Evening All
seem to have lost power to a few things on my RS6 Avant 2018
No Rear Climate control
No Passenger Heated Mirror
No Power on rear view mirror
I've Ran Scan on controller and got the following , can anyone help
Chris
Chris
28-HVAC, Rear -- Status: Cannot be reached 0100
30-Special Function II -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: Malfunction 0010
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CWUC) Labels: Redir Fail!
Part No SW: 4G0 906 560 F HW: 4H0 906 014
Component: 4.0l V8TFSI / X63 0002
Revision: NCX63---
Coding: 122A00326526010B2800
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM40TFS0114G0906560F 001003
ROD: EV_ECM40TFS0114G0906560F.rod
VCID: 2B03078B638F1F5F4FB-807E
4718 - No Communication with Transmission Control Module
U0101 00 [032] - -
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 BH HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H22 1010
Revision: --H22---
Coding: 000001
VCID: 75B7E1F3F54B19AFE9F-8020
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Coding: 62B7DA4146ED5B829F00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 42DD4A2FF405FE179CD-8016
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Coding: 01B9704E000000000000
VCID: 7CA1F4D7D6E148E7961-8028
Serial number: 3217000244032016
Fault Status: 00101101
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:03
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 02021800040043
Coding: 682210B80D0000
VCID: 6A8DC28FACF5C65774D-803E
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
Reset counter: 211
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:12
Voltage terminal 30: 11.84 V
Outside air temperature: 10.0 °C
Engine speed: 0 /min
0317 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Klima hinten: kein Signal / Kommunikation]
Reset counter: 99
Mileage: 29650 km
Date: 2019.10.01
Time: 12:46:32
Voltage terminal 30: 12.17 V
Outside air temperature: 22.5 °C
0387 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 83
Reset counter: 248
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:12
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001909785902
Coding: 0105001440349FE0690140C7A0001800CF9DC70A2F08020180000894E100170200400024030000
VCID: 74B1DCF7FEB100A7DE1-8020
Component: WWS57X 171201 H38 0080
Serial number: 171213172016
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21178560X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 01 02 2018 00000731
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA130066000042067972
Coding: 020300
6 Faults Found:
03123 - Terminal 30 - 2
Fault Status: 00101011
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 08:57:39
01800 - Light Switch (E1)
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:08:47
01543 - Parking Aid Warning Chime (H15)
Fault Status: 00101001
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:08
01625 - Front Parking Aid Warning Chime (H22)
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:08
Reset counter: 211
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:12
03608 - Humidity Sensor in Fresh Air Intake Duct
Fault Status: 01100101
Fault Frequency: 56
Reset counter: 248
Mileage: 33061 km
Date: 2019.11.13
Time: 09:12:12
Component: Airbag10.43 H83 0098
Revision: -------- Serial number: 003P100FT8D8
Coding: 30333130313730323737554A305234473053
VCID: 3B2337CB93EF8FDFDFB-806E
Serial number: 3575HRB40125DLTM694J
Serial number: 3585HRB400C5DL9MH9Q%
Serial number: 3515JRB405T57BBU5PK8
Serial number: 3525JRB404V583SQJ1A$
Serial number: 3554VRB405T57BBE28S
Serial number: 3564VRB405T57BBEB1Q$
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372RB500017
Coding: 000035
VCID: 372B2BFBAF47ABBF3B3-8062
Subsystem 1 - Part No SW: 4G0 951 528 J HW: 4G0 951 528 J
Serial number: 20 11 2017 E0032460
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G0 920 982 T HW: 4G0 920 982 T
Component: TBenGb Nv H17 0225
Revision: 18001312 Serial number: 658240118592003
Coding: 33AF910B9B412600010400
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3D2739D38DFB81EFE1F-8068
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002885011
Coding: C0ED07481C
ASAM Dataset: EV_GatewPkoUDS 002011
VCID: 40D94027FA09EC078A9-8014
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 8863905804
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 17112400000000000275
5055 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:09:30
Voltage terminal 30: 11.8 V
Voltage terminal 15: 0.1 V
Control Module temperature: 20 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
5088 - Rear A/C control module
U1072 00 [009] - No communication
Reset counter: 99
Mileage: 29650 km
Date: 2019.10.01
Time: 12:46:32
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.9 V
Control Module temperature: 32 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4352 - ABS Control Module on FlexRay Data Bus
U10BD 00 [008] - No Communication
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:02
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 003001180001004
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
VCID: 2809F88772793447A29-807C
0390 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Getriebe - Steuergerät keine Kommunikation DTC_FRAY_GETRIEBE_03_NO_COM]
Reset counter: 40
Mileage: 29650 km
Date: 2019.10.01
Time: 12:46:39
Address 28: HVAC, Rear
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H07 0030
Revision: S0H07000 Serial number: 00000000007234
Coding: 01010101000000000001000102
VCID: 6491ACB74E5190274E1-8030
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:02
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:02
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008000
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F3B139B5797637F633-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000299133283
VCID: 77ABEBFBEFC76BBFFB3-8022
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:09:34
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E036GMJ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B2BFBAFC7ABBF3B3-8062
3801346 - Databus
[PDU Timeout]
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:02
DCU_Internal_DTC: 3A 01 02
Ignition Cycle Count: 7805
DCU Temperature: 6 °C
Voltage VBG 22: 2.5 V
VIN received: 00000000000000000
Debug Data: 00 00 00 00 00 00 00 00
Component: TSG FA H03 0511
Coding: 011F16015E21620002080002
VCID: 47CB5B3BDFA7DB3F4B3-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H55 0202
Revision: 00000002 Serial number: 0000450894
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D32CF9CD5B6D7C4D-806E
Revision: 00002001 Serial number: 0470224473
Coding: 013B0622A0B93894C3300984000113470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H04 0005
Serial number: 0000FST001YA3R300000
Coding: 901E00
Subsystem 4 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H04 0005
Serial number: 0000FST001YA36I00000
Coding: 801E00
01308 - Control Module for Roof Electronics (J528)
Fault Frequency: 9
Reset counter: 223
Mileage: 29650 km
Date: 2019.10.01
Time: 12:46:36
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:07:03
Reset counter: 251
Mileage: 33061 km
Date: 2019.11.13
Time: 09:09:34
Fault Frequency: 21
Reset counter: 7
Mileage: 33073 km
Date: 2019.11.13
Time: 10:58:17
00216 - Signal EC-mirror Fade Out
Reset counter: 218
Mileage: 33201 km
Date: 2019.11.15
Time: 09:13:42
Component: TSG BF H03 0511
VCID: 46D5563FD8ADC237B05-8012
Fault Frequency: 13
Reset counter: 206
Mileage: 29920 km
Date: 2019.10.03
Time: 16:54:26
Part No SW: 4H0 907 801 N HW: 4H0 907 801 M
Component: EPB-4 H01 0020
Revision: -------- Serial number: 00000002431642
ROD: EV_ParkiBrake_VW51.rod
VCID: 33331FEBBBBF479F07B-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02202A130200
VCID: 34311CF7BEB140A71E1-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Part No SW: 4G1 035 020 J HW: 4G1 035 020 D
Component: MU-H-ND-EU 054 0910
Serial number: A735B0JS005423
Coding: 017562010000000013111102000A00002F0008E7F1700100DF
VCID: 2019E0A71A49CC07EA9-8074
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY809RDG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349RB7000GS
Component: Gracenote2 --- 1016
Component: TSG HL H03 0511
Coding: 010F14004021620002080002
VCID: 49CF5D03C9B32D4F5D7-801C
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000047163
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A0D028F6C750657B4D-807E
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0152
Revision: 14005003 Serial number: 024801591
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 363526FFA8CD52B7205-8062
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H28 0081
Revision: -------- Serial number: 262130025421000
Coding: E0140000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C01049766811867461-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813009250001
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU57.rod
End----(Elapsed Time: 02:16, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
