Results 1 to 9 of 9
Thread: VW Golf 7R DQ500 RS3 - Haldex RS3 install
    Oct 2018
    Romania
    Hope my message finds you well!
    I own a 2015 VW Golf 7R with a DQ500 RS3 gearbox conversion.
    Today I have installed the RS3 Haldex to match the DQ500 RS3 gearbox.
    After the install, the car appears to drive OK at first review. Will check more details later.
    But I noticed that I am currently encountering the following error codes on the AWD module, after installing it, and they won't go away.
    As always, any advice is more than welcome and I thank each and everybody for your time and help!
    They are really appreciated.
    Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
    Component: Haldex4Motion H52 7755
    Serial number: HA1-00019.12.15
    Coding: 0701
    Shop #: WSC 06745 128 28888
    VCID: 45D45899C5299DAFBA1-8010
    17502 - Databus
    [Bremsensteuergerät - TO -- ESP_18]
    Reset counter: 236
    Mileage: 143478 km
    Date: 2019.11.28
    Time: 11:28:51
    17503 - Databus
    [Bremsensteuergerät - TO -- ESP_23]
    Reset counter: 236
    Mileage: 143478 km
    Date: 2019.11.28
    Time: 11:28:51
    17504 - Databus
    [Bremsensteuergerät - TO -- ESP_29]
    Reset counter: 236
    Mileage: 143478 km
    Date: 2019.11.28
    Time: 11:28:51
    Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
    Component: ESC H42 0723
    Revision: 00000000 Serial number: 62155000001290
    Coding: 01FA6BA15420296D077E070541CA6980D62A94E0E08296F718 4250F8C288
    Shop #: WSC 47196 003 1048576
    VCID: 7AAEFB65FC572257873-802E
    Jun 2017
    Before digging into ABS coding, have you tried other codings for AWD?
    0601 or 0001 ?
    Oct 2018
    Romania
    0601 or 0001 ?
    No, I did not try any codings yet.
    I just installed it on the car.
    I looked at the coding previously on my car and it was 0001. With the old Golf Haldex.
    Please see below:
    Serial number: HA1-00010.01.17
    Coding: 0001
    VCID: 4ACE6BA5EC3772D7573-801E
    Do you think this could be the culprit?
    Oct 2018
    Romania
    0601 or 0001 ?
    Fast update. Tried to update the codings to either one of 0001, 0601 or 0701. All give the same three already indicated error messages.
    Jun 2017
    Okay.
    Honestly I have no clue....
    No other people that did the same retrofit?
  6. #6
    Oct 2018
    Romania
    Okay.
    I do not know. I will look around more.
    After last night checks I noticed that it works perfectly. But have these three error messages.
  7. #7
    Looks to me like the firmware in the RS3 AWD module is expecting extra messages?
  8. #8
    Oct 2018
    Romania
    Exactly my thoughts. And I know that the Golf 7 Haldex works with 7V and 9A current. The RS3 with 9V and 11A current. I currently have recorded 7.2 V and 8.9 A. So it still treats it like a Golf Haldex. I have performed basic settings of the Haldex Pump. Will test again.
    If it still works like this i believe i can safely ignore the errors or switch back to the old Golf Haldex controller on this RS3 Haldex. That should work also.
  9. #9
    Oct 2019
    Ottawa, Canada
    I didnt think there was a difference between the 2 haldex units
