Results 1 to 3 of 3
Thread: Golf mk7
    Mar 2016
    Norway
    Golf mk7
    Hello,need help with the drl on this car..have not tried to delete any codes.
    can i find an explanation on the fault's somewhere?
    the trailer towbar was mounted by the dealer an there was som problems with the lights,they used 1 mnd to repair it..
    Nissan dealer
    thanks in advance
    Sunday,24,November,2019,16:06:57:06025
    VIN: WVWZZZAUZEW026228   License Plate: KZ61137
    Mileage: 87746km-54522mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 18 19 22 42 44 52 55 5F 69 A5
    VIN: WVWZZZAUZEW026228   Mileage: 87746km-54522miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EA    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5515
       Revision: 83H22---
       Coding: 0119001A034605082000
       ASAM Dataset: EV_ECM20TDI01104L906021EA 002003
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 6889B9D182F2A3D7617-803C
    7158 - Please Check DTC Memory in CAN Gateway (J533)
              U1008 00 [032] - -
              [Diagnostic interface for data busRead out DTC]
              U0428 00 [032] - -
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:27
                        Coolant temperature: 12 °C
                        Intake air temperature: 10 °C
                        Voltage terminal 30: 11.920 V
                        Unlearning counter according OBD: 28
    17156 - Databus
    17158 - Databus
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:28
                        Voltage terminal 30: 11.860 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
    21125 - Implausible Data Received from Airbag Control Module
              U0452 00 [032] - -
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 6151300000041F
       Coding: 01FA62A1242209720379070241CB2980462490C0E08294F3F4605074C009
       VCID: 074B9A6DAFAC4CAF88D-8052
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:28
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:38
       Part No SW: 5G0 907 044 AB    HW: 5G0 907 044 AB
       Component: Climatronic   H02 0705
       Revision: 00001K06
       Coding: 00020104204101011105000000101000
       VCID: 678BBAED8FECACAF68D-8032
    327943 - Position Sensor for Left Temperature Flap Motor
              B1094 15 [008] - Open or Short to Plus
                        Fault Frequency: 29
                        Reset counter: 245
                        Mileage: 82076 km
                        Date: 2019.10.07
                        Time: 15:12:10
                        Voltage terminal 30: 13.8 V
                        Outside air temperature: 7.0 °C
                        Interior temperature: 10.1 °C
                        Left temperature flap - actual value: 0.0 %
                        Left temperature flap - actual value: 239
                        Left temperature flap - specified value: 238
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011600500193
       Coding: 00060E46C24122FB4BE44000001C07081400000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 005981718A827B97C97-8054
       Component: WWS    130526  042 0551
       Serial number:         130529125036
       Component: RLFS  024 0042
       Serial number: Y13M06D05H16M43S16S4
       Coding: 00A8DD
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 205
                        Mileage: 87726 km
                        Date: 2019.11.20
                        Time: 09:11:20
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [008] - Electrical Failure
                        Reset counter: 219
                        Mileage: 85570 km
                        Date: 2019.11.01
                        Time: 13:56:12
    541204 - Databus
              [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert]
                        Reset counter: 233
                        Mileage: 87092 km
                        Date: 2019.11.17
                        Time: 00:43:01
    934149 - Rain/Light Recognition Sensor
              B1366 76 [008] - Wrong mounting position
                        Reset counter: 210
                        Mileage: 85572 km
                        Date: 2019.11.04
                        Time: 09:05:47
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231314501723
       Coding: 0071051101
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: 3B23369DA3E4D84FDC5-806E
    13637426 - Databus
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:29
       Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H03 0141
       Serial number: 29051376510319
       Coding: 00000D00FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001013
       VCID: 353720A585C00E3F2A1-8060
    7 Faults Found:
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:29
                        Control Module temperature: 1 °C
                        Voltage terminal 15: 11.5 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:29
                        Voltage terminal 15: 11.6 V
    1542 - Sensor for Automatic Distance Control
              [FAULT_RADAR_BLIND]
                        Fault Frequency: 20
                        Reset counter: 216
                        Mileage: 85610 km
                        Date: 2019.11.04
                        Time: 14:52:00
                        Control Module temperature: 24 °C
                        Voltage terminal 15: 14.3 V
                        Vehicle speed: 17.68 m/s
                        Acceleration: -0.10 m/s²
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:29
                        Voltage terminal 15: 11.7 V
    1043 - Automatic Distance Control
              B10E7 F0 [008] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 232
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:29
    1379 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [FAULT_V3LN_IS_OFF]
                        Reset counter: 90
                        Mileage: 63574 km
                        Date: 2019.01.14
                        Time: 17:07:35
                        Control Module temperature: 6 °C
                        Vehicle speed: 0.42 m/s
                        Acceleration: -0.16 m/s²
    1104 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Reset counter: 205
                        Mileage: 58062 km
                        Date: 2018.11.02
                        Time: 14:55:00
                        Control Module temperature: 25 °C
                        Voltage terminal 15: 12.4 V
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Serial number: 003M1R03865W
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4ACD6359FC3E71C7573-801E
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169667B06061370703
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169668B03061340670
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 905 13
       Serial number: 35767000000B43913D0T
       Subsystem 4 - Part No SW: -----------    HW: 480 002 905 13
       Serial number: 35867000000806503D0L
       Subsystem 5 - Part No SW: -----------    HW: 480 400 506 13
       Serial number: 35165029B10CBDF5236O
       Subsystem 6 - Part No SW: -----------    HW: 480 400 606 13
       Serial number: 3526502AD10CBDF1F1D%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 705 13
       Serial number: 3556502C5105EDD512FQ
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:30
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 28051308491271
       Coding: 0D00
       Shop #: WSC 12345 777 54321
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 7BA3F69DE364184F9C5-802E
       Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
       Component: KOMBI         252 2210
       Coding: 07A41800EF80000800886A03040000
       VCID: 270BFAED4F6C6CAFA8D-8072
       Part No SW: 5Q0 963 272 A    HW: 5Q0 963 272 A
       Component: STH-MQB       005 0066
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002012
       VCID: 34311DA18EBA17371DF-8060
       Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000000583753
    0036 - Fuel Level too Low
              P1250 00 [008] - -
                        Reset counter: 224
                        Mileage: 80187 km
                        Date: 2019.09.18
                        Time: 21:21:42
                        Operating condition of parking heater: Control mode
                        99
                        Coolant temperature of parking heater: 81 °C
                        Coolant temperature: 69 °C
                        Engine running status: detected
                        Fuel level: 8 l
                        Heater output: 4460 W
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000636047
       Coding: 030100040B087300EF00065E080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       Component: E221__MFL-DC1  H14 0035
       Serial number: 27130000597210083185
       Coding: 2C0000
       Serial number: 4994760603
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Component: Haldex4Motion H52 7076
       Serial number: HA1-00012.03.13
       Coding: 0001
       VCID: 46D55769E82695A7B3B-8012
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 01061302090088
       Coding: 003B0320D000048000001000
       VCID: 3FDB428DB7FCC46FF0D-806A
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001589273
       Coding: 11
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D273885BDF0D67FE21-8068
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 23051304080923
       Coding: 003B0120DE00048000801000
       VCID: 3E253F89B0F6CD67FBB-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001575324
       Coding: 090000
       Coding: 02AA00104F000200
       VCID: 40D94171CA02BB97897-8014
       Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 900000
       Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 900000
    5282321 - Supply Voltage for Variable Lighting Motor Sensor Left
              C109A 11 [008] - Short to Ground
                        Reset counter: 233
                        Mileage: 87092 km
                        Date: 2019.11.17
                        Time: 00:42:59
    13705995 - Databus
              [Kamera_Status: Fehlerwert im Signal Kamera_FDD_Funktionsstatus]
                        Reset counter: 205
                        Mileage: 58062 km
                        Date: 2018.11.02
                        Time: 15:00:31
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    040 0430
       Serial number: V7F02605130258
       Coding: 02730001FF00000011111201002800001F0100840100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       Component: ABT_Std_Nav  H44 0022
       Serial number: VWZ8Z9N340235D
       Subsystem 2 - Part No SW: 5G0 919 866 E    HW: -----------
       Component:  ECE 2013/14  --- 0034
       Part No SW: 5Q0 907 383     HW: 5Q0 907 383
       Component: Anheanger     H10 0030
       Serial number: 00006789276869
       Coding: 0100000200000000
       Shop #: WSC 00011 888 182020
       ASAM Dataset: EV_TrailFunctDemouHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: 74B1DDA1CE3A5737DDF-8020
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0050
       Serial number: 00000072647
       Coding: 0100020001020304000400000100000100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3A2D3399ACDEE147C73-806E
    6553600 - Databus
              [LH_EPS_03_BERECHN_LW_SIG_FAILURE]
                        Reset counter: 231
                        Mileage: 87064 km
                        Date: 2019.11.16
                        Time: 00:00:30
                        Control Module temperature: 0 °C
                        Outside air temperature: -1.0 °C
                        Vehicle speed: 0.00 km/h
                        Terminal 15 on: 3.5 s
    0646 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [suInvalidCodingFailure]
                        Reset counter: 205
                        Mileage: 58062 km
                        Date: 2018.11.02
                        Time: 14:54:59
                        Control Module temperature: 31 °C
                        Outside air temperature: 14.0 °C
                        Voltage terminal 15: 11.8 V
                        Terminal 15 on: 4.8 s
    End----------(Elapsed Time: 01:30, VBatt start/end: 14.5V/14.5V)-----------
    Please clear all faults and then see what comes back.
    I see now that this appears to be a duplicate thread. Closing this one. Carry on here:
    https://forums.ross-tech.com/showthread.php?20949
