Results 1 to 6 of 6
Thread: 2012 Tiguan ECU Error 31 coding rejected
    Nov 2019
    Hi! We've got a Volkswagen Tiguan 2012 5N chassis code. We have a new genuine engine ECU that has been hardware coded from factory and we are trying to attempt the long coding (soft coding). We have retrieved the original long code from the original ECU however when this is entered it comes up with Error 31 coding rejected. Can anyone advise/assist?
    Monday,25,November,2019,13:08:12:53838
    VCDS Version: 14.10.2.0
    Data version: 20150311
    Dealer/Shop Name: matt
    VIN:    License Plate: ML61UMT
    Mileage: 172340km-107087mi   Repair Order:
    Chassis Type: XX (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 4C 52 53 56 61
              62 72 77
    VIN: XXXXXXXXXXXXXXXXX   Mileage: 172340km-107087miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9981
       Revision: 41H28---    Serial number: XXXXXXXXXXXXXX
       Coding: 00000000000000000000
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_ECM20TDI01103L906018E 003014
       ROD: EV_ECM20TDI01103L906018E.rod
       VCID: 2C50A5EF47D97941E27-8079
    10 Faults Found:
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [039] - Electrical Malfunction
                        Time: 00:00:00
    4814 - System Voltage
              P0562 00 [036] - Too Low
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:00:24
    10065 - Mass Air Flow Sensor (G70)
              P0104 00 [167] - Intermittent
                        Time: 00:00:00
    5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
              P0045 00 [167] - Open Circuit
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:00:19
    10095 - Engine Control Unit Incorrectly Coded
              P0610 00 [167] - -
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:00:16
    5040 - Fuel Injector #1 (N30)
              P0263 00 [167] - Contribution/Balance Fault
                        Time: 00:00:00
    5042 - Fuel Injector #3 (N32)
              P0269 00 [167] - Contribution/Balance Fault
                        Time: 00:00:00
    5045 - Fuel Injector #4 (N33)
              P0272 00 [167] - Contribution/Balance Fault
                        Time: 00:00:00
    5041 - Fuel Injector #2 (N31)
              P0266 00 [167] - Contribution/Balance Fault
                        Time: 00:00:00
    10529 - Engine Control Module Incorrectly Coded
              P1612 00 [167] - -
                        Time: 00:00:00
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AH    HW: 5N0 614 109 AH
       Component: J104   C6 450M VDE7 0003
       Revision: --H07---    Serial number: 00000005024844
       Coding: 0040254
       Shop #: WSC 01324 020 00200
       VCID: 71EE749B687B54A9911-8024
                        Fault Frequency: 54
                        Reset counter: 231
                        Mileage: 172341 km
                        Date: 2014.04.07
                        Time: 00:00:46
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.50 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
    00532 - Supply Voltage B+
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:22:09
                        Hex Value: 0x0000
                        Voltage: 7.50 V
                        Bin. Bits: 00011110
                        Count: 115
                        Hex Value: 0x0000
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:22:09
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001004
       Coding: 0000004003
       VCID: 7F0AA2A3E62F32D9175-802A
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 231
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:09:05
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0064
       Revision: BC021001
       Coding: 48180A3B8025F1C0400800C0340081E44B510088436D81606480C7000041
       VCID: 3E749FA7A9A5FBD15C3-806B
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 14111  013 0203
       Coding: 009795
       Component: RLS 241111 05  54  0403
       Coding: 02304D
       Component: LIN BACKUP HO  H11 9005
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:14:36
                        Voltage: 8.30 V
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:20:49
                        Voltage: 8.15 V
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:19:44
                        Voltage: 8.60 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 61
                        Reset counter: 231
                        Mileage: 166252 km
                        Date: 2014.01.11
                        Time: 16:27:32
                        Voltage: 12.35 V
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261132600129
       Coding: 149203
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000_SE36.rod
       VCID: 4480ED4FCF4991010A7-8011
    13635840 - Supply voltage
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:31
              U1400 00 [008] - -
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:31
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__207 VW10 HI   1918
       Revision: 23016000    Serial number: 003K0PPTBDLI
       Coding: 0012343
       VCID: 4C90C56F2F195941C27-8019
       Subsystem 1 - Serial number: 6332MTS624123111
       Subsystem 2 - Serial number: 6342MTS635533101
       Subsystem 3 - Serial number: 6351HTS675F21AKJ
       Subsystem 4 - Serial number: 6361HTS6RA4LV9KJ
                        Reset counter: 15
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:19:45
       Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20111119100505
       Coding: 1082140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79FE4CBBF80B1CE9291-802C
       Coding: 820000
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:21:08
    136194 - Supply voltage
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:20:40
       Part No SW: 5N0 920 982 D    HW: 5N0 920 982 D
       Component: KOMBI         H04 0417
       Coding: 411F01
       VCID: 3566808B949338898D9-8060
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:45
       Part No SW: 7N0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway H43 1623
       Revision:   H43       Serial number: 221111F2002748
       Coding: 356003
       VCID: 3B7296B3BAB7EEF97BD-806E
                        Reset counter: 15
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:20:45
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4D96C86BD4035049D59-8018
    00448 - Haldex Clutch Pump (V181)
                        Reset counter: 40
                        Mileage: 160635 km
                        Date: 2013.10.22
                        Time: 12:57:36
    01155 - Clutch
                        Fault Status: 00100011
                        Reset counter: 13
                        Mileage: 171617 km
                        Date: 2014.03.27
                        Time: 19:58:07
       Component: IMMO          H04 0417
       VCID: 6ADC63F78DADA771D0B-803F
       Revision: A1001003    Serial number: 7661368256
       VCID: 295E5CFB402B6C69191-807C
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:19:30
                        Reset counter: 16
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0504
       Revision: 13110009    Serial number: 0003833310
       Coding: 0202B4
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 387889BF8381C5E196F-806D
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C
       Component: J389__TSG-HR  007 1504
       Serial number: 00000006259767
       Coding: 000090
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 230
    65793 - Supply voltage
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:52
    131329 - Rear Door Control Module
              B11ED F0 [008] - Supply Voltage too Low
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:20:58
       Part No: 5N0 909 144 N
       Component: EPS_ZFLS Kl. 202    3301
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       VCID: 3C7095AF7FB9E9C1727-8069
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.1 V
                            PD
                        Temperature: 11.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
    Address 4C: Tire Pressure II
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0504
       Revision: 15110009    Serial number: 0003837384
       Coding: 0202B4
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 397E8CBBB88BDCE9691-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C
       Component: J388__TSG-HL  007 1504
       Serial number: 00000006265346
       Coding: 000090
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:52
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:20:41
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000444092
       Coding: 0026167
       VCID: 3566808B5C9338898D9-8060
    03200 - Switch for Electric Parking Brake (E538)
                        Reset counter: 7
                        Voltage: 12.30 V
                        Count: 10
                        Hex Value: 0x0863
                        Hex Value: 0x0098
                        Hex Value: 0x1010
                        Reset counter: 231
                        Mileage: 172341 km
                        Date: 2014.04.11
                        Time: 00:21:09
                        Voltage: 8.00 V
                        Count: 48
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
       Component: Radio RCD510  050 0207
       Revision: 00000001    Serial number: VWZ1Z3L6697942
       Coding: 0100040004000C
       VCID: 2C50A5EF4FD97941E27-8079
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H43 1623
       Coding: 030F185A
       VCID: 71EE749BA87B54A9911-8024
       Component: J367-BDM  H07 0180
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661379021
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01719
       ROD: EV_UHVNA.rod
       VCID: 264457C759354311343-8073
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:20:09
              U1400 00 [008] - -
                        Reset counter: 16
                        Mileage: 172341 km
                        Date: 2019.11.19
                        Time: 00:19:51
    End-------------------------(Elapsed Time: 03:39)--------------------------
    Nov 2014
    New Zealand
    Many of the modules are reporting low voltage.
    You may have to install some more voltage before it will even attempt to write anything.
    If that isn't the issue, you don't really want to brick something with it shutting off half way through, do you?
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  3. Likes MartinsX, Uwe liked this post
    Quote Originally Posted by mtmservices1 View Post
    Five-year old software? Really?
    Yes, it appears to be legitimate, but still.. Software updates are free.
    You wouldn't happen to have a scan from this car when the old ECU was still in there for comparison purposes, would you?
    Lastly: Have you tried setting some different WSC, Importer, and Equipment number values?
    Nov 2019
    We've now updated to latest version. We can replug old ECU back in and get a code scan. In the meantime, how do we know what different WSC/Importer/Equipment number values we should change it to? Thanks for help.
    Nov 2016
    How was the new unit matched? If online with odis it would of also restored the soft coding too
    WSC etc is changed in the settings option, bottom right on the main vcds page, you can change to any random numbers, it is just some modules done like 001 etc when coding
    It is possible the new ecu is newer and different software, so the coding itself may be different, take a picture of each screen from the long coding options, and match the options selected on the new ecu
  7. Likes Uwe liked this post
    Jun 2014
    Poland
    Quote Originally Posted by rhinopower View Post
    XXXXXXXXXXXX = IMMO OFF
    post autoscan with old ECU
  9. Likes Uwe, MartinsX liked this post
