Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2009 Jetta TDI, Changing ABS module and coding
    Nov 2019
    Canada
    Hi everyone,
    I need to change the ABS module in my 2009 Jetta, According to VW my car has the 1K0 907 375 AN abs module. Now according to VCDS my module is a 1K0 907 375 AD.
    So I just recently acquired an ABS Module from a 2011 TDI jetta, Part number 1K0 907 375 AT. Will I be able to re code this module to work in my 2009 Jetta?
    Also I should mention the PCM is not the original for the Car. Its still from a 2009 jetta but has been flashed with a Malone stage 2 tune and the immobilizer has been deleted.
    Here is a copy of my Auto Scan from VCDS
    I was also wondering which line is the code for re-coding the new ABS module?
    Thank you
    Allen
    Tuesday,26,November,2019,17:38:17:33238
    VIN: 3VWTL71K89M263079   License Plate:
    Mileage: 246760km-153329mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
    VIN: 3VWTL71K89M263079   Mileage: 246760km-153329miles
    01-Engine -- Status: Sporadic communication error 1000
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 016 N    HW: 03L 906 022 J
       Component: R4 2,0L EDC G000SG  8680
       Revision: 12H01---    Serial number: VWX7Z0H524I095
       Coding: 0050072
       Shop #: WSC 84224 299 591528
       VCID: 3D273EB08179B38FE21-8068
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Coding: 113B400D492700FE880C02E9921D00423000
       Shop #: WSC 50571 001 1048576
       VCID: 76B5E19CE8CF20D7E3B-8022
                        Fault Frequency: 7
                        Reset counter: 3
                        Mileage: 246479 km
                        Count: 32768
                        Count: 4608
                        Count: 73
                        Count: 52022
       Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 70B9D78486AB0EE7397-8024
       Revision: 00H54000    Serial number: 00000009264211
       Coding: 10018E234004100007140000001400000008730B5C000120000000000000
       Shop #: WSC 53316 000 1048576
       VCID: 323D1D8C48277CF70F3-8066
       Component: Wischer 190309 021  0501
       Coding: 00038805
       Shop #: WSC 53316
                        Reset counter: 237
                        Mileage: 245885 km
                        Voltage: 12.75 V
       Revision: 00000000    Serial number: AUZ4Z7I0532598
       Coding: 0000102
       VCID: 33331888B73D75FF045-8066
    00003 - Control Module
                        Fault Status: 00101110
                        Reset counter: 6
                        Mileage: 36521 km
                        Time: 14:55:18
                        Reset counter: 177
                        Mileage: 245062 km
                        Time: 14:59:04
       Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
       Component: 2U AIRBAG VW8R  038 8600
       Revision: 07038000    Serial number: 003E7M08Y5PW
       Coding: 0012885
       VCID: 6D87CEF09199E30F121-8038
       Subsystem 1 - Serial number: 6332MSME43511211W
       Subsystem 2 - Serial number: 6342MSME4454272FF
       Subsystem 3 - Serial number: 6351HSME1C0C494FO
       Subsystem 4 - Serial number: 6361HSME1B790871C
       Subsystem 5 - Serial number: 63727SME1B74466BA
       Subsystem 6 - Serial number: 63827SME1B751E617
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Coding: 0000331
       VCID: 76B5E19CE4CF20D7E3B-8022
       Part No SW: 1K0 920 874 D    HW: 1K0 920 874 D
       Component: KOMBIINSTRUMENT 3HL 2418
       Revision: V0005000    Serial number: VWX7Z0I224B0EN
       Coding: 0023303
       VCID: 2E0509FC5C1F58176BB-807A
                        Fault Frequency: 16
                        Reset counter: 227
                        Mileage: 245424 km
                        Time: 16:14:11
                        Fault Frequency: 9
                        Reset counter: 237
                        Mileage: 245885 km
                        Time: 16:51:38
       Revision:   H07 01    Serial number: 180209F2001694
       Coding: E9807F06001702001002
       VCID: 372B2C98A34599DF38D-8062
                        Fault Status: 00110100
                        Reset counter: 237
                        Mileage: 245885 km
                        Time: 16:51:38
       Component: Kompass         005 0004
       Revision: 00005000    Serial number: 1293324T413504
       Coding: 0000003
       VCID: 392F2AA095518FAFCE9-806C
                        Fault Frequency: 10
                        Reset counter: 227
                        Mileage: 245424 km
                        Time: 16:14:11
       Component: IMMO            3HL 2418
       Revision: 72009005    Serial number: 00000805689208
       Coding: 0001205
       VCID: 6FBBD4F89B95111F20D-803A
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 70     2501
       Revision: 00H15000
       VCID: 2C0103F46A032A0745F-8078
                        Fault Status: 00101101
                        Fault Frequency: 18
                        Reset counter: 12
                        Mileage: 246707 km
                        Time: 15:42:05
                        Voltage: 14.00 V
                            DU
                        Temperature: 15.0°C
                        RPM: 1626 /min
                        Speed: 84.0 km/h
                        Speed: 85.0 km/h
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 13900F880106281B0904058FB0880F0488FC00
       Shop #: WSC 03285 999 14509
       VCID: 71BFD2808DA107EF369-8024
       Revision: 72009005    Serial number: 08120722582603
       Coding: 0001204
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2241149
       Coding: 0010400
       VCID: 290FFAE065F13F2FBE9-807C
                014 - Defective
       Revision: 12006001    Serial number: 00000003800031
       Coding: 0001168
       Revision: 12006001    Serial number: 00000003874453
       Coding: 0001168
       VCID: 77ABEC98E3C559DFF8D-8022
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 A    HW: 1Z0 035 729 A
       Component: FSE_2P8x        H34 0150
       Revision: 00000000    Serial number: 00000005009436
       Coding: 0001088
       VCID: 3635219CA44F60D723B-8062
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.6V/12.5V)-----------
    Quote Originally Posted by Allen Vos View Post
    No, you're looking at the hardware part number. The part number that's really relevant here is the software part number, and what you have is: 1K0 907 379 CD.
    Your ABS coding is here:
       Revision: 00H35001
    Nov 2019
    Canada
    ok, good to know, so how will I know if I can use the 1K0 907 375 AT module?
    Sep 2016
    Riga, Latvia
    Why do You want to replace Your ABS module? Whats wrong with it?
    Nov 2019
    Canada
    Its been doing some very random things, abs sensor codes coming and going randomly, steering angle sensor needing to be randomly reset, traction control kicking in without wheelspin, and speedometer reading 1/2 the speed the car is going. The traction control will randomly activate as well with the ABS lite on as well. Then everything will work fine for a while. So I picked one up for a good price and want to swap it to see if it fixes the issues.
    Sep 2016
    Riga, Latvia
    A lot of symptoms You described may be explained by this:
                        Fault Frequency: 7
                        Reset counter: 3
                        Mileage: 246479 km
    Sensor, wiring, wheel bearing.
    This does not explain sporadic communication interruptions on CAN. Faulty ABS module can cause comm faults, but, from another side, comm faults on CAN may cause similar symptoms like faulty module.
    Anyway, if You already have replacement, go on, try it
  7. Likes Jack@European_Parts, downtime liked this post
    Nov 2019
    Canada
    I figured it was worth a try to replace it, i had the same code for both rf and rr sensors as well but the funny thing is both wheel bearings and sensors are new, Ive also checked resistance on the wiring from the wheel to the module. These codes all come and go. One thing I should also mention is that the lr sensor always reads 10% higher than the other 3 sensors.
    Any ways, I just wanted to know if the newer module will work on my car? How would I go about figuring that out?
  9. #8
    Vehicle Identification No. 3VWTL71K89M263079
    Model Jetta Variant
    JEV
    Date of production 31.07.2008
    Model year 2009
    Sales type 1K577L
    Engine Code CBEA
    Transmission Code KNS
    1K0 907 375 AF
    Legacy!
    Control unit for ABS
    1K0 614 117 AC
    1K0 614 117 AD
    1K0 907 379 AF
    Looks like fiddle dee dee FOD!
    OP WTF are you doing?
    Mr. X gave great advice I suggest you JPPSG and take it!
    Did you check your ignition switch function, mini harness to it and all terminal relays + grounds?
    https://bigbangtheory.fandom.com/wik..._Nearest_To_Me
  10. #9
    Nov 2019
    Canada
    Model Jetta Variant
    JEV
    Model year 2009
    Sales type 1K577L
    Engine Code CBEA
    1K0 907 375 AF
    Legacy!
    1K0 614 117 AC
    1K0 614 117 AD
    1K0 907 379 AF
    So I probably should have Included my cars actual VIN as the PCM I have is from another vehicle and flashed with a tune.
    So my actual VIN is 3VWRL81KX9M154154. I'm not sure if this will make a difference on the ABS modules I can use.
    I had seen another thread on this forum where a guy managed to get the newer 1K0 907 375 AT module working on a 2009 golf I believe
    Here is the link to it https://forums.ross-tech.com/showthr...-Golf-GTI_2009
    I get that I currently have a LR ABS sensor code but I have multiple codes that come and go. I have multiple symptoms which almost point to an ABS module or as you are thinking possible power , ground or CAN bus issues.
    So i think the easiest thing for me to do is swap the ABS module, since I have one to see if the issue goes away. If the issue is still there then I will have to dig further. But for right now I would really like to try and get this ABS module working on my car. According to the link I supplied its doable, but I might be dead wrong
  11. #10
    TRIPLE FOD THREAT MATCH!
    Vehicle Identification No. 3VWRL81KX9M154154
    Model Jetta
    JEM
    Date of production 27.03.2009
    Model year 2009
    Sales type 1K277L
    Engine Code CBEA
    Emission standard 7GB Emission standard ULEV 2
    PART NUMBER DESCRIPTION REMARK MODEL
    * 1K0 907 375 AD Control unit for ABS 1K0 614 517 BD
    1K0 907 379 AD
    Dropped: Dec 1, 2009 (EKZ: L)
    Supersession
    1K0 907 375 AN Control unit for ABS
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1D Battery 380 A (72 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0E Component parts set, complying with vehicle type for Canada, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0XZ Information kit in English/French
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ1 Chrome package
    General operating permit, alterations C14 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G46 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MA Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running lights NAR
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YG Weight range 7 installation control only, no requirement forecast
    Weight category front axle L13 Suspension range 13 installation control only, no requirement forecast
    Base engine TJ3 4-cylinder diesel engine 2.0 l unit 03L.D
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U0 Without luggage compartment cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G0K 6-speed manual transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M0 Without rear window wiper and washer system
    Rear seats 3NQ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5D Instrument cluster, km/h speedometer - Canada -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W2 Glove compartment cooling system
    child safety 4H3 Manual child lock
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y3 Cold zones
    Compass/road sign display QR1 With compass
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F5 Fuel system for diesel engine
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K5 Transport protection film with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2ZB Leather-wrapped multi-function steering wheel
    Speaker installation 8RW 10 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z4 moderately hot country
    Engine specifications D91 4-cyl. turbo diesel engine 2.0 L/103 KW (4 V) TDI common rail TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TQ Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CJ8 Alloy wheels 6.5J x 16
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G4 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PLV Leather package "Vienna"
    Side airbag 4X4 Side airbag in front and rear with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Nameplates for sales name QD3 Lettering for sales name
    Seat belt check 9P6 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N1X Seat trim covers in part leather
    Seat adjustment 3PD Manual height adjustment for front seats, electric backrest adjustment for left front seat
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B0 with no protective side strip
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JL Comfort bumpers
    Rear stabilizer 0BG Rear stabilizer
    Front stabilizer bar 0AG Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 1DG Nameplate set "TDI"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B35 Legal requirements Canada
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W3 Telephone preparation (UHV High NAR)
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E6 Electric auxiliary air heater
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 7VP With engine preheating
