A6 C7 MY2015 09 Cent. Elect. Security Code
Wozik
Unverified
Poland
LP/IP
Folks,
I have a car equipped with RMC, no green menu, no chance to get the control of the ambiente light from the console. However, the level can be adjusted using VCDS. Then the security code is needed to do the adaptation.
How can I get this code for my car? Or maybe somebody already found out how to get the control option to RMC console?
Please post an Auto-Scan so people can see exactly how your car is equipped.
Wozik
Unverified
Poland
LP/IP
Here's my auto scan result:
Monday,02,December,2019,18:21:51:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
License Plate:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 34 3B 42 44 46 52 53 5F 62
          6D 72 85 8B 8E 8F 90 AC
Mileage: 256770km-159549miles
Address 01: Engine (J623-CRTE)       Labels: None
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0001
   Revision: 92H33---
   Coding: 32254012056609030000
   ASAM Dataset: EV_EC3M0TDI0114G2907311C 001001
   ROD: N/A
   VCID: 25462AD6247A4669BA-8070
No ASAM data for: "EV_EC3M0TDI0114G2907311C" (AU57)
9645 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 256663 km
                    Date: 2019.11.28
                    Time: 17:56:34
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G0 927 166 G    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0002
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501012 001021
   ROD: N/A
   VCID: 316ECE8660B21AC956-8064
No ASAM data for: "EV_TCMDL501012" (AU57)
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 27A6DE4DE4657BB29B00
   ASAM Dataset: EV_ESP9BOSHCAU57X 003019
   ROD: N/A
   VCID: 3F8A98BEA6E6FCB9D0-806A
No ASAM data for: "EV_ESP9BOSHCAU57X" (AU57)
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A9700E000000000000
   VCID: 7AFC29AAF5441991A7-802E
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 18111400110457
   Coding: 360211082D0000
   ASAM Dataset: EV_AriCondiBasisUDS 003009
   ROD: N/A
   VCID: 61CE7EC670D2EA4986-8034
No ASAM data for: "EV_AriCondiBasisUDS" (AU57)
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00000949348001
   Coding: 2600001401349FE28981408300001D0C4F9C47082609020100000420610117020040002C030000
   VCID: 71EE0E86A8325AC916-8024
   Component: WWS57X 141109  H37 0080
   Serial number:         141114120242
   Coding: 0045F7
   Serial number: 23481868
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 17 11 2014  00000868
   Serial number: AF188957000000000001
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7804010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 295E26E6486262099E-807C
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] -  -
                    Fault Frequency: 81
                    Reset counter: 96
                    Mileage: 256647 km
                    Date: 2019.11.27
                    Time: 13:15:25
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.579 V
                    Velocity_vehicle_reference: -0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002A110
   Coding: 30333130313930313830554A304C34473053
   ASAM Dataset: EV_AirabAU10BPAAU64X 001014
   ROD: N/A
   VCID: 3B72ECAEB2FEE099FC-806E
   Subsystem 1 - Serial number: 3575HRB405V2QRBI7O4J
   Subsystem 2 - Serial number: 3585HRB40572ORMG9OST
   Subsystem 3 - Serial number: 3515JRB405R31R1QH07H
   Subsystem 4 - Serial number: 3525JRB405T31R1QA039
   Subsystem 5 - Serial number: 3554VRB405D332528068
   Subsystem 6 - Serial number: 3564VRB405D33252AH3P
No ASAM data for: "EV_AirabAU10BPAAU64X" (AU57)
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372NKG0000H
   Coding: 00001D
   VCID: 377AF09E86D6C4F918-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 28 10 2014  F0086450
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G9 920 950 T    HW: 4G9 920 950 T
   Component: TDieRdwAccNv  H07 0043
   Revision: 03001036    Serial number: 658131114592064
   Coding: 138F22081F410008030600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 418E9E46D0128A49A6-8014
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001532645
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUSD 001024
   ROD: N/A
   VCID: 73E2048EDA2E68D9E4-8026
   Serial number: 3604984903
No ASAM data for: "EV_GatewPkoUSD" (AU57)
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6AC8FE76860C3940-807A
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208J9SP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_VW51.rod
   VCID: 3664FD9A89DC3DF103-8062
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011E17014000628002080003
   VCID: 45868A56CC3AA6699A-8010
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0009189074
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3362C48E9AAE28D924-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0352441589
   Coding: 0100063820B93014832009040E010F470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO33651091
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO33651394
   Coding: 801F00
   Coding: 011E17014400628002080002
   VCID: 46848D5AF13CAD7193-8012
   Revision: --------    Serial number: 00000001275704
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2D56D2F67C8A7E2972-8078
   Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 0100050001715B674C2B060301010000000000
   VCID: 224C31CA3D54B151DF-8076
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464J40E2689441
   Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349NK60011T
            000 -  -  - Intermittent
                    Reset counter: 95
                    Mileage: 256754 km
                    Date: 2019.12.02
                    Time: 15:41:22
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00100011
                    Reset counter: 91
                    Mileage: 256660 km
                    Date: 2019.11.28
                    Time: 11:38:15
                    Voltage: 12.30 V
   Coding: 010E15004000628002080002
   VCID: 499E8666E02242097E-801C
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 322400411
   Coding: 093205C010
   ASAM Dataset: EV_HDGSAu572 001022
   ROD: N/A
No ASAM data for: "EV_HDGSAu572" (AU57)
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: EA040000
   ASAM Dataset: EV_OnBoardCamerPDC 001007
   ROD: N/A
   VCID: 2C50DFF24790772165-8078
No ASAM data for: "EV_OnBoardCamerPDC" (AU57)
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7804010202
   ASAM Dataset: EV_AdaptCrusiContr2AU57X 002012
   ROD: N/A
   VCID: 275A20DE5E76547988-8072
No ASAM data for: "EV_AdaptCrusiContr2AU57X" (AU57)
Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621011147
   Coding: 04808A181211
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326CC18A65B421D12F-8066
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 143060210
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B52DCEE429E70196C-807E
End-------------------------(Elapsed Time: 05:16)--------------------------
One more try in progress...
