Results 1 to 5 of 5
Thread: Recommended Car Battery Charger / Power Supply
    Mar 2016
    Question Recommended Car Battery Charger / Power Supply
    Just wanted to get throughts on a good Battery Charger for modern start/stop cars when working on them with coding etc (to avoid battery drain etc).
    Normally I would start the engine, but sometimes the engine must not be running when doing updates for example.
    Not sure if "Battery Charger" is the right term to use, or just something to stop the battery draining and the car shutting down mid-coding/flashing etc.
    The VAS 5908 is quite expensive
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
    You want something that can produce at least 20 amps without breaking a sweat. The products offered on your side of the pond are quite different than ours, so can't make a specific recommendation, other than to avoid cheap stuff.
    For your application, you don't really need a "charger". A power supply putting out a fixed 13.4-13.8V will work just fine, but a good one capable of providing the requisite 20 or more amps that a modern car can pull still won't be cheap.
  3. Likes andyhud liked this post
    Aug 2018
    Ireland
    This is what I use for BMW flashing. Never had an issue and often has peak demand of 50A with some BMWs
    https://www.fronius.com/en/battery-c...essional-flash
  5. Likes Uwe, andyhud, Jack@European_Parts liked this post
  6. #4
    Jan 2018
    Cheshire UK
    I use this.. https://www.ringautomotive.com/en/product/RSCPR50
    Works great and doesn't cost an arm and a leg
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  7. Likes andyhud, Jack@European_Parts liked this post
  8. #5
    Mar 2016
    Thanks all for your comments, I genuinely appreciate it.
    Andy
