Results 1 to 10 of 10
Thread: Audi tt Satnav enable
    Oct 2016
    16 reg. Car is fitted with CD player with satnav,but the satnav is not enabled. How do I go about enabling the sat nav, with vcds if this is possible.
    Quote Originally Posted by Radiosolutions View Post
    16 reg.
    Meaningless to anyone not in the UK, i.e. most of us. And even if one knows what it means, it does not reflect the model year with any degree of certainty.
    Please post an Auto-Scan.
  3. Likes NZDubNurd liked this post
    Oct 2016
    here is scan attached. been looking into this and been told unit in glovebox is fitted with satnav on this vehicle. just needs to be activated.
    Wednesday,04,December,2019,09:01:58:42542
    VCDS Version: 19.6.2.0
    VIN: TRUZZZFV7G1030000   License Plate: BT16XJG
    Mileage: 27419km-17037mi   Repair Order: harveys
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
    VIN: TRUZZZFV7G1030000   Mileage: 27419km-17037miles
    Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8S0 906 264     HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 0A1900322404010B3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208S0906264 001003
       ROD: EV_ECM18TFS0208S0906264.rod
       VCID: 76E3377DC96113FF8D-8022
    15170 - Engine Oil Temp. Sensor (G8)
              P0198 00 [032] - Signal too High
    15171 - Engine Oil Temp. Sensor (G8)
              P0196 00 [032] - Implausible Signal
    15072 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
    Readiness: 0010 0001
       Part No SW: 8S0 907 379 D    HW: 8S0 907 379 D
       Component: ESC           H42 0522
       Revision: 00000000    Serial number: 60676000000370
       Coding: 11AA108D1A9C15A940910064C291830640880858A8020043C16002
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
       ROD: EV_Brake1UDSContiMK100IPB_060.rod
       VCID: 428B9BADD529FF5FF1-8016
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0398911045
       Coding: 000F0F1620
       VCID: 3979FC41B8FFBC87A0-806C
       Part No SW: 8S0 820 047     HW: 8S0 820 047
       Component: AC Manuell el H05 0030
       Revision: 20009000    Serial number: 16010000009000
       Coding: 410040000011100000
       ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
       ROD: EV_AirCondiMAPrehAU33x.rod
       VCID: 70EF0165AB053DCF57-8024
       Operating and display unit 2 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
       Component: E775 BuA_2  H06 0010
       Serial number: 00000000000000006056
       Operating and display unit 3 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
       Component: E776 BuA_3  H06 0010
       Operating and display unit 4 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
       Component: E777 BuA_4  H06 0010
    262914 - Refrigerant Pressure
              B10AB F0 [008] - Too Low
                        Fault Frequency: 20
                        Reset counter: 192
                        Mileage: 25035 km
                        Date: 2019.10.23
                        Time: 04:32:36
                        Outside air temperature: 4.5 °C
                        Engine speed: 1533.00 /min
                        Compressor current: actual value: 0.00 A
                        Temperature after evaporator: 6.8 °C
                        Refrigerant pressure: 1.8 bar
                        System run time-Engine running time: 1 s
                        System run time-Terminal 15 on: 2 s
       Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0175
       Serial number: 01061607901866
       Coding: 07054C42C201067D03044004B31807A80880000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 04075DB58FBD316F83-8050
       Subsystem 1 - Part No SW: 8S2 955 119 B    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: 43x RL 151217  038 0371
       Serial number: 00000001512140304805
       Coding: 1BC7F7
       Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0004
       Serial number: 50047158
       Coding: 00005D
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 06 01 2016  00000551
       Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY1120001SN
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000065418027
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39291607400086
       Coding: 0000040001
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3C77E555B7CD89AFBB-8068
       Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
       Component: AirbagVW20    010 0870
       Serial number: 003M7R01AVU2
       Coding: 88CCF0C00C8000005C5000CFC0C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4D91B8911C7730271C-8018
       Subsystem 1 - Part No SW: -----------    HW: 480 002 903 16
       Serial number: 35700000000272817A1A
       Subsystem 2 - Part No SW: -----------    HW: 480 002 903 16
       Serial number: 35800000000662817A1E
       Subsystem 3 - Part No SW: -----------    HW: 480 010 402 16
       Component: SideSensor_Dr  004 0108
       Serial number: 351001A05D2D12333E92
       Subsystem 4 - Part No SW: -----------    HW: 480 401 411 16
       Serial number: 3550002C122E8E13A220
       Front Sensor Passenger:
       Subsystem 5 - Part No SW: -----------    HW: 480 401 111 15
       Serial number: 3560002B91D3F98222AF
       Pedestrian Protection Center:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 002 16
       Component: PedP_Sensor_C  001 6149
       Serial number: 2300002AF1F93A3102E4
       Subsystem 7 - Part No SW: -----------    HW: 480 002 405 17
       Serial number: I0M0000000014371242L
       Subsystem 8 - Part No SW: -----------    HW: 480 002 405 17
       Serial number: I0N000000000F2E8A42A
       Part No SW: 8S0 907 129 AF    HW: 8S0 907 129 AF
       Component: Lenks. Modul  H07 0150
       Revision: --------    Serial number: 91335PCN00754
       Coding: 0008
       ASAM Dataset: EV_SMLSKLOMQB 050001
       ROD: EV_SMLSKLOMQB_050.rod
       VCID: 7EF32F5DE1515BBFD5-802A
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8S0 920 790 A    HW: 8S0 920 790 A
       Component: FBenRDW       H35 0265
       Coding: 24050110298006000120A8809000800000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 377DFA798EEBAAF756-8062
       Part No SW: 8S0 907 468 C    HW: 8S0 907 468
       Component: GW MQB TT3    012 0246
       Revision: --------    Serial number: 22031610802300
       Coding: 030100042F025A004B000268080000000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 011003
       ROD: EV_GatewContiAU33X_011.rod
       VCID: 408F91A5DB25ED4FE7-8014
       Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
       Component: J453 MFL  H07 0002
       Serial number: 20160317062959 00824
       Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
       Serial number: 4265879103
       Serial number: 16000046403005
       Coding: 0100000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71E90461A00F34C758-8024
       Serial number: 100216EB905902
       Coding: 001042224001040100001402
       VCID: 43859EA9CA33F657FA-8016
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8103
       Serial number: 060216EB404786
    Address 55: Headlight Range (J745)       Labels:* None
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 03DE00102B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
       VCID: 3663F77D89E153FF4D-8062
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
       Part No SW: 8S0 035 020 F    HW: 8S0 035 020
       Component: MU-H-ND-EU    043 0413
       Serial number: A580C0GB004262
       Coding: 013304013C00000011111101000A00002F0000E3007000001A
       ASAM Dataset: EV_MUHig4CGen2HBAS 001115
       ROD: EV_MUHig4CGen2HBAS_AU37.rod
       VCID: 2B55D60942A31E1722-807E
       Multimedia Operating Unit:
       Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
       Component: ControlUnit_H  H22 0136
       Serial number: APVAK118011600010015
       Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1011
       Part No SW: 8S0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 160224200023
    End-------------------------(Elapsed Time: 04:31)--------------------------
    Dec 2016
    DE
    What makes you assume the car has a satnav installed?
    Oct 2016
    audi dealer says its possible, and also companys out there they they can do it by just sending them the unit out of glovebox. dealer says all audi tt new cars are equipped with the satnav.just needs activating.
    In most cases this would be a SWaP function which either requires a FEC code or a firmware hack...
    As petroldave said SWaP
    You need ODIS and online connection.
    I priced one a little while ago it was about £2000 for the activation!
  9. #8
    Quote Originally Posted by DGMotors View Post
    Google Maps/Nav on your phone is free.
  10. #9
    OP - do you have either Android Auto or Apple CarPlay enabled?
    I recently had a Toyota Corolla rental car, the Toyota map app wasn't enabled but Apple CarPlay was so I just used Apple Maps
  11. Likes Uwe liked this post
  12. #10
    The crazy thing is the Audi A3 activation for the same infotainment system is around £300
    Ive tried the A3 one on the TT and it doesn't work
    don't know why they charge a premium for the TT??
    Nav on your phone is the best option.
