Results 1 to 5 of 5
Thread: VW Touareg 2018 vcds
    Nov 2019
    Australia
    Hi from Australia.
    is there any way to disable drivers door open Chime.TOUAREG 2018.
    This option is not available in 2018
    Turn off "ignition on" chime
    1. Control Module 17
    2. Adaptations
    3. Ignition Active Message, Actuator: Driver Door -> No Display
    Thanks rlteck
    Tuesday,26,November,2019,13:23:14:39348
    VIN: WVGZZZ7PZJD016783   License Plate: 1G0E
    Mileage: 14630km-9090mi   Repair Order:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 34 36 42 46 52 53 55 56
              5F 62 69 6C 6D 72
    VIN: WVGZZZ7PZJD016783   Mileage: 14630km-9090miles
    Address 01: Engine (J623-CRCA)       Labels: None
       Part No SW: 7P1 907 401 D    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H41 0001
       Revision: 53H41---
       Coding: 292A4012233E01020000
       Shop #: WSC 40556 002 1048576
       ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
       ROD: EV_ECM30TDI0117P1907401D.rod
       VCID: 313F152F41A0C1CF769-8064
    Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
       Part No SW: 0C8 927 755 M    HW: 0C8 927 755
       Component: 34O06G0Q.MOT  130 3073
       Coding: 010100011C008400000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 3B23370793EC3B9FDC5-806E
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 42457446686892
       Coding: 5B6B13C34B252559DAFBC89BD2D5A470F701
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4CC164DBC6428C2765F-8018
       Part No SW: 4H0 907 064 JM    HW: 4H0 907 064 JM
       Component: BCM2 2.0      H44 0582
       Coding: 05B60016000000000000
       VCID: 7DA7F91FCDF8F5AFA21-8028
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 3218000021224010
       Component: MEM-BFS       H08 0156
       Revision: AA000000    Serial number: 00000306008661
       Coding: 0038330000004201000001010101202020202121202020
       VCID: 34311C3BBE32F4E71DF-8060
       Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
       Component: Klima 2 Zonen H23 1608
       Coding: 3626200E90
       VCID: 065596F398AEB677F3B-8052
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 2202007S    Serial number: 00001925032902
       Coding: 26000015D0345D010029400780005D4C431D670827010241800000000040110000000000000000
       Shop #: WSC 12345 123 61029
       VCID: 6A8DC243AC767217773-803E
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
       Component: WWS    171103  033 0021
       Serial number: 90243401171117072221
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 81193411
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
       Component: E1 - LDS  H02 0040
       Serial number: 00000000002002180231
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA130580000043561172
       Coding: 020300
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28261805902392
       Coding: 518504
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 44D14CFBEE124467ADF-8010
       Part No SW: 7P0 959 655 G    HW: 7P0 959 655 G
       Component: VW10Airbag00T H11 0048
       Revision: --------    Serial number: 003TU004BCFI
       Coding: 000000000000000000000000000000003054
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       VCID: 45D751FFE5287D6FBA1-8010
       Serial number: 3575LRB40145DLTMF1Q5
       Serial number: 3585LRB40185DLTMGP09
       Serial number: 3517ARB404R56MM4NORH
       Serial number: 3527ARB405B57114B1L7
       Serial number: 3557BRB406556KBSJ0VW
       Serial number: 3567BRB406556KBSA98A
       Part No SW: 4H0 953 568 P    HW: 7P6 953 507 AL
       Component: Lenks.Modul   H06 0010
       Revision: C0077960    Serial number: 91560RBL0001Y
       Coding: 000015
       VCID: 40D940EBFA8A5847897-8014
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H05 0028
       Serial number: 0093265 TRW 20180214
       Part No SW: 7P6 920 883 L    HW: 7P6 920 883 L
       Component: Kombi         H15 0607
       Revision: 16240316    Serial number: 658270218592022
       Coding: 233533003A00000801000C
       ASAM Dataset: EV_KombiUDSRBVW526 001030
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 47CB5BF7DF246F7F48D-8012
       Part No SW: 7P6 907 530 Q    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H15 6055
       Revision: --------    Serial number: 00000002905356
       Coding: 000D07AD00
       ASAM Dataset: EV_GatewVW526UDS 001008
       ROD: EV_GatewUDS_VW52.rod
       VCID: 46D556F3D82E7677B3B-8012
       Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
       Component: Batt_Sensor  H07 0270
       Serial number: 44228I51245811861861
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
       Serial number: 18045001997021200181
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 AH    HW: 7P0 907 553 AH
       Component: PASM          H05 0960
       Revision: 00000000    Serial number: 00000180270332
       Coding: 14210000
       ASAM Dataset: EV_PASMConti 001005
       ROD: EV_PASMConti.rod
       VCID: 7DA7F91FCD78F5AFA21-8028
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000305992207
       Coding: 00383B0000004201000001010101202020202121202020
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H03 0306
       Revision: --------    Serial number: 0000297954368
       Coding: 011D1620DE01451205080002
       VCID: 7AADF203DCD6C297873-802E
       Revision: 00002001    Serial number: 0473143341
       Coding: 019B1E20A8B9108183200624210000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 172
       Component: Sensor, DWA  005 0502
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H03 0306
       Revision: --------    Serial number: 0000305273542
       Coding: 011D1620DE01451205080000
       VCID: 48C958CBD2BA6007417-801C
       Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1820600820
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 372B2B37AFC41FFF38D-8062
       Slave 3:
       Component: AFS-ECU       H01 0120
       Coding: 01A602000B000200
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       VCID: 3FDB431787F427BFF0D-806A
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0006
       Coding: B00000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0006
       Coding: B00000
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227BX0J5057413
       Coding: 040005020100000003
       VCID: 2615F67378EE967793B-8072
       Part No SW: 7P6 035 764 N    HW: 7P6 035 764 A
       Component: H-BNT-RW      H43 1062
       Revision: --------    Serial number: 605BW0J7515510
       Coding: 010A01050040C1EF41000B0E00000003F00001030000000000
       VCID: 44D14CFBEE924467ADF-8010
       Subsystem 1 - Part No: 8R0 060 884 EG
       Component: ROW 2017  0905
       Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9VGF025TZ
       Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
       Component: CD-Database  9040
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H04 0306
       Revision: --------    Serial number: 0000306183593
       Coding: 011814200001251005080000
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
       Component: Anhaenger     H20 0160
       Revision: 7C001003    Serial number: 0429917806
       Coding: 0300000202000000
       ROD: EV_TrailFunctGener2Hella_VW52.rod
    Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
       Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
       Component: TopView       H09 0115
       Revision: 11001001    Serial number: 82330JG0476771
       Coding: 0100000001000000010102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001014
       ROD: EV_CamerSysteTopViewVW.rod
       VCID: 3D27391F8DF835AFE21-8068
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010003    Serial number: 044800095
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H04 0306
       Revision: --------    Serial number: 0000306195360
    End----------(Elapsed Time: 01:56, VBatt start/end: 12.2V/12.1V)-----------
    Hi and welcome.
    I don't see an obvious way to accomplish that.
    Where did you find the instructions you're trying to follow?
    Gonna move this to the Tweaks section.
    Hah! A Touareg is nothing like a Golf.
    The systems in the original 7L Touaregs were similar to the Phaeton and several Bentley models of the period.
    The systems in the 7P Touareg like yours are similar to the Audi A6/A8 of the time.
    Nov 2019
    Australia
    Made a few changes,
    Seatbelt Chime,Green Screen,
    Enable Video In Motion,
    disable Stop-Start,
    daylight lights.
    But haven't find any codes for drivers door open chime.
    Thanks for that.
