2019 Audi A6 old cable?
suffeks
Poland
C?ID=128398
not using the new cable i assume is the problem?
Friday,15,November,2019,12:05:22:27988
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZF21KN100993   License Plate:
                Address 01: Engine
Control Module Part Number: 05L 906 027 F
  Component and/or Version: R4 2.0l TDI   H22 6314
           Software Coding: 0A65401A2576050C3C282000000400000000000000000000
            Work Shop Code: WSC 02391
                      VCID: 2F671EA7767018370E-807A
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: E1H22---
     Date: 23.03.19
     Manufacturer number: 1313
     Test stand number: 0705
Flash Status
     Programming Attempts(application): 1/1/1/1/1/1
     Flash Date: 19.04.05
Misc.
     Hardware number: 05L 907 309
     Workshop System Name: J623
     ASAM Dataset: EV_ECM20TDI01105L906027F
     ASAM Dataset Revision: 005004
Car Info
     Chassis Number: WAUZZZF21KN100993
     Engine code: DFBA
VCDS Info:
       Labels: None
       Readiness: No script available
       ROD: ERROR - EV_ECM20TDI01105L906027F 005004 ()
Friday,15,November,2019,12:06:50:27988
                Address 44: Steering Assist
Control Module Part Number: 4N0 909 144 E
  Component and/or Version: EPS_MLBEVO2BS H21 0505
           Software Coding: E1002101010000
                      VCID: 326117D3654235DF61-8066
     Identification: URB-001
     Date: 17.03.19
     Manufacturer number: 0001
     Test stand number: 0267
Flash Status
     Programming Attempts(application): 1/1/1/1/1/0/1
     Flash Date: 00.01.01
     Flash Tool Code(data): 00200 785 02391
Misc.
     Hardware number: 4N0 909 144 A
     Workshop System Name: J500
     Equipment/PR Code: 000000000000000000000000
     Dataset Number: 4K0909852K
     Dataset Version: 0002
     ASAM Dataset: EV_EPSVWBSAU426
     ASAM Dataset Revision: 010017
VCDS Info:
       Labels: None
       ROD: ERROR - EV_EPSVWBSAU426 010017 ()
                Address 01: Engine
     Revision: E1H22---
     Date: 23.03.19
Flash Status
Misc.
Car Info
     Engine code: DFBA
VCDS Info:
       Labels: None
                Address 01: Engine
     Revision: E1H22---
     Date: 23.03.19
Flash Status
Misc.
Car Info
     Engine code: DFBA
VCDS Info:
       Labels: None
                Address 01: Engine
     Revision: E1H22---
     Date: 23.03.19
Flash Status
Misc.
Car Info
     Engine code: DFBA
VCDS Info:
       Labels: None
                Address 01: Engine
     Revision: E1H22---
     Date: 23.03.19
Flash Status
Misc.
Car Info
     Engine code: DFBA
VCDS Info:
       Labels: None
Correct. That old HEX+CAN is not compatible with this car.
Upgrades are available here.
