Results 1 to 4 of 4
Thread: A6 C7.5 Homelink retrofit
    Nov 2019
    I decided to retrofit Homelink garage door opener to my MY15 C7.5 A6. Got necessary parts from ebay (cable set, keypad and homelink transmitter), and installed those in place. I have access to Kufactec documentation, and done coding based on that:
    09 Central electrics: byte 20, bit7 -> 1, byte 23 bit 5 ->1
    46 Central conv: byte 6 bit 6 -> 1
    To addition I should somehow enable the visibility for homelink controls on MMI and this is usually done with green menu. On my car, the green menu is really limited compared to older models. So does anyone have a clue how those MMI menus for homelink can be enabled on facelifted models?
    Autoscan is available in here: https://forums.ross-tech.com/showthr...l=1#post183388
    Adaptation for [5F], try this:
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,                      activated
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,     not activated
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,         not activated
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high, not activated
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,          not activated
    and this:
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,                activated
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus, Comfort data bus
    And if different, Adaptation for [46], channel 20, value:
    1 if no MMI
    17 if MMI (you have this I guess)
  3. Likes Uwe, santti liked this post
    Nov 2019
    Thanks alot! This seems to do the trick! For some reason there wasn't anything on [46] channel 20, so ignored it, but those [5F] adaptations soleved the issue.
    Quote Originally Posted by santti View Post
    Sorry my mistake, it is channel 66
