Results 1 to 4 of 4
Thread: A6 C7 MY2015 09 Cent. Elect. Security Code
    Unverified
    Nov 2019
    Folks,
    I have a car equipped with RMC, no green menu, no chance to get the control of the ambiente light from the console. However, the level can be adjusted using VCDS. Then the security code is needed to do the adaptation.
    How can I get this code for my car? Or maybe somebody already found out how to get the control option to RMC console?
    Please post an Auto-Scan so people can see exactly how your car is equipped.
    Unverified
    Nov 2019
    Here's my auto scan result:
    Monday,02,December,2019,18:21:51:39744
    VCDS Version: 17.1.3.0 (x64)
    License Plate:
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 34 3B 42 44 46 52 53 5F 62
              6D 72 85 8B 8E 8F 90 AC
    Mileage: 256770km-159549miles
    Address 01: Engine (J623-CRTE)       Labels: None
       Part No SW: 4G2 907 311 C    HW: 4G2 907 401
       Component: 3.0TDI EDC17  H33 0001
       Revision: 92H33---
       Coding: 32254012056609030000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_EC3M0TDI0114G2907311C 001001
       ROD: N/A
       VCID: 25462AD6247A4669BA-8070
    No ASAM data for: "EV_EC3M0TDI0114G2907311C" (AU57)
    9645 - ROD - Unknown Error Code
              - 00 [032]
                        Mileage: 256663 km
                        Date: 2019.11.28
                        Time: 17:56:34
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 4G0 927 166 G    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0002
       Revision: --H03---
       Coding: 100001
       ASAM Dataset: EV_TCMDL501012 001021
       ROD: N/A
       VCID: 316ECE8660B21AC956-8064
    No ASAM data for: "EV_TCMDL501012" (AU57)
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 27A6DE4DE4657BB29B00
       ASAM Dataset: EV_ESP9BOSHCAU57X 003019
       ROD: N/A
       VCID: 3F8A98BEA6E6FCB9D0-806A
    No ASAM data for: "EV_ESP9BOSHCAU57X" (AU57)
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A9700E000000000000
       VCID: 7AFC29AAF5441991A7-802E
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 18111400110457
       Coding: 360211082D0000
       ASAM Dataset: EV_AriCondiBasisUDS 003009
       ROD: N/A
       VCID: 61CE7EC670D2EA4986-8034
    No ASAM data for: "EV_AriCondiBasisUDS" (AU57)
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00000949348001
       Coding: 2600001401349FE28981408300001D0C4F9C47082609020100000420610117020040002C030000
       VCID: 71EE0E86A8325AC916-8024
       Component: WWS57X 141109  H37 0080
       Serial number:         141114120242
       Coding: 0045F7
       Serial number: 23481868
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 17 11 2014  00000868
       Serial number: AF188957000000000001
    Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
       Component: ACC3          H21 0053
       Coding: 7804010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       VCID: 295E26E6486262099E-807C
    12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] -  -
                        Fault Frequency: 81
                        Reset counter: 96
                        Mileage: 256647 km
                        Date: 2019.11.27
                        Time: 13:15:25
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 14.579 V
                        Velocity_vehicle_reference: -0.00 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Revision: --------    Serial number: 003P1002A110
       Coding: 30333130313930313830554A304C34473053
       ASAM Dataset: EV_AirabAU10BPAAU64X 001014
       ROD: N/A
       VCID: 3B72ECAEB2FEE099FC-806E
       Subsystem 1 - Serial number: 3575HRB405V2QRBI7O4J
       Subsystem 2 - Serial number: 3585HRB40572ORMG9OST
       Subsystem 3 - Serial number: 3515JRB405R31R1QH07H
       Subsystem 4 - Serial number: 3525JRB405T31R1QA039
       Subsystem 5 - Serial number: 3554VRB405D332528068
       Subsystem 6 - Serial number: 3564VRB405D33252AH3P
    No ASAM data for: "EV_AirabAU10BPAAU64X" (AU57)
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Revision: --------    Serial number: 90372NKG0000H
       Coding: 00001D
       VCID: 377AF09E86D6C4F918-8062
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 28 10 2014  F0086450
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G9 920 950 T    HW: 4G9 920 950 T
       Component: TDieRdwAccNv  H07 0043
       Revision: 03001036    Serial number: 658131114592064
       Coding: 138F22081F410008030600
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       VCID: 418E9E46D0128A49A6-8014
       Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001532645
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUSD 001024
       ROD: N/A
       VCID: 73E2048EDA2E68D9E4-8026
       Serial number: 3604984903
    No ASAM data for: "EV_GatewPkoUSD" (AU57)
    Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F6AC8FE76860C3940-807A
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8208J9SP
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2_VW51.rod
       VCID: 3664FD9A89DC3DF103-8062
       Component: TSG FA        H04 0507
       Coding: 011E17014000628002080003
       VCID: 45868A56CC3AA6699A-8010
    Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0009189074
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 3362C48E9AAE28D924-8066
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0352441589
       Coding: 0100063820B93014832009040E010F470000000000000000000000000000
       Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:     WOO33651091
       Coding: 901F00
       Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     WOO33651394
       Coding: 801F00
       Coding: 011E17014400628002080002
       VCID: 46848D5AF13CAD7193-8012
       Revision: --------    Serial number: 00000001275704
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2D56D2F67C8A7E2972-8078
       Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
       Component: RMC Cnct Nav  H61 0139
       Coding: 0100050001715B674C2B060301010000000000
       VCID: 224C31CA3D54B151DF-8076
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464J40E2689441
       Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
       Serial number: 90349NK60011T
                000 -  -  - Intermittent
                        Reset counter: 95
                        Mileage: 256754 km
                        Date: 2019.12.02
                        Time: 15:41:22
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
    03787 - Rotation Mechanism for Display Module Front
                        Fault Status: 00100011
                        Reset counter: 91
                        Mileage: 256660 km
                        Date: 2019.11.28
                        Time: 11:38:15
                        Voltage: 12.30 V
       Coding: 010E15004000628002080002
       VCID: 499E8666E02242097E-801C
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0150
       Revision: 14005001    Serial number: 322400411
       Coding: 093205C010
       ASAM Dataset: EV_HDGSAu572 001022
       ROD: N/A
    No ASAM data for: "EV_HDGSAu572" (AU57)
    Address 85: On Board Cam. (J852)       Labels: None
       Component: DPC-SG        H27 0081
       Coding: EA040000
       ASAM Dataset: EV_OnBoardCamerPDC 001007
       ROD: N/A
       VCID: 2C50DFF24790772165-8078
    No ASAM data for: "EV_OnBoardCamerPDC" (AU57)
    Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
       Coding: 7804010202
       ASAM Dataset: EV_AdaptCrusiContr2AU57X 002012
       ROD: N/A
       VCID: 275A20DE5E76547988-8072
    No ASAM data for: "EV_AdaptCrusiContr2AU57X" (AU57)
    Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
       Component: BV-SG         H33 0090
       Serial number: 005000621011147
       Coding: 04808A181211
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 00660600031F0376000308014248D2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326CC18A65B421D12F-8066
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0010
       Revision: 00000000    Serial number: 143060210
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B52DCEE429E70196C-807E
    End-------------------------(Elapsed Time: 05:16)--------------------------
    Quote Originally Posted by Wozik View Post
    One more try in progress...
  5. Likes PetrolDave liked this post
