Results 1 to 8 of 8
Thread: "Audi lane change assistant" permanent activation?
    Jan 2015
    hi, on my 67 plate A7 I have audi lane change assistant that you can turn on by pressing button on the door near the mirror, does anyone know the way of permanent activation of this option?
    as it goes off after car restart.
    Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
    Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
    Component: SWA Master H08 0070
    Serial number: 0462040113
    Coding: 040312
    VCID: 3979018FB8251787A0-806C
    Lane Change Assistant 2:
    Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
    Component: SWA Slave H08 0070
    Serial number: 0462201850
    Coding: 040312
    thanks in advance for any input.
    Oct 2017
    Northwest UK
    Hi
    Can you please post a complete autoscan. tou shouldn't need to turn it on every time.
    Jan 2015
    Quote Originally Posted by myounus View Post
    Hi
    Every time have to press that button and light comes on. after next engine start it is off again.
    Monday,25,November,2019,23:53:40:31877
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ4G1JN071508   License Plate: AFTER CODE
    Mileage: 51104km-31754mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 36 3B 3C 42 44 46
              52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 AC C0
    VIN: WAUZZZ4G1JN071508   Mileage: 51104km-31754miles
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0008
       Revision: 54H23---
       Coding: 1A2A4032256603030800
       Shop #: WSC 54544 001 1048576
       ASAM Dataset: EV_ECM30BTD0114G0907589F 001008
       ROD: EV_ECM30BTD0114G0907589F.rod
       VCID: 377D07B78E3101F756-8062
    18728 - NOx Sensor 1 Bank 1
              P2201 00 [237] - Implausible Signal
                        Mileage: 49114 km
                        Date: 2019.11.05
                        Time: 16:09:17
                        Engine speed: 1964.50 /min
                        Vehicle speed: 103 km/h
                        Coolant temperature: 89 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 14.200 V
                        Exh r N Ox Pres Comp NSC Ds: -37 ppm
                        NOx-Sensor 1: oxygen concentration: 0.20439
                        O2 sensor 1: bank 1: voltage raw value O2 signal: 1277.0 mV
                        O2 sensor 1 bank 1: adjusted oxygen value: -0.00055
                        EGR Solen.val.: actual value: 99.89 %
                        Mean injection quantity: 0.00 mg/stroke
                        Exh.gas temp.sen 1: 298.2 °C
    Readiness: 1 1 0 0 0
       Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRDW H22 1015
       Revision: --H22---
       Coding: 000001
       VCID: 77FDC7B7CEB1C1F796-8022
       Coding: 49A79E4B92E579D29B00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 4189696FD0F54F47E8-8014
    171008 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
                        Mileage: 51104 km
                        Date: 2019.11.25
                        Time: 23:38:52
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 9C
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01BA704E000000000000
       VCID: 7CF7D89BFF97E2AFFB-8028
       Serial number: 3217000171792012
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Serial number: 01121700040212
       Coding: 362311783D0000
       VCID: 63C583E76A293D57DA-8036
       Part No SW: 4H0 907 063 GG    HW: 4H0 907 063 AG
       Component: BCM1 2.0      H20 0368
       Revision: 1402003S    Serial number: 00001819903601
       Coding: 0105C01540348FE2C10140C780001800CF9DC30A2F080201800008946100130200400019010000
       VCID: 73E5F3A7D2C9ADD7AA-8026
       Component: WWS57X 171017  H38 0080
       Serial number:         171114221610
       Coding: 004DF7
       Serial number: 21073893X81A955547A0
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
       Component: E1 - LDS  H07 0044
       Serial number: 27 11 2017  00000727
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA129149000038179320
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 1E605CD800PAG0MUFU03
    03455 - Function Restriction due to Faults in Other Modules
                        Reset counter: 39
                        Mileage: 51104 km
                        Date: 2019.11.25
                        Time: 23:37:20
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0090
       Revision: --------    Serial number: 56231732003096
       Coding: B83B10
       ASAM Dataset: EV_EPHVA2CAU64X0000 001015
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 3A7B1E83BD231C9FA9-806E
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Coding: 7E04010201
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 2959D1CF4885A707D0-807C
    154624 - Door Contact Switch
              C1076 29 [008] - Signal Implausible
                        Reset counter: 67
                        Mileage: 49656 km
                        Date: 2019.11.10
                        Time: 15:29:22
                        Control Module temperature: 22 °C
                        Voltage terminal 15: 11.300 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/sІ
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H83 0098
       Revision: --------    Serial number: 003P100FB25J
       Coding: 30333046313130313137554A305234473853
       VCID: 3B751B87B2192597B2-806E
       Serial number: 3575HRB400Q5BRV86HQL
       Serial number: 3585HRB401C5BRV880NY
       Serial number: 3515JRB400A5BT50CQ56
       Serial number: 3525JRB405556RGO9023
       Serial number: 3554VRB4051556M4E07U
       Serial number: 3564VRB4051556M4LPHU
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QKP0007Z
       Coding: 0000FC
       VCID: 377D07B7863101F756-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 06 11 2017  D0009509
       Part No SW: 4G8 920 988 D    HW: 4G8 920 988 D
       Component: TDieGb Acc    H17 0225
       Revision: 18001312    Serial number: 658221117592058
       Coding: 338F05020F550408010100
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K_AU57.rod
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002804002
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 002011
       VCID: 408F6C6BDBFF464FE7-8014
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 2190945804
       Voltage stabilizer:
       Serial number: 1708250000000000017D
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 01121700040777
       Coding: 22
       VCID: 3D71159FAC0D2BA78C-8068
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H07 0030
       Revision: S0H07000    Serial number: 00000000006550
       Coding: 01010101000000000001000202
       VCID: 64C780FB67273A6F23-8030
       Revision: AA000000    Serial number: 00000288037971
       VCID: 77FDC7B7C6B1C1F796-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820ERFGX
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 36630AB3893BF8FF4D-8062
       Coding: 040312
       Coding: 040312
    262157 - Databus
                        Reset counter: 61
                        Mileage: 49116 km
                        Date: 2019.11.05
                        Time: 16:18:34
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F56035E21628002080413
       VCID: 45817D7FCCDD6367D4-8010
       Component: RCevo         H55 0202
       Revision: 00000002    Serial number: 0000269819
       Coding: 101101010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       Revision: 00002001    Serial number: 0461924966
       Coding: 013F0622A0B93884C3200A840E010D470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H04 0005
       Serial number: 0000FST001W7YBD00000
       Coding: 901F02
       Subsystem 4 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
       Serial number: 0000000AP00040671781
       Coding: 011F56035E21628002080402
       VCID: 46837A73F1DB687FDD-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002381465
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 326B36A36553E4DF61-8066
       Coding: 05FE02202A170200
       VCID: 346730BB9F47EAEF73-8060
       Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7570
       Coding: E02100
       Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7570
       Coding: E02100
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E02100
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E02100
    5350720 - Left Matrix High Beam
              C1175 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 26
                        Mileage: 49656 km
                        Date: 2019.11.10
                        Time: 22:45:18
    5350976 - Right Matrix High Beam
              C1176 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 26
                        Mileage: 49656 km
                        Date: 2019.11.10
                        Time: 22:45:18
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 J    HW: 4G1 035 021 D
       Component: MU-H-LND-EU   054 0910
       Serial number: A733K0HS022207
       Coding: 017503010000000013111102000A00332F000CE7F17001009F
       VCID: 2149C9EF30B56F4788-8074
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY809FXP
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Serial number: 90349QKM00012
       Component: Gracenote2  --- 1016
       Coding: 010F14024021628002080002
       VCID: 4999714FE0C5870730-801C
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 0275000102002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
       VCID: 78FFC48BC3AFCE8F9F-802C
       Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
       Component: HDSG-Modul    H14 0049
       Revision: 11014001    Serial number: 287701390
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 45817D7FC4DD6367D4-8010
       Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
       Component: HeadUpDisplay H10 0306
       Coding: C70000
       ASAM Dataset: EV_HUDContiC7 001027
       ROD: EV_HUDContiC7.rod
       VCID: 3E731293A10B30BF95-806A
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H28 0081
       Coding: 6A160000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C5728DB4777B22F2B-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010201
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 275DD7F75E919177C6-8072
                        Reset counter: 67
                        Mileage: 49656 km
                        Date: 2019.11.10
                        Time: 15:29:22
                        Control Module temperature: 20 °C
                        Voltage terminal 15: 11.307 V
                        Velocity_vehicle_reference: -0.00 m/s
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H34 0090
       Serial number: 005002452111177
       Coding: 03C239181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308004240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 316939AF6055DFC718-8064
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0007
       Serial number: 170921204894
       VCID: 2E5322D3716BC03F05-807A
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 172471404
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F6D3FD77661C9370E-807A
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0011
       Serial number: 171005200194
    End-------------------------(Elapsed Time: 06:59)--------------------------
    Oct 2017
    Northwest UK
    It sounds like your issue is here:
    Try clearing all faults and see if they return. I suspect the car thinks the door is open and subsequently disabling the lane change assistant. It would also be easier if you had a V2 cable as the UDS fault description is more easier to define a databus error.
    Is the car still under manufacturer's warranty? If so I'd take it in.
  5. Likes Uwe liked this post
    Jan 2015
    thanks for reply, still is, they seen it, and ordered some parts, just not sure why it still allows to activate it manually if there's fault.. thought there's something else..
    Dec 2016
    Amsterdam
    Quote Originally Posted by Au07 View Post
    Probably because it only detects the fault when the door contact switch is actuated. Try opening and closing the door a few times with the engine running, lane change assist on and your seatbelt on. It will probably deactivate right then and there.
    Current:
  8. Likes Uwe, Au07 liked this post
    Jan 2015
    tried today, it stays active until you restart the car.
    hope you not mixing it with active lane assistant? i'm on about light on the mirrors that warn you if anyone in the blind spot
  10. #8
    Oct 2017
    Northwest UK
    All of these systems work together on the CAN. All ADAS systems run in conjunction with one another and they are linked into the vehicle's electrical systems to enable certain operations. When one part of the system is down is affects another functioning correctly.
    In your case as has been explained already the vehicle thinks that the door may not been closed and is causing the BSA not to activate automatically. The car may only pick this up on startup thus you can activate it manually.
  11. Likes Au07 liked this post
