First post here so I'm excited to join the community! I recently purchased a 2009 Touareg v8 that came with an RNS510 head unit. I purchased Eurozone Tuning's 9w7 bluetooth retrofit kit with module P/N 7P6035730F. Once installed, I am able to pair to my phone and stream audio, as well as view my phone book from the main screen. The issue is, there is no song information on the main screen, or in the MFD display as well as no phone page on the MFD. Pairing phones is also strange and there's no graphical way to do it. I added the telephone module to the gateway install list and upon trying to code the telephone module (77) I receive a "no response from controller" error. Some other threads have suggested an incompatibility with this module and the CAN/diagnostics bus on the T1/T2 Touareg. Can anyone confirm this? If so, is there a better module part number I should be picking up?
Here's a full scan if it's helpful.
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2E 32 34 36 37 3C 46 47
          55 56 65 68 69 6C 6D 6E 76 77
37-Navigation -- Status: Malfunction 1010
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (   )       Labels:. 079-907-560-BAR.clb
   Part No SW: 7L0 907 560 G    HW: 7L0 907 560 E
   Component: 4.2l V8/4V          0020
   Revision: 79H02---    Serial number: VWX3Z0H6785483
   Coding: 0421000A590F0E60
   Shop #: WSC 31414 790 00001
   VCID: 35372688D951BFFF2A1-5160
   Part No SW: 09D 927 750 HG    HW: 09D 927 750 HG
   Component: AL 750 6A           1410
   Revision: 00H75000    Serial number:
   Coding: 0004984
   VCID: 7AADF5B4B0CF9087873-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0006530
   VCID: 46D55144B4E72467B3B-8012
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 C    HW: 7L0 909 137 C
   Component: 2G Kessy            6850
   Revision: 00H22070    Serial number: VWX3Z0H6785483
   Coding: 0147688
   VCID: 33331890D775A1CF045-8066
                    Fault Frequency: 14
                    Reset counter: 126
                    Date: 2019.09.20
                    Time: 09:24:06
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AH
   Component: CLIMAtronic R/L     4334
   Coding: 0021030
   VCID: 76B5E1848487F4E7E3B-8022
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2003
   Revision: -0004---    Serial number: --------------
   Coding: 230008002F243C000000000000000000
   VCID: 0059875CD643CA57C97-8054
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 7L6 907 567 A    HW: 7L6 907 567 A
   Component: AC201  NAR 1    031 0382
   Revision: 00031000    Serial number: 00000000024293
   Coding: 0020000
   VCID: 3C2133ACFA2B6EB7D5F-8068
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3N VW8T       0250
   Revision: 92012025    Serial number: 0039P005UVCT
   Coding: 0013134
   VCID: 7AADF5B4B09F9087873-802E
   Subsystem 1 - Part No: 7L0 959 339 F
   Component: BF-Gewichtsens. 007 0010
   Subsystem 2 - Serial number: 3SHU9
   Subsystem 3 - Serial number: 0001.01.000000700000000000
   Subsystem 4 - Serial number: 000000
   Part No: 7L6 953 549 G
   Component: J527                3601
   Coding: 0011221
   VCID: 43D3485087D5114F945-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 990 H    HW: 7L6 920 990 H
   Component: J285 KOMBI-INST.    8828
   Revision: KHH06V36
   Coding: 0007201
   VCID: 3E2539A4EC777CA7FBB-806A
                    Fault Frequency: 12
                    Reset counter: 158
                    Mileage: 169801 km
                    Date: 2019.08.24
                    Time: 22:52:37
01304 - Radio
                    Reset counter: 155
                    Mileage: 174431 km
                    Date: 2019.11.11
                    Time: 13:46:29
                    Reset counter: 155
                    Mileage: 174431 km
                    Date: 2019.11.11
                    Time: 13:46:29
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 990 H
   Component: J533  GW-K-CAN TP20 8828
   Coding: FFEEFFDBCB846002
   VCID: 70B9D79CE6A3DAD7397-8024
01304 - Radio
                    Reset counter: 155
                    Mileage: 174431 km
                    Date: 2019.11.11
                    Time: 13:46:29
                    Reset counter: 155
                    Mileage: 174431 km
                    Date: 2019.11.11
                    Time: 13:46:29
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 015F8258DD19C35FC69-5160
Address 2E: Media Player 3
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 D
   Component: SG-Quersperre       5023
   VCID: 392F2AB8F5495B9FCE9-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A2D35B4F04F5087C73-5160
01772 - Signal from Level Control Pressure Sensor (G291)
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77ABEC80838D8DEFF8D-8022
   Part No SW: 7L6 035 684     HW: 7L6 035 684
   Component: RNS-MID       H16 0211
   Revision: AB001001    Serial number: VWZ6Z7H8184021
   Coding: 000500000100002200
   VCID: 73B3D8909BB5E1CFC45-8026
00862 - Antenna for GPS Navigation (R50/R52)
                    Reset counter: 168
                    Mileage: 156616 km
                    Date: 2018.11.19
                    Time: 11:00:34
   Part No SW: 7L6 907 566 B    HW: 7L6 907 566 A
   Component: J0769_SWA_MasterH10 0070
   Revision: 00H10000    Serial number: 6PZ 009 014-01
   Coding: 0010051
   Subsystem 1 - Part No: 7L6 907 568 B
   Component: J0770_SWA_Slave_H08 0070
   Subsystem 2 - Serial number: 6PZ 009 014-21
   Subsystem 3 - Serial number: 3F08.07.0800H0800000010171
   Subsystem 4 - Serial number: 010171
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 248
                    Mileage: 154789 km
                    Date: 2018.09.27
                    Time: 14:51:38
   Part No: 7L6 959 933 A
   Component: 22 HSG              0601
   Coding: 0000085
   VCID: 40D9475C96930A57897-4B1E
   Subsystem 1 - Part No: 7L0 959 701 P
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 P
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
01134 - Alarm Horn (H12)
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 7L6 035 466 C    HW: 7L6 035 466 C
   Component: DSP 10 Kanal        0020
   Revision: 00H06001    Serial number: 75835000900606
   VCID: 34311B8CD23BA6F71DF-8060
                    Reset counter: 248
                    Mileage: 154790 km
                    Date: 2018.09.28
                    Time: 00:00:03
                    Reset counter: 248
                    Mileage: 154790 km
                    Date: 2018.09.28
                    Time: 00:00:03
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0132
   Coding: 1292419
   VCID: 3B2330B0FF25698FDC5-806E
   Component: AFS-Lst.-Modul l    S002
   Coding: 00000019
   Component: AFS-Lst.-Modul r    S002
   Coding: 00000019
                    Reset counter: 168
                    Mileage: 156616 km
                    Date: 2018.11.19
                    Time: 11:00:34
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Component: J0502 RDK           0006
   Revision: 00004006    Serial number: 00000600011458
   Coding: 0040008D8D0000000000000000
   VCID: 3A2D35B4F01F5087C73-806E
02214 - Tire Pressure Warning
                    Reset counter: 152
                    Mileage: 174242 km
                    Date: 2019.11.09
                    Time: 12:26:58
                    (no units): 63.0
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392F2AB8F5595B9FCE9-806C
   Component: RLS     080708 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0050
   Revision: 4A007002    Serial number: 00000112755310
   Coding: 0016386
   VCID: 3FDB44A0EB3D75AFF0D-806A
   Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
   Component: J772__Rearview      0033
   Revision: 00H13000    Serial number:    PA8 J870251
   Coding: 0110001
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------037979
   Coding: 0122110
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AB    HW: 7L6 919 044 AB
   Component: J702  Dachdisplay   0400
   Revision: --30005S    Serial number: 00000000086870
   VCID: 77ABEC8083CD8DEFF8D-8022
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392F2AB8F5195B9FCE9-806C
Address 77: Telephone
End----(Elapsed Time: 03:15, VBatt start/end: 11.9V/11.9V. VIgn 11.7V)-----
