- Joined
- Jul 6, 2019
- Messages
- 7
- Reaction score
- 2
- Location
- Sheffield, UK
- VCDS Serial number
- C?ID=222374
could someone please provide me qith coding for this ABS module
Thursday,28,November,2019,16:22:44:06187
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZBP313347 License Plate: AV61 ZNL
Mileage: 185380km-115189mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 61 62
72 77
VIN: WVWZZZ3CZBP313347 Mileage: 185380km-115189miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BF HW: 03L 907 309 N
Component: R4 2.0l TDI H24 9978
Revision: 47H24--- Serial number: VWZCZ000000000
Coding: 00190032042501080000
Shop #: WSC 51773 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
ROD: EV_ECM20TDI01103L906018BF.rod
VCID: 6FBB2F89771C8ECF20D-803A
4815 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [167] - -
[Software Incompatibility with Anti-Lockplease read DTC]
Mileage: 185377 km
Date: 2019.11.28
Time: 01:35:24
Coolant temperature: 75 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.660 V
Requested transmission torque: 1000.0 Nm
Limitation: accelerator pedal: 126.7 Nm
Cruise Control System (CCS): status-Bits 0-7: 202
selected gear-Bits 0-7: 0
Transmission torque intervention status-Bits 0-7: 0
Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 185377 km
Date: 2019.11.28
Time: 01:35:19
Voltage terminal 30: 12.620 V
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 185377 km
Date: 2019.11.28
Time: 01:35:19
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 3
Status of ACC/CCS acceleration interface-Bits 0-7: 3
Acceleration: 0.000 m/s²
Engine status: COENG_READY
11525 - No Communications with Parking Assist Control Module A
U0159 00 [039] - -
Mileage: 185377 km
Date: 2019.11.28
Time: 01:35:19
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AC HW: 3AA 614 109 AC
Component: J104 C2 450M VDE2 0022
Revision: --H07--- Serial number: 00000004296838
Coding: 0010000
Shop #: WSC 05311 000 00000
VCID: 6E85328D7C9687C72BB-803A
7 Faults Found:
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 216
Hex Value: 0x0000
03201 - Adaptation Overboost
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
00810 - Sensor 1/2 for Brake Pressure
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
01542 - Yaw Rate Sensor (G202)
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004003
Shop #: WSC 00015 115 00000
ROD: EV_ACManueBHBVW36X_VW46.rod
VCID: 7F5BFFC9277CFE4FB0D-802A
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
Component: BCM PQ47 H 413 0452
Revision: BB413001
Coding: 000000000000000000180080540081E443516488406C85606480C7200041
Shop #: WSC 00028 028 00001
VCID: 3829D4D542520977317-806C
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 16051 26 0612
Coding: 00B795
Component: RLS 080611 05 54 0403
Coding: 0230ED
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:57:02
Voltage: 12.80 V
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:57:02
Voltage: 12.80 V
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 226
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:38
Voltage: 12.60 V
03384 - Windshield Washer Jet Heating
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:57:03
Voltage: 13.20 V
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__102 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PAXR09+
Coding: 0012338
VCID: 4CC198052ACA95D765F-8018
Subsystem 1 - Serial number: 6332MTS622831301
Subsystem 2 - Serial number: 6342MTS645001301
Subsystem 3 - Serial number: 6351HTS6I1SPT9KJ
Subsystem 4 - Serial number: 6361HTS6371ST9KJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB
Revision: FF010040 Serial number: 20110525301379
Coding: 1182250000
VCID: 76B51AED0846BF07E3B-8022
Component: E221__MFL-TK6 H06 0022
Coding: E20000
1140738 - Steering angle sensor
Reset counter: 225
Mileage: 185377 km
Date: 2019.11.28
Time: 01:35:18
UBat: 12.80 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 970 A HW: 3AA 920 970 A
Component: KOMBI H20 0420
Coding: 460F00
Shop #: WSC 00028 028 00022
VCID: 313FE9F1A1A8D83F769-8064
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 230511F2000979
Coding: 462007
Shop #: WSC 05314 000 00000
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:25
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76B51AED04C6BF07E3B-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660173912
VCID: 290F019189F8A0FFBE9-807C
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0002926261
Coding: 0202B7
Shop #: WSC 05311 115 00000
VCID: 3537DDE155C0F41F2A1-8060
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002205456
Coding: 000290
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 195 3201
Revision: 00H20000
VCID: 3431E0E5523AED171DF-8060
Fault Status: 11100101
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Battery Volts: 12.6 V
DD
Temperature: 22.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Component: KSG PQ47 ELV 043 0631
Coding: 01910A0002860E76300494157C085FCE105C01
Subsystem 1 - Part No: 1K8 951 605 B
Component: LIN BACKUP HORN H11 9005
Component: Neigungssensor 004 0611
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 00000008
VCID: 6FBB2F89779C8ECF20D-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0002933927
Coding: 0202B6
VCID: 3635DAED48C6FF0723B-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002200224
Coding: 000290
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000027053
Coding: 0010000
VCID: 3537DDE15940F41F2A1-8060
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 225
Mileage: 185377 km
Date: 2014.04.20
Time: 01:35:19
Voltage: 12.60 V
Count: 69
Hex Value: 0x1243
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 01110101
Reset counter: 226
Mileage: 185375 km
Date: 2014.04.20
Time: 20:04:46
Voltage: 11.40 V
Count: 99
Hex Value: 0x1243
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 01110000
Reset counter: 226
Mileage: 185375 km
Date: 2014.04.20
Time: 20:04:46
Voltage: 11.40 V
Count: 41
Hex Value: 0x1243
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 226
Mileage: 185375 km
Date: 2014.04.20
Time: 20:04:46
Voltage: 11.40 V
Count: 98
Hex Value: 0x1243
Hex Value: 0x0001
Hex Value: 0x1010
Part No SW: 1K0 035 186 AP HW: 1K0 035 186 AP
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3749304
Coding: 01000400040011
VCID: 74B120E51EBAAD17DDF-8020
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H40 1620
Coding: 030B185A
VCID: 71BF29F161A8983F369-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900626880
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660115318
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 3431E0E55EBAED171DF-8060
End----------(Elapsed Time: 01:30, VBatt start/end: 13.2V/13.3V)-----------
