Results 1 to 5 of 5
Thread: No response from controller
    Mar 2018
    Hi everyone. I have a 2016 Audi A7 US spec car. I recently ran an auto scan (see below) and for some reason, when I go to the Electronic Tabs 1&2, I cannot communicate with the controllers. It says "No response from controller". 2 of the controllers I want to explore are the Radio, and Navigation. Just an FYI, I don't think I ever tried to address these modules before. Also As for the Malfunctions listed, I had a run in with a deer. I believe the damage to the headlight and radar dome are causing these codes.
    I'm using a USB connector interface. Does anyone offer any suggestions ?
    Thursday,28,November,2019,10:57:07:62608
    VIN: WAUWGAFC3GN0XXXX   License Plate:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 52
              53 55 5F 62 6C 6D 72 85 8B 8E 8F 90
    VIN: WAUWGAFC3GN015096   Mileage: 122742km-76268miles
    Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G2 907 551 A    HW: 4H2 907 551 A
       Component: 3.0l V6 TFSI  H10 0004
       Revision: --H10---
       Coding: 1A2A00340566010D3000
       ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
       ROD: EV_ECM30TFS0214G2907551A_002.rod
       VCID: 290F0049C9766B4FBE9-807C
    23044 - Valve for Fuel Metering (N290)
              P0089 00 [096] - Implausible Signal
    15077 - Idle Control System RPM
              P0507 00 [096] - Higher than Expected.
                        Mileage: 114938 km
                        Date: 2019.11.08
                        Time: 10:17:28
                        Engine speed: 1606.00 /min
                        Coolant temperature: 36 °C
                        Intake air temperature: 22 °C
                        Ambient air pressure: 920 mbar
                        Voltage terminal 30: 14.179 V
                        Unlearning counter according OBD: 6
                        Ignition angle of current cylinder: actual value: 7.88 °
                        Throttle valve angle: 5.186 °
                        Charge press.: average: 0.279 bar
                        Secondary air system: status: cancelled
                        Engine torque: 35.21875 Nm
                        Ambient air pressure: 0.926 bar
                        Accelerator position: 0.00 %
       Part No SW: 4G0 927 158 AM    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H19 1002
       Revision: --H19---
       Coding: 000001
       VCID: 79AF100979561BCF8E9-802C
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 44A7964B22E569D21B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FDBBE1127F2F5FFF0D-806A
       Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0560
       Coding: 0DAA6F4E000000000000
       VCID: 7EA5031560F83CF7BBB-802A
       Serial number: 3215000045223013
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 23031500040411
       Coding: 668331B84D0000
       VCID: 63935261EBDAF11FB45-8036
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Revision: 21020001    Serial number: 00001033397502
       Coding: 01050011043C9FE2C100488780007800CF9CC208AE0802218000089C710015020060002D0B0000
       VCID: 76B51B3548C874B7E3B-8022
       Component: WWS57X 150307  H37 0080
       Serial number:         150310091155
       Coding: 0045F7
       Serial number: 23819186
       Coding: 02006E
       Component: E1 - LDS  H07 0044
       Serial number: 10 03 2015  00001897
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01E5BD9A
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA120407000012221144
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: B2A01AC800PAG0MUFU03
    03455 - Function Restriction due to Faults in Other Modules
                        Reset counter: 52
                        Mileage: 119555 km
                        Date: 2019.11.20
                        Time: 17:36:12
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Fault Status: 00101100
                        Reset counter: 59
                        Mileage: 122639 km
                        Date: 2019.11.25
                        Time: 15:00:49
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7E01010201
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
    10240 - Sensor for Automatic Distance Control
              [FAULT_BLR_BLK8_31]
                        Fault Frequency: 39
                        Reset counter: 57
                        Mileage: 111743 km
                        Date: 2019.11.03
                        Time: 09:37:26
                        Control Module temperature: 6 °C
                        Voltage terminal 15: 14.598 V
                        Velocity_vehicle_reference: 34.12 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
    88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] - -
              [FAULT_MAR_SLOW_MISALIGNMENT]
                        Reset counter: 57
                        Mileage: 122009 km
                        Date: 2019.11.23
                        Time: 12:07:01
                        Control Module temperature: 9 °C
                        Voltage terminal 15: 14.360 V
                        Velocity_vehicle_reference: 32.85 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.04 m/s²
    88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] - -
              [FAULT_MAR_FAST_MISALIGNMENT]
                        Reset counter: 57
                        Mileage: 120653 km
                        Date: 2019.11.22
                        Time: 11:21:05
                        Control Module temperature: -2 °C
                        Voltage terminal 15: 14.352 V
                        Velocity_vehicle_reference: 33.29 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
    12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] - -
              [FAULT_MAR_PRE_MISALIGNMENT]
                        Fault Frequency: 46
                        Reset counter: 57
                        Mileage: 120088 km
                        Date: 2019.11.21
                        Time: 15:25:15
                        Control Module temperature: 4 °C
                        Voltage terminal 15: 14.492 V
                        Velocity_vehicle_reference: 36.82 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.02 m/s²
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G000212BZ
       Coding: 303331333131303134354A55304C34473853
       VCID: 3431E13D1EB426A71DF-8060
       Component: BF-Gewichtss.  H11 0046
       Serial number: 6940000Y150001BE5H0L
       Serial number: 3575HRB405134BKO18K4
       Serial number: 3585HRB406933RVKE11N
       Serial number: 3515JRB406736270O0HI
       Serial number: 3525JRB4053346844GOO
       Serial number: 3554VRB405D35IMO1P6/
       Serial number: 3564VRB405D35IMOM1I7
       Revision: --------    Serial number: 90372OCH0004R
       Coding: 0004FC
       VCID: 3829D50D025CC2C7317-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 26 02 2015  E0084774
       Part No SW: 4G8 920 986 A    HW: 4G8 920 986 A
       Component: TBenUsaAcc    H08 0043
       Revision: 04001037    Serial number: 658210315596022
       Coding: 0BCF01060F53D705020100
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3635DB3508C834B723B-8062
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001769306
       Coding: C0CD073010
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75B71C39554E7FAFEA1-8020
       Serial number: 9312886003
       Voltage stabilizer:
       Serial number: 15011000000000000293
       Revision: AA001002
       Coding: 04018E64747464545425363E00
       VCID: 7CA1091D76E42EE795F-8028
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 22031500040003
       Coding: 20
       VCID: 3E25C31520F8FCF7FBB-806A
       Revision: AA000000    Serial number: 00000138614452
       VCID: 77AB16314FC20DBFF8D-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA82097LPN
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0359078765
       Coding: 040211
       VCID: 392FD00939D6DBCFCE9-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0363651604
       Coding: 040211
    733440 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Reset counter: 50
                        Mileage: 113040 km
                        Date: 2019.11.04
                        Time: 12:13:33
    733696 - Control Module 2 for Lane-Change Assist
              C1115 F5 [008] - Limited Visibility
                        Reset counter: 50
                        Mileage: 117990 km
                        Date: 2019.11.17
                        Time: 10:49:20
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F57035E00628002000413
       VCID: 45D7ACF945AEAF2FBA1-8010
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0014616076
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0364125417
       Coding: 0126063A20BAF08582B00A0402030D470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000282073
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST0007BONT00000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA120473000012380672
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93466428
       Coding: 011F57035E00628002000402
       VCID: 46D5ABF578A8A437B3B-8012
       Revision: --------    Serial number: 00000001398756
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D07F459FD9E776F521-8078
       Coding: 05FA021122600400
       Coding: E02000
       Coding: E02000
    5538320 - Bulb for High Beam Headlamp Right
              B121A 01 [008] - Electrical Failure
                        Reset counter: 52
                        Mileage: 119555 km
                        Date: 2019.11.20
                        Time: 17:36:08
    5538322 - Temperature Sensor for Right High Beam
              C1170 01 [008] - Electrical Failure
                        Fault Frequency: 14
                        Reset counter: 54
                        Mileage: 119790 km
                        Date: 2019.11.21
                        Time: 12:03:42
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 025     HW: 4G1 035 025
       Component: MU-H-LNS-US   040 0143
       Serial number: A278C0FB011150
       Coding: 01750302FF0A000013220001041A00102F000CE5F1700104FE
       VCID: 5BE36A81D3AAC9DFFC5-800E
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Component: DU8 C7 SV  H63 0006
       Serial number: AUZ8Z9EY800SZ6
       Multimedia Operating Unit:
       Serial number: 90349OCG0010H
       Component: Gracenote2  --- 3006
       Coding: 010F17024000628002000002
       VCID: 49CFA0C969B64B4F5E9-801C
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0214131
       Coding: 0216000001010100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2E05F355F0980C776BB-807A
       Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
       Component: HDSG-Modul    H14 0049
       Revision: 12014001    Serial number: 065501757
       Coding: 0A3305C122
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 46D5ABF57828A437B3B-8012
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F95DC6847E6745F-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E01010201
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270B0671DF625D3FA8D-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000621703157
       Coding: 03C1B8180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE829E1A6138F769-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323DE725E4A028970F3-8066
    End----------(Elapsed Time: 02:22, VBatt start/end: 12.2V/12.2V)-----------
    Look at the Installation List (at the top of the Auto-Scan) that shows all the controller that exist in the car, trying to access any other controller won't work as it doesn't exist!
    BTW radio and navigation are now both handled by the 5F Infotainment module
  3. Likes Jack@European_Parts, Uwe liked this post
    Mar 2018
    Hi PetrolDave,
    Thanks for getting back to me and clearing this matter up and also showing me the correct way to include an auto-scan.
    The reason I'm looking to explore the Nav. module is because my maps need updating. My dealer wants approx. $600 to install the new activation code and the new North American maps. That just seems wrong. I've been told that I can actually purchase the key code but not sure if I can access where to update the activation code. Any ideas on this?
    Quote Originally Posted by bobst1100 View Post
    Can't help you with that - my Skoda map update is just a case of downloading the new maps from either the VW or Skoda website and unzipping it onto an SD card, but my previous Audi required a new DVD every year at a cost of around $300.
    Mar 2018
    I understand. Thanks for your help!
