Results 1 to 2 of 2
Thread: 2014 Touareg tdi Radio
    Mar 2014
    anyone know how to fix this i'm guessing software issue. thanks in advance
     uesday,26,November,2019,18:25:18:52565
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEP9BP4ED009215   Mileage: 207239km-128772miles
    17-Instruments -- Status: Cannot be reached 0100
    56-Radio -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
       Component: 3.0TDI FSA    H21 0011
       Revision: 56H21---
       Coding: 292A4012233600050000
       Shop #: WSC 19419 444 00000
       ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
       ROD: EV_ECM30TDI0117P0907401K.rod
       VCID: 372B285A6FC151EF38D-8062
    9567 - NOx Sensor 2 Bank 1
              P229F 00 [096] - Implausible Signal
    9952 - Catalyst System; Bank 1
              P0420 00 [096] - Efficiency Below Threshold
    17277 - SCR NOx Catalyst Bank 1
              P20EE 00 [096] - Efficiency too Low
       Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
       Component: AL1000 AISIN  002 3376
       Coding: 001368
       Shop #: WSC 50400 002 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 72BDD94E4423F4C7CF3-8026
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
       Component: MK25A         H36 0446
       Revision: --------    Serial number: 434030010EC818
       Coding: 5B7613C34924255CDAF6C89492D7A4407300
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 4ACD61AE0C33DC07573-801E
       Part No SW: 4H0 907 064 EK    HW: 4H0 907 064 EK
       Component: BCM2 2.0      H36 0521
       Coding: 0D860016000000000000
       VCID: 76B5E55E28CBE8E7E3B-8022
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 0213000391586008
    00956 - Key 2
                        Reset counter: 218
                        Mileage: 202700 km
                        Date: 2019.06.26
                        Time: 10:06:51
       Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
       Component: Klima 2 Zonen H21 1306
       Coding: B606200A80
       VCID: 0557929265ADF37FFA1-8050
       Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000001510600
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 6C81C7366687223705F-8038
       Component: WWS    131229  033 0021
       Serial number: 90243400140103094310
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20242436
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000002401140303
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R9F3303
                        Reset counter: 32
                        Mileage: 176603 km
                        Date: 2018.06.22
                        Time: 20:57:00
       Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
       Component: VW10Airbag06X H06 0026
       Revision: --------    Serial number: 003L50041YZH
       Coding: 000000000000000000000000000000003658
       VCID: 42DD498E340304479F3-8016
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R13A040EMPK
       Serial number: 3575LRB405B2ATKE48S%
       Serial number: 3585LRB404V2ATKE99QN
       Serial number: 3515RRB400250QLSD27F
       Serial number: 3525RRB400K50QLSCPJP
       Serial number: 3555NRB400G50P7ENHU5
       Serial number: 3565NRB400G50P7EGPDX
       Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
       Revision: --------    Serial number: 99999MK7000QH
       Coding: 000015
       VCID: 3635255E684BA8E723B-8062
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H04 0028
       Serial number: 0030690 TRW 20131206
       Part No SW: 7P6 920 982 L    HW: 7P6 920 982 L
       Component: Kombi         H13 0419
       Revision: 13240270    Serial number: 658140114592056
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001020
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 47CB589A1F21216F48D-8012
       Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6032
       Revision: --------    Serial number: 00000001241907
       Coding: 000103AD00
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3FDB407A47F169AFF0D-806A
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 41008I05045701628007
    0269 - Optical data bus
              U104A 00 [008] - No Communication
                        Fault Frequency: 18
                        Reset counter: 252
                        Mileage: 206965 km
                        Date: 2019.11.24
                        Time: 14:43:01
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 7 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
       Revision: AA000000    Serial number: 00000085728411
       Coding: 00581B0000004001000001010101202020202121202020
       VCID: 34311F567E37BAF71DF-8060
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000088489831
       Coding: 011D17205E00453005080000
       VCID: 7AADF16E1CD38C87873-802E
       Revision: 00002001    Serial number: 0324290655
       Coding: 0186123A68B9509580A00620210A08000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 0091421358
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO26327150
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO2615112Z
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93115108
    00230 - Transmission Park Selector Switch (F305)
                        Reset counter: 251
                        Mileage: 207203 km
                        Date: 2019.11.26
                        Time: 14:35:29
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000088951543
       VCID: 48C95BA612BF2E17417-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1410400156
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 3635255E68CBA8E723B-8062
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 010A00010F000400
       VCID: 7CA1F7761667B2B795F-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0003
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0003
       Coding: 130000
    Address 56: Radio
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000088703921
       Coding: 011817200000253005080000
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000123475
       ROD: EV_RDKBERU25_VW52.rod
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H11 0110
       Revision: 5A001001    Serial number: 00000321362182
       Coding: 020D000000000000
       VCID: 3B23346A5369758FDC5-806E
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H08000    Serial number: 525 PA8J3Z1157
       Coding: 0110001
       VCID: 372B285A634151EF38D-8062
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 350300653
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000088694324
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.1V)-----------
    16.4905° S, 151.7375° W
    Address 56: Radio
    That is weird, the [17-Instruments] says it could not be reached? but it looks okay in the Auto-Scan?
    This maybe more than a software issue, you could pull the radio to totally disconnect it for 30 minutes or so and the re connect to see if that resets the radio.
    Added: I did see there were some internet posts out there that do talk about a software update, so maybe it is possible to recover with a disc or SD card update?
    Hope that helps,
    drpeter
  3. Likes Uwe, HMFIC liked this post
