A6 4B ABS coding problem
Liteace1
Spain
C?ID=90243
Hi All, got here A6 with
BDV engine
GHK tranny (Multitronic (01J))
1LT brakes
VIN: WAUZZZ4B34N032265
Had the norm LHF wheel speed sensor code, so took the module off and sent it for repair, its come back but coding is 00000, I can log in with 40168,, Ive tried to code it with the original code of 06499 that I snapped a photo of but its wont code, my wsc# is showing 00000 but its correct in the "options" page ?
Any clues please
Thanks
EDIT
Just had a relaxing read without shop phone and the "is it ready people" and see that my login should be 07399, I'll give it a go in the morning, please feel free to add if Ive missed anything
Liteace1
Spain
C?ID=90243
Normally I do a full autoscan on all and save before doing anything else, this one for some strange reason I didnt, Ive no idea why I didnt,
Check your Scans sub-folder too. If you made a scan but didn't save it, VCDS saved it in there anyway.
Liteace1
Spain
C?ID=90243
All coded in when I entered the correct 07399, the module has been away for repair as it had LHF wheel speed sensor code, its still got LHF wheel speed sensor code :mad:
Liteace1
Spain
C?ID=90243
This ABS unit has been repaired again, if someone has a spare 5 mins please have a look at this video and tell me what you think the problem is, the repair shop is saying its the vehicle, I need a second opinion
Thanks
Tuesday,17,December,2019,17:47:21:39628
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
Dealer/Shop Name:
Workshop Code: 912 91234 091235
VIN: WAUZZZ4B34N032265   License Plate: 9812CWJ
Mileage: 187780km-116681mi   Repair Order: A6 abs
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
VIN: WAUZZZ4B34N032265   Mileage: 187780km-116681miles
Address 01: Engine        Labels: 078-907-552-AMM.lbl
   Part No: 3B0 907 552 BK
   Component: 2.4L V6/5V          0002
   Coding: 11582
   Shop #: WSC 02334
   VCID: 6E903AAF280DC93F45-5184
   WAUZZZ4B34N032265     AUZ7Z0C2460750
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: 0010 1001
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4B0 910 155 G    HW: 01J 927 156 HH
   Component: V30 01J 2.4l 5V RdW 3120
   Revision: 00000004    Serial number: 00000000484710
   Coding: 0000001
   Shop #: WSC 00011 888 06946
   VCID: 22081E9FFC553D5F91-5184
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    RPM: 704 /min
                    RPM: 128 /min
                    RPM: 10 /min
                    (no units): 13.0
                    Torque: 4.0 Nm
                    Temperature: 40.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0011 0 0
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 06499
   Shop #: WSC 91234
   VCID: 25020583BD7BCA67F4-51CE
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
18031 - Powertrain Data Bus
            P1623 - 35-10 - No Communication - Intermittent
            35-10 - - - Intermittent
            37-10 - Faulty - Intermittent
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            35-00 - -
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AN
   Component: A6-Klimavollautomat 0208
   Coding: 00000
   VCID: 6680428F03FD017F3D-2580
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 P
   Component: Airbag 8.4EP        3002
   Coding: 0000606
   Shop #: WSC 02334 785 00200
   VCID: 3D32CDE365EB62A78C-5184
00532 - Supply Voltage B+
   Part No: 4B0 920 933 JX
   Component: KOMBI+WEGFAHRS. VDO D15
   Coding: 00162
   Shop #: WSC 11111
   VCID: 02487E1F0C95DD5FB1-5184
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 N
   Component: Zentralverrieg.,DWA D38
   Coding: 06987
   Shop #: WSC 02334
   VCID: 3424E8C705A1A3EF73-4EEA
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01561 - Rear left door
            61-10 - Won't De-Safe - Intermittent
01134 - Alarm Horn (H12)
            76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00101
   Shop #: WSC 02334
   VCID: 2600028FC37DC17FFD-50AE
01349 - Alarm via Theft Warning System; Front
            35-00 - -
   Part No: 4Z7 907 357
   Coding: 00040
   Shop #: WSC 02334
   VCID: 044478071581D36F83-4B1E
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 4B0 035 186 Q
   Component: concert II  GRO    0008
   Coding: 02001
   Shop #: WSC 02334
   VCID: 2E10FAAFEB8D893F05-4AE0
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283
   Component: Parkingsyst. A6 RDW D08
   Coding: 01106
   Shop #: WSC 02334
   VCID: 02487E1F0F95DD5FB1-513C
End----------(Elapsed Time: 05:01, VBatt start/end: 12.4V/12.4V)-----------
