H23 0103
       Coding: 000007
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_SE36.rod
       VCID: EAF595520DDAF54EA53-80BF
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 12000174969002
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ROD: EV_ELVMarquMPVW36X.rod
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:42:19
    12665089 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:42:20
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662997872
       Coding: 010100
       VCID: 2A75D552455AB54EE53-807F
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 3753FC2646E818A66AD-8062
    Address 56: Radio (J503)       Labels: None
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H03 0005
       Revision: -----07S    Serial number: VWZ4Z6M3428682
       Coding: 01000400040002
       VCID: 256F266E2C449A36C81-8070
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663126577
       Coding: 0A10040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A55E512BDFA05CE953-806F
    Address B9: Aux. Display (J285)       Labels: None
       Part No SW: 5C5 919 527 C    HW: 5C5 919 527 C
       Component: ZUSATZANZEIGE H16 0014
       Coding: 05
       ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001007
       ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
       VCID: 3147C23E608CC696249-8064
    2097173 - Databus
                        Reset counter: 64
                        Mileage: 7481 km
                        Date: 2016.14.30
                        Time: 15:42:19
    Last edited by Uwe; 03-25-2014 at 09:19 PM. Reason: Wrapped CODE tags around Auto-Scan
    New User
    Mar 2014
    any ideas?
