Hi! We've got a Volkswagen Tiguan 2012 5N chassis code. We have a new genuine engine ECU that has been hardware coded from factory and we are trying to attempt the long coding (soft coding). We have retrieved the original long code from the original ECU however when this is entered it comes up with Error 31 coding rejected. Can anyone advise/assist?
Monday,25,November,2019,13:08:12:53838
VCDS Version: 14.10.2.0
Data version: 20150311
Dealer/Shop Name: matt
VIN: License Plate: ML61UMT
Mileage: 172340km-107087mi Repair Order:
Chassis Type: XX (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 4C 52 53 56 61
62 72 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 172340km-107087miles
2E-Media Player 3 -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 E HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9981
Revision: 41H28--- Serial number: XXXXXXXXXXXXXX
Coding: 00000000000000000000
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_ECM20TDI01103L906018E 003014
ROD: EV_ECM20TDI01103L906018E.rod
VCID: 2C50A5EF47D97941E27-8079
10 Faults Found:
4527 - Coolant Fan Control Circuit 1
P0480 00 [039] - Electrical Malfunction
Time: 00:00:00
4814 - System Voltage
P0562 00 [036] - Too Low
Mileage: 172341 km
Date: 2019.11.19
Time: 00:00:24
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
Time: 00:00:00
5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0045 00 [167] - Open Circuit
Mileage: 172341 km
Date: 2019.11.19
Time: 00:00:19
10095 - Engine Control Unit Incorrectly Coded
P0610 00 [167] - -
Mileage: 172341 km
Date: 2019.11.19
Time: 00:00:16
5040 - Fuel Injector #1 (N30)
P0263 00 [167] - Contribution/Balance Fault
Time: 00:00:00
5042 - Fuel Injector #3 (N32)
P0269 00 [167] - Contribution/Balance Fault
Time: 00:00:00
5045 - Fuel Injector #4 (N33)
P0272 00 [167] - Contribution/Balance Fault
Time: 00:00:00
5041 - Fuel Injector #2 (N31)
P0266 00 [167] - Contribution/Balance Fault
Time: 00:00:00
10529 - Engine Control Module Incorrectly Coded
P1612 00 [167] - -
Time: 00:00:00
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AH HW: 5N0 614 109 AH
Component: J104 C6 450M VDE7 0003
Revision: --H07--- Serial number: 00000005024844
Coding: 0040254
Shop #: WSC 01324 020 00200
VCID: 71EE749B687B54A9911-8024
Fault Frequency: 54
Reset counter: 231
Mileage: 172341 km
Date: 2014.04.07
Time: 00:00:46
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.50 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
00532 - Supply Voltage B+
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:22:09
Hex Value: 0x0000
Voltage: 7.50 V
Bin. Bits: 00011110
Count: 115
Hex Value: 0x0000
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:22:09
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004003
VCID: 7F0AA2A3E62F32D9175-802A
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 231
Mileage: 172341 km
Date: 2019.11.19
Time: 00:09:05
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 48180A3B8025F1C0400800C0340081E44B510088436D81606480C7000041
VCID: 3E749FA7A9A5FBD15C3-806B
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14111 013 0203
Coding: 009795
Component: RLS 241111 05 54 0403
Coding: 02304D
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:14:36
Term 15 On
Voltage: 8.30 V
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:20:49
Term 15 On
Voltage: 8.15 V
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:19:44
Term 15 On
Voltage: 8.60 V
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 61
Reset counter: 231
Mileage: 166252 km
Date: 2014.01.11
Time: 16:27:32
Term 15 On
Voltage: 12.35 V
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261132600129
Coding: 149203
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 4480ED4FCF4991010A7-8011
13635840 - Supply voltage
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:31
U1400 00 [008] - -
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:31
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__207 VW10 HI 1918
Revision: 23016000 Serial number: 003K0PPTBDLI
Coding: 0012343
VCID: 4C90C56F2F195941C27-8019
Subsystem 1 - Serial number: 6332MTS624123111
Subsystem 2 - Serial number: 6342MTS635533101
Subsystem 3 - Serial number: 6351HTS675F21AKJ
Subsystem 4 - Serial number: 6361HTS6RA4LV9KJ
Reset counter: 15
Mileage: 172341 km
Date: 2014.04.11
Time: 00:19:45
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20111119100505
Coding: 1082140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79FE4CBBF80B1CE9291-802C
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:21:08
136194 - Supply voltage
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:20:40
Part No SW: 5N0 920 982 D HW: 5N0 920 982 D
Component: KOMBI H04 0417
Coding: 411F01
VCID: 3566808B949338898D9-8060
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:45
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 221111F2002748
Coding: 356003
VCID: 3B7296B3BAB7EEF97BD-806E
Reset counter: 15
Mileage: 172341 km
Date: 2014.04.11
Time: 00:20:45
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4D96C86BD4035049D59-8018
00448 - Haldex Clutch Pump (V181)
Reset counter: 40
Mileage: 160635 km
Date: 2013.10.22
Time: 12:57:36
01155 - Clutch
Fault Status: 00100011
Reset counter: 13
Mileage: 171617 km
Date: 2014.03.27
Time: 19:58:07
Component: IMMO H04 0417
VCID: 6ADC63F78DADA771D0B-803F
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661368256
VCID: 295E5CFB402B6C69191-807C
Reset counter: 16
Mileage: 172341 km
Date: 2014.04.11
Time: 00:19:30
Reset counter: 16
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0504
Revision: 13110009 Serial number: 0003833310
Coding: 0202B4
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 387889BF8381C5E196F-806D
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C
Component: J389__TSG-HR 007 1504
Serial number: 00000006259767
Coding: 000090
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 230
65793 - Supply voltage
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:52
131329 - Rear Door Control Module
B11ED F0 [008] - Supply Voltage too Low
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:20:58
Part No: 5N0 909 144 N
Component: EPS_ZFLS Kl. 202 3301
Revision: 00H22000
Shop #: WSC 01324 785 00200
VCID: 3C7095AF7FB9E9C1727-8069
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.1 V
PD
Temperature: 11.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 4C: Tire Pressure II
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0504
Revision: 15110009 Serial number: 0003837384
Coding: 0202B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 397E8CBBB88BDCE9691-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C
Component: J388__TSG-HL 007 1504
Serial number: 00000006265346
Coding: 000090
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:52
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:20:41
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000444092
Coding: 0026167
VCID: 3566808B5C9338898D9-8060
03200 - Switch for Electric Parking Brake (E538)
Reset counter: 7
Voltage: 12.30 V
Count: 10
Hex Value: 0x0863
Hex Value: 0x0098
Hex Value: 0x1010
Reset counter: 231
Mileage: 172341 km
Date: 2014.04.11
Time: 00:21:09
Voltage: 8.00 V
Count: 48
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L6697942
Coding: 0100040004000C
VCID: 2C50A5EF4FD97941E27-8079
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Component: Batt.regelung H43 1623
Coding: 030F185A
VCID: 71EE749BA87B54A9911-8024
Component: J367-BDM H07 0180
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661379021
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 264457C759354311343-8073
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:20:09
U1400 00 [008] - -
Reset counter: 16
Mileage: 172341 km
Date: 2019.11.19
Time: 00:19:51
End-------------------------(Elapsed Time: 03:39)--------------------------
