Results 1 to 2 of 2
Thread: Advance Measuring Values some data errors
    Verified VCDS User Adamantos's Avatar
    Oct 2019
    Greece
    While was browsing the data i notice that some addresses giving me some weir values
    https://drive.google.com/file/d/1pb-...ew?usp=sharing
    https://drive.google.com/file/d/1ShV...ew?usp=sharing
    https://drive.google.com/file/d/17-m...ew?usp=sharing
    Tuesday,05,November,2019,17:22:13:15375
    VIN: WVWZZZAUZEP061565   License Plate:
    Mileage: 77498km-48155mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEP061565   Mileage: 77498km-48155miles
       Part No SW: 04L 906 021 N    HW: 04L 907 309 B
       Component: R4 1.6l TDI   H22 9213
       Revision: 84H22---
       Coding: 01250012032405092000
       Shop #: WSC 01050 207 00000
       ASAM Dataset: EV_ECM16TDI01104L906021N 002014
       ROD: EV_ECM16TDI01104L906021N_002.rod
       VCID: 3038EACBFAA09377797-8064
       Part No SW: 0CW 300 047 C    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5260
       Revision: 00043014    Serial number: CU501312075582
       Shop #: WSC 00028 028 00024
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 3B22CDE723E6602FDC5-806E
       Revision: 00000000    Serial number: 6351300000055A
       Coding: 01FA62A12426096D037C060641C82580462490C06082A4F300420078C209
       VCID: 7BA20DE76366A02F9C5-802E
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00020104200100011005004000101000
       VCID: 3828D2EB12D04B37317-806C
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011335101479
       Coding: 00001842C24100DB4BE44000000403081000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 79AE17EF695A923F8E9-802C
       Component: WWS    131206  042 0551
       Serial number:         131210114903
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 20597119
       Component: AirbagVW20    014 0386
       Serial number: 003MLR02EKR7
       Shop #: WSC 00028 028 00061
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5AF9F7777EBC0FB0D-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169667B16121371138
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169668B18121370663
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 012 13
       Serial number: 3576700000001CE48E0
       Subsystem 4 - Part No SW: -----------    HW: 480 002 012 13
       Serial number: 35867000000AC6587E05
       Subsystem 5 - Part No SW: -----------    HW: 480 401 312 13
       Serial number: 3516502C912FAE33109F
       Subsystem 6 - Part No SW: -----------    HW: 480 401 312 13
       Serial number: 35265029F12FAE3450BQ
       Subsystem 7 - Part No SW: -----------    HW: 480 401 312 13
       Serial number: 3556502C911FBE9231BT
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Component: Lenks.Modul   075 0135
       Revision: FF027027    Serial number: 20131209500494
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDAB9F737FE7C0FF0D-806A
       Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
       Component: KOMBI         252 2210
       Coding: 07A51A082380000800083A00040000
       VCID: 270A0197CF6ED4CFA8D-8072
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2163
       Revision: --------    Serial number: 18121310800419
       Coding: 030100040B087300EF00024C1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti_010.rod
       VCID: 3E24C4F330F47507FBB-806A
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H15 0038
       Serial number: 27130002077080123493
       Coding: 29FFFF
       Serial number: 0548092103
       Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
       Component: TSG FS        009 0014
       Serial number: 0000086218509
       Coding: 003003208000048000001000
       VCID: 42DCB003440C11E79F3-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003730843
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 0103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DEBF0F410A0AFF869-8014
       Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
       Component: TSG BFS       009 0014
       Serial number: 0000086394627
       Coding: 003001208600048000801000
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003724775
       Coding: 090000
       Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
       Component: MU-S--ER      040 0421
       Serial number: V1C02212130207
       Coding: 02730000FF00000011110001000800001F0100840100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H51 0022
       Serial number: VWZ8Z9NJ703JGV
    End----------(Elapsed Time: 01:00, VBatt start/end: 12.9V/12.9V)-----------
    Those are all generic OBD data types. Yes, they are kind of weird, but I'm fairly confident they are showing what they are supposed to based on the generic OBD specs.
  3. Likes PetrolDave liked this post
