Hi everyone,
I need to change the ABS module in my 2009 Jetta, According to VW my car has the 1K0 907 375 AN abs module. Now according to VCDS my module is a 1K0 907 375 AD.
So I just recently acquired an ABS Module from a 2011 TDI jetta, Part number 1K0 907 375 AT. Will I be able to re code this module to work in my 2009 Jetta?
Also I should mention the PCM is not the original for the Car. Its still from a 2009 jetta but has been flashed with a Malone stage 2 tune and the immobilizer has been deleted.
Here is a copy of my Auto Scan from VCDS
I was also wondering which line is the code for re-coding the new ABS module?
Thank you
Allen
Thank you
Allen
Tuesday,26,November,2019,17:38:17:33238
VIN: 3VWTL71K89M263079 License Plate:
Mileage: 246760km-153329mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWTL71K89M263079 Mileage: 246760km-153329miles
01-Engine -- Status: Sporadic communication error 1000
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 8680
Revision: 12H01--- Serial number: VWX7Z0H524I095
Coding: 0050072
Shop #: WSC 84224 299 591528
VCID: 3D273EB08179B38FE21-8068
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B400D492700FE880C02E9921D00423000
Shop #: WSC 50571 001 1048576
VCID: 76B5E19CE8CF20D7E3B-8022
Fault Frequency: 7
Reset counter: 3
Mileage: 246479 km
Count: 32768
Count: 4608
Count: 73
Count: 52022
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D78486AB0EE7397-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009264211
Coding: 10018E234004100007140000001400000008730B5C000120000000000000
Shop #: WSC 53316 000 1048576
VCID: 323D1D8C48277CF70F3-8066
Component: Wischer 190309 021 0501
Coding: 00038805
Shop #: WSC 53316
Reset counter: 237
Mileage: 245885 km
Voltage: 12.75 V
Revision: 00000000 Serial number: AUZ4Z7I0532598
Coding: 0000102
Shop #: WSC 00066 000 00000
VCID: 33331888B73D75FF045-8066
00003 - Control Module
Fault Status: 00101110
Reset counter: 6
Mileage: 36521 km
Time: 14:55:18
Fault Frequency: 6
Reset counter: 177
Mileage: 245062 km
Time: 14:59:04
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 2U AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08Y5PW
Coding: 0012885
VCID: 6D87CEF09199E30F121-8038
Subsystem 1 - Serial number: 6332MSME43511211W
Subsystem 2 - Serial number: 6342MSME4454272FF
Subsystem 3 - Serial number: 6351HSME1C0C494FO
Subsystem 4 - Serial number: 6361HSME1B790871C
Subsystem 5 - Serial number: 63727SME1B74466BA
Subsystem 6 - Serial number: 63827SME1B751E617
01316 - ABS Control Module
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000331
VCID: 76B5E19CE4CF20D7E3B-8022
Component: E0221 002 0010
Part No SW: 1K0 920 874 D HW: 1K0 920 874 D
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I224B0EN
Coding: 0023303
VCID: 2E0509FC5C1F58176BB-807A
Fault Frequency: 16
Reset counter: 227
Mileage: 245424 km
Time: 16:14:11
Fault Frequency: 9
Reset counter: 237
Mileage: 245885 km
Time: 16:51:38
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 180209F2001694
Coding: E9807F06001702001002
VCID: 372B2C98A34599DF38D-8062
Fault Status: 00110100
Reset counter: 237
Mileage: 245885 km
Time: 16:51:38
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T413504
Coding: 0000003
VCID: 392F2AA095518FAFCE9-806C
Fault Frequency: 10
Reset counter: 227
Mileage: 245424 km
Time: 16:14:11
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000805689208
Coding: 0001205
VCID: 6FBBD4F89B95111F20D-803A
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C0103F46A032A0745F-8078
Fault Status: 00101101
Fault Frequency: 18
Reset counter: 12
Mileage: 246707 km
Time: 15:42:05
Voltage: 14.00 V
DU
Temperature: 15.0°C
RPM: 1626 /min
Speed: 84.0 km/h
Speed: 85.0 km/h
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Coding: 13900F880106281B0904058FB0880F0488FC00
Shop #: WSC 03285 999 14509
VCID: 71BFD2808DA107EF369-8024
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08120722582603
Coding: 0001204
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2241149
Coding: 0010400
VCID: 290FFAE065F13F2FBE9-807C
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003800031
Coding: 0001168
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003874453
Coding: 0001168
VCID: 77ABEC98E3C559DFF8D-8022
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 A HW: 1Z0 035 729 A
Component: FSE_2P8x H34 0150
Revision: 00000000 Serial number: 00000005009436
Coding: 0001088
VCID: 3635219CA44F60D723B-8062
End----------(Elapsed Time: 01:28, VBatt start/end: 12.6V/12.5V)-----------
