2005 Audi TT 8N
Kim Mundy-Castle
St. Kitts
C?ID=380151
Problem with performing the Brake Pressure Sensor 1 (G201) procedure to activate basic settings, parameters read Group 066 Error Not Available:banghead:
Tuesday,26,November,2019,13:04:37:36149
VIN: TRUZZZ8NX51012214   License Plate: PB2335
Mileage: 87460km-54345mi   Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUZZZ8NX51012214   Mileage: 87460km-54345miles
Address 01: Engine        Labels: 06A-906-032-AJQ.clb
   Part No: 8N0 906 018 CN
   Component: 1.8L R4/5VT         0010
   Coding: 11570
   Shop #: WSC 01236
   VCID: 7F5B03338EE5AFAFB0D-513C
   TRUZZZ8NX51012214     AUZ5Z0DN246008
   Part No: 09G 927 750 CA
   Component: AQ 250 6F           0622
   Coding: 0008200
   Shop #: WSC 01236 785 00200
   VCID: 72BDDA07C8B7F2C7CF3-513C
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-F.lbl
   Part No: 8N0 907 379 J
   Coding: 0019473
   VCID: 43D34FC3A78D0B4F945-513C
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00241
   Shop #: WSC 01236
   VCID: 2809F86F3BEBC817A17-2578
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 D
   Component: Airbag Front+Seite 1000
   Coding: 00102
   Shop #: WSC 01236
   VCID: 41DF45CBB891195F869-513C
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N2 920 930 G
   Component: KOMBI+WEGFAHRS. M73 D09
   Coding: 06844
   VCID: 36352617E15FAEE723B-4B00
01304 - Radio
            49-00 - No Communications
            37-00 - Faulty
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N8 962 267 F
   Component: Central Lock        D09
   Coding: 06848
   Shop #: WSC 01236
   VCID: 44D14CDFA7830C77ADF-4F0C
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00009
   Shop #: WSC 01236
   VCID: 6597B15B0C79157F5A1-5160
End----(Elapsed Time: 02:53, VBatt start/end: 12.0V/12.1V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 03: DTCs cleared
Are you following this procedure?
What do you have in MVB 005.1 at the start?
Kim Mundy-Castle
St. Kitts
C?ID=380151
yes that's the procedure I'm following
MVB 005.1 +13.6 was hoping activate basic setting would correct this but guessing now bad sensor is causing this error
