Friday,15,November,2019,11:16:45:57784
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZ3CZLE****** License Plate:
Mileage: 458km-284mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6D 75 A5
BB BC
VIN: WVWZZZ3CZLE****** Mileage: 458km-284miles
23-Brake Booster -- Status: Malfunction 0010
Address 01: Engine (J623-DPCA) Labels: None
Part No SW: 05E 906 018 BE HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9598
Revision: 8AH20000
Coding: 0125003223641D0830000000000000000000000000000000
Shop #: WSC 05311 115 00067
ASAM Dataset: EV_ECM15TFS01105E906018BE 003003
ROD: EV_ECM15TFS01105E906018BE_VW48.rod
VCID: 698CB707A9F7F9CF7E9-803C
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 050 A HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1703
Revision: 00005008 Serial number: CU501909126102
ROD: EV_TCMDQ200021_VW31.rod
VCID: 3330156FBBBB731F045-8066
Part No SW: 5Q0 614 517 FA HW: 5Q0 614 517 BR
Component: ESC H82 0190
Revision: 00000000 Serial number: 62559000001310
Coding: 0FEC7A8F31213B6E477F060560C749F05E8CDCE2600692753822F078D2224A0B0003000012121212B835351919323200
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B4EB77F54F2D2FEA1-8020
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0526367815
Coding: 1F20200723
Shop #: WSC 05311 115 00294
ASAM Dataset: EV_KessyHellaMQBAB 004052
VCID: 45D45BB7E52FFDAFBA1-8010
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11989806
Part No SW: 5G0 907 044 ER HW: 5G0 907 044 ER
Component: Climatronic H04 2202
Revision: 00001K10
Coding: 12020004200110011115000C8010D836
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 7BA0FD4FD36B7B5F9C5-802E
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 CE HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F0908190080
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 7F58095FC773677FB0D-802A
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190731 042 0607
Serial number: 190820191253
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: USER\5Q0-955-547.LBL
Component: RLHS 051 0206
Serial number: S5Y19M09D10H12M20S15
Coding: 0008DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 09 06 2019 10000469
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY192202B3N
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000595861
Steering Column Switch:
Subsystem 7 - Part No SW: 5Q1 953 521 AC HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0100030920190C204230
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319253
Coding: 0451051811
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50FA7AE32A6D2807197-8004
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 R HW: 3Q0 907 567 A
Component: ACC BOSCH MQB H01 0771
Coding: 3200674215FFC728949C812480400600000000000000000066
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003.rod
VCID: 46D65CBBD829F6B7B3B-8012
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z4PGP587%
Coding: 98CCC0C0000000005C5400CF000840000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0E46A49BF0D97EF74BB-805A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705B0261T01319
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1040
Serial number: 3G0857706B0256T01202
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 003 107 19
Serial number: 35700000000D53197E3R
Subsystem 4 - Part No SW: ----------- HW: 454 003 107 19
Serial number: 35800000000D6C497E3+
Subsystem 5 - Part No SW: ----------- HW: 454 800 908 19
Component: SideSensor_Dr 301 0148
Serial number: 3510082224C190000006
Subsystem 6 - Part No SW: ----------- HW: 454 800 808 19
Component: SideSensor_Pr 301 0148
Serial number: 35200B2214C190000009
Subsystem 7 - Part No SW: ----------- HW: 454 800 608 19
Component: FrontSensor_D 304 0149
Serial number: 35500AB882F19000000Y
Part No SW: 3G0 920 750 F HW: 3G0 920 750 F
Component: KOMBI 301 7411
Coding: 07A409186780000801882A031001000800200000
ASAM Dataset: EV_DashBoardJCIMQBAB 009014
ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
VCID: 2708F13F7F630FBFA8D-8072
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000094711
Coding: 030900047F085700F910425C180F00000001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF.rod
VCID: 70BADA638A2D0807397-8024
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 3G0 959 442 K HW: 3G0 959 442 K
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036260191308
Coding: 2F0B00
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001909030E6A
131643 - Brake Booster Control Module
U103E 00 [008] - No communication
[Timeout Knoten 0x3B / 23 - Steuerger‰t f¸r Bremskraftverst‰rkung]
Reset counter: 43
Mileage: 12 km
Date: 2019.11.06
Time: 15:04:13
Supply voltage: Terminal 30: 12.0 V
Terminal 15: OFF
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3Q0 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0069
Serial number: BPA085120919013
Coding: 0102C100340000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
VCID: 3B203D4F93EBBB5FDC5-806E
499968 - Implausible Data Received from Vehicle Immobilizer Control Module
U0426 00 [046] - -
Fault Frequency: 96
Reset counter: 0
Mileage: 3 km
Date: 2019.09.30
Time: 15:25:21
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000238453008
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0320
Serial number: YE007SGT08467
Coding: 00351A20D000028000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
VCID: 49CC5787C93719CF5E9-801C
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 957032 00
Coding: 0100001100400010
Shop #: WSC 00015 115 00294
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
VCID: 2B000D0F638B2BDF4C5-807E
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0320
Serial number: YE007SHS01044
Coding: 00351020DC00028000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
VCID: 48CA5283D23DE0C7417-801C
Part No SW: 3G0 035 869 HW: 3G0 035 869
Component: MU-E--ER 715 0740
Serial number: 06091900021507
Coding: 02840200FF00000041110001000002001F0000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW48.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 T HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0271
Revision: -------- Serial number: A2-C748-5840-9
Coding: 0228
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000905NVZC2
Coding: 02482000196828208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_VW37.rod
VCID: 015C8FA7B187118FC69-8054
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1027
Serial number: E33417008192430
Coding: 00000888004C4020109E10000020000000410000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 72BED06B84213A17CF3-8026
Part No SW: 5Q0 959 395 K HW: 8W1 959 395 D
Component: TSG HFS004 0320
Serial number: YE007SHD12266
Coding: 000010200100028000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
Component: TSG HBFS004 0320
Serial number: YE007SHD13481
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.2V)-----------
