Results 1 to 6 of 6
Thread: A6 4B ABS coding problem
    Feb 2015
    Spain
    Hi All, got here A6 with
    BDV engine
    GHK tranny (Multitronic (01J))
    1LT brakes
    VIN: WAUZZZ4B34N032265
    Had the norm LHF wheel speed sensor code, so took the module off and sent it for repair, its come back but coding is 00000, I can log in with 40168,, Ive tried to code it with the original code of 06499 that I snapped a photo of but its wont code, my wsc# is showing 00000 but its correct in the "options" page ?
    Any clues please
    EDIT
    Just had a relaxing read without shop phone and the "is it ready people" and see that my login should be 07399, I'll give it a go in the morning, please feel free to add if Ive missed anything
    If you don't succeed with that, please post an Auto-Scan for context.
    Feb 2015
    Spain
    Normally I do a full autoscan on all and save before doing anything else, this one for some strange reason I didnt, Ive no idea why I didnt,
    Check your Scans sub-folder too. If you made a scan but didn't save it, VCDS saved it in there anyway.
  5. Likes Liteace1 liked this post
    Feb 2015
    Spain
    All coded in when I entered the correct 07399, the module has been away for repair as it had LHF wheel speed sensor code, its still got LHF wheel speed sensor code
    Feb 2015
    Spain
    This ABS unit has been repaired again, if someone has a spare 5 mins please have a look at this video and tell me what you think the problem is, the repair shop is saying its the vehicle, I need a second opinion
    Tuesday,17,December,2019,17:47:21:39628
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Dealer/Shop Name:
    Workshop Code: 912 91234 091235
    VIN: WAUZZZ4B34N032265   License Plate: 9812CWJ
    Mileage: 187780km-116681mi   Repair Order: A6 abs
              75 76 77
    VIN: WAUZZZ4B34N032265   Mileage: 187780km-116681miles
    Address 01: Engine        Labels: 078-907-552-AMM.lbl
       Part No: 3B0 907 552 BK
       Component: 2.4L V6/5V          0002
       Coding: 11582
       Shop #: WSC 02334
       VCID: 6E903AAF280DC93F45-5184
       WAUZZZ4B34N032265     AUZ7Z0C2460750
    18057 - Powertrain Data Bus
                P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
    Readiness: 0010 1001
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4B0 910 155 G    HW: 01J 927 156 HH
       Component: V30 01J 2.4l 5V RdW 3120
       Revision: 00000004    Serial number: 00000000484710
       Shop #: WSC 00011 888 06946
       VCID: 22081E9FFC553D5F91-5184
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        RPM: 704 /min
                        RPM: 128 /min
                        RPM: 10 /min
                        (no units): 13.0
                        Torque: 4.0 Nm
                        Temperature: 40.0C
                        T.B. Angle: 0.0
                        Bin. Bits: 0011 0 0
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 06499
       Shop #: WSC 91234
       VCID: 25020583BD7BCA67F4-51CE
    6 Faults Found:
    18256 - Please check DTC Memory of Engine Controller
                P1848 - 35-10 -  - Intermittent
    18031 - Powertrain Data Bus
                P1623 - 35-10 - No Communication - Intermittent
                35-10 - - - Intermittent
                37-10 - Faulty - Intermittent
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                35-00 - -
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AN
       Component: A6-Klimavollautomat 0208
       Coding: 00000
       VCID: 6680428F03FD017F3D-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 P
       Component: Airbag 8.4EP        3002
       Coding: 0000606
       Shop #: WSC 02334 785 00200
       VCID: 3D32CDE365EB62A78C-5184
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 933 JX
       Component: KOMBI+WEGFAHRS. VDO D15
       Coding: 00162
       Shop #: WSC 11111
       VCID: 02487E1F0C95DD5FB1-5184
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 N
       Component: Zentralverrieg.,DWA D38
       Coding: 06987
       Shop #: WSC 02334
       VCID: 3424E8C705A1A3EF73-4EEA
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    01561 - Rear left door
                61-10 - Won't De-Safe - Intermittent
    01134 - Alarm Horn (H12)
                76-10 - Terminal 30 missing - Intermittent
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00101
       Shop #: WSC 02334
       VCID: 2600028FC37DC17FFD-50AE
    01349 - Alarm via Theft Warning System; Front
                35-00 - -
       Part No: 4Z7 907 357
       Coding: 00040
       Shop #: WSC 02334
       VCID: 044478071581D36F83-4B1E
       Part No: 4B0 035 186 Q
       Component: concert II  GRO    0008
       Coding: 02001
       Shop #: WSC 02334
       VCID: 2E10FAAFEB8D893F05-4AE0
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01106
       Shop #: WSC 02334
       VCID: 02487E1F0F95DD5FB1-513C
    End----------(Elapsed Time: 05:01, VBatt start/end: 12.4V/12.4V)-----------
