Engine light (2005 Passat V6)
glkirk
C?ID=37343
Can anyone steer me in the right direction now please?
I have replaced the purge valve and installed a new gas cap seal, but the light still comes back on after 50 or so miles.
Thank you
Gary
Sunday,24,November,2019,12:44:19:08677
VIN: WVWRU63BX5P005880   License Plate:
VIN: WVWRU63BX5P005880   Mileage: 218590km-135825miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 DC
   Component: 2.8L V6/5V      G   0020
   Coding: 07551
   Shop #: WSC 00028
   VCID: 678B4783567FCA6F68D-5160
   WVWRU63BX5P005880     VWZ7Z0D9524430
16805 - Warm Up Catalyst; Bank 1
            P0421 - 35-00 - Efficiency Below Threshold
16815 - Warm Up Catalyst; Bank 2
            P0431 - 35-00 - Efficiency Below Threshold
16825 - EVAP Emission Control Sys
            P0441 - 35-00 - Incorrect Flow
   Part No: 3B0 927 156 CC
   Component: AG5 01V 2.8l5V  USA 0404
   Coding: 0001104
   Shop #: WSC 00028 028 00001
   VCID: 698F41BB456BFC1F7E9-5160
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04257
   Shop #: WSC 00028
   VCID: 25170D8BECF3187F9A1-51CE
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0006
   Coding: 17200
   Shop #: WSC 00028
   VCID: 280904BF9BE10517A17-5160
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 00028
   VCID: 2411108FE7C9E1778DF-513C
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F3BEFA3BE0F522F60D-5160
   Part No: 3B0 920 929 B
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 15235
   Shop #: WSC 00222
   VCID: 26150A8791F5136793B-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70B92CDF63B10DD7397-513C
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: °301
   Shop #: WSC 00000 065 00000
   VCID: 2F3BEFA3BB0F522F60D-513C
01008 - Note; Emergency OFF Switch is Active!
   Part No: 1C0 959 799 C
   Component: 09 Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   VCID: 372BD7C3465F9AEF38D-4B1E
   Subsystem 1 - Part No: 1C0959801
   Component: 09 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959802A
   Component: 09 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 09 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 09 Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 G
   Component:    Radio PM6        0016
   Coding: 04031
   Shop #: WSC 00028
End----(Elapsed Time: 04:04, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
glkirk
C?ID=37343
Respectfully Bump
Thank you
Gary
   Coding: 07551
   Shop #: WSC 00028
   Coding: 0001104
   Coding: 04257
   Shop #: WSC 00028
   Coding: 17200
   Shop #: WSC 00028
   Coding: 12345
   Shop #: WSC 00028
   Coding: 00118
   Shop #: WSC 00028
   Coding: 15235
   Shop #: WSC 00222
   Coding: 00006
   Shop #: WSC 00028
   Component: °301
   Coding: 00258
   Shop #: WSC 00028
   Coding: 04031
   Shop #: WSC 00028
Vehicle Identification No.WVWRU63BX5P005880
ModelPassat GLX sedan
PA
Date of production10.06.2004
Model year2005
Sales type3B35U5
Engine CodeATQ
Transmission CodeEZZ
Emission standard0GMEmission standard LEV 1
Is fuel PSI/volume adequate and what is amplitude tests on the PRE CATS in VCDS?
Vacuum leaks or any exhaust air leaks & did you isolate them all yet?
PARDON ME, HOWEVER, DID YOU HAPPEN TO ASK, CARB, EPA & VAG, WHY A FLASH UPDATE EXISTS VIA TPI OR TSB & FOR THE SAME EMISSIONS ABSTRACT FOR A4/A6/PASSAT ATQ ENGINES & FOR THE EXACT CAT/EVAP CODES ON OTHER ECU PART NUMBERS, HOWEVER, THIS ONE SLIPPED THROUGH THE CRACKS, SO AGAIN VAG, WHY IS THAT? :popcorn:
PART NUMBERPARDON .....MEDESCRIPTIONREMARKMODEL
* 3B0 907 551 DCVAG FART?Control unit for petrol engineATQ
Dropped on Oct 1, 2018, without replacement (EKZ: O)
glkirk
C?ID=37343
I guess I could find a way to make a smoke machine to prove no leaks. As I said, I did replace the purge valve.
Do you think it might be one of the (apparently) 4 O2 sensors?
Been here?
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
I would correct that first since it may have some influence on the mixture and thus the catalyst performance logic, but..
http://wiki.ross-tech.com/wiki/index.php/16805/P0421/001057
http://wiki.ross-tech.com/wiki/index.php/16815/P0431/001073
In the end, at 135,000 miles, you may indeed be looking at Cats that are shot.
On both sides, not so likely after rethinking this right?
How is the pre air filter screen, air filter and MAF or connecting boots to intake?
Please clear all fault codes and re-post a new fresh complete auto-scan after the car idles for 1 minute.
glkirk
C?ID=37343
The pre air filter screen might possibly be a bit dirty. You can certainly see through it.
I will carefully wash it with soap and water.
All the other large intake air connections seem to be good.
I cleared all codes, started it and let it run one minute.
Re scanned and here it is.
Not sure if I mentioned that after I changed purge, it seemed to go 40 miles before cel. After I changed gas cap seal, it seemed to go 50 miles before cel.
Thanks for the help!
Monday,25,November,2019,13:38:06:08677
Mileage: 218590km-135825mi   Repair Order:
   Coding: 07551
   Shop #: WSC 00028
Readiness: 0110 1101
   Coding: 0001104
   Coding: 04257
   Shop #: WSC 00028
   Coding: 17200
   Shop #: WSC 00028
   Coding: 12345
   Shop #: WSC 00028
   Coding: 00118
   Shop #: WSC 00028
   Coding: 15235
   Shop #: WSC 00222
   Coding: 00006
   Shop #: WSC 00028
   Component: °301
   Shop #: WSC 00000 008 00000
   Coding: 00258
   Shop #: WSC 00028
   Coding: 04031
   Shop #: WSC 00028
End----(Elapsed Time: 04:06, VBatt start/end: 12.7V/11.7V. VIgn 11.7V)-----
Well that's a good thing so far.
Is the N80 purge valve installed in correct direction?
Are there any exhaust leaks?
What are fuel PSI values?
Have you isolated all intake lines, PCV lines to engine and VC & including brake booster for vacuum leaks?
Have you done manual readiness tests to qualify each AECD sub system?
JPPSG
https://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
https://forums.ross-tech.com/showth...ases-and-vacuum-amp-so-should-you!-Air-leaks!
glkirk
C?ID=37343
I have found two hard plastic pipes at the rear of the engine under the throttle body.
They come off a barbed TEE with the other ends having a gasketed flange attaching to a metal component.
I am certainly going to replace them, but may ask you alls opinion if this could trigger the cel?
Thank you!
JPPSG
Thank you!
Couldn't any vacuum leak and what does the RTFB say?
https://erwin.vw.com/erwin/showHome.do
glkirk
C?ID=37343
So, I'm at my wits end.
I have been concentrating on hoses or pipes because I still have the burned oils smell at stoplights.
The oil seemes to be at the top of the valvecover!
I changed the valvecover gaskets. I dont see any leakage around the cam chain tensioners.
I only see the oil on the passenger side.
Surely someone has proved what causes this..........
The cel still comes on after about 50 miles. I was thinking I would try to take out the o2 sensors and test one at a time. Does anyone think that is a good idea?
Btw, the fault codes pertaining to the drivers door are probably because I replace that door switch/latch.
Any help would be appreciated.
Thanks.
Saturday,07,December,2019,14:10:19:08677
VIN: WVWRU63BX5P005880   Mileage: 218800km-135956miles
   Coding: 07551
   Shop #: WSC 00028
16725 - Camshaft Position Sensor (G40)
            P0341 - 35-10 - Implausible Signal - Intermittent
   Coding: 0001104
   Coding: 04257
   Shop #: WSC 00028
   Coding: 17200
   Shop #: WSC 00028
   Coding: 12345
   Shop #: WSC 00028
   Coding: 00118
   Shop #: WSC 00028
   Coding: 15235
   Shop #: WSC 00222
   Coding: 00006
   Shop #: WSC 00028
   Component: °301
   Coding: 00258
   Shop #: WSC 00028
00957 - Key 3
            09-10 - Adaptation Limit Surpassed - Intermittent
   Coding: 04031
   Shop #: WSC 00028
End----(Elapsed Time: 04:04, VBatt start/end: 11.6V/11.7V. VIgn 11.8V)-----
Have you looked for the oil is most likely from adjuster gaskets ( half moon ) or round seal plug behind camshafts, no?
Did you know you can qualify each OXS oxygen sensor in VCDS by doing readiness tests for the heater circuit and the probes readings?
Don't you think it would be best to sort EVAP code & check N80 or LDP for vacuum leaks?
Did you know if a vacuum leak exists it will affect the FPR in rail and throw off trims too sporadically?
glkirk
C?ID=37343
Thank you for your responce! I see oil on top of the valve cover. It looks like it must be being forced out- maybe one of the bolt holes. I have looked over the half moon and the rest of the camshaft area and saw no evidence of leak. I will look for the round seal plugs and examine them.
I have always hoped that by maybe finding a plugged line, that could be causing the pressure build up and force the oil out the top of the engine and the reason for the cel.
No, I did not know that, thanks, I will learn that proceedure!
I have replaced the N80 and all the plastic evap lines.
Is the LDP the components behind the heads on that 1/2" lines go into? I do not know what those components are or where the LDP might be? Could you help me understand those two questions?
Thanks again!
I drove the car for 20 miles and here is the scan. The cel has not come on yet.
Looks like no fault codes yet. I will do it again at 40 miles
Sunday,08,December,2019,11:29:11:08677
Mileage: 218850km-135987mi   Repair Order:
VIN: WVWRU63BX5P005880   Mileage: 218850km-135987miles
   Coding: 07551
   Shop #: WSC 00028
Readiness: 0000 0100
   Coding: 0001104
   VCID: 55F77D4BFC1348FFCA1-51CE
No Faults Found
   Coding: 17200
   Shop #: WSC 00028
   Coding: 12345
   Shop #: WSC 00028
   Coding: 00118
   Shop #: WSC 00028
   Coding: 15235
   Shop #: WSC 00222
   Coding: 00006
   Shop #: WSC 00028
   Component: °301
   Shop #: WSC 65536 065 00000
   Coding: 00258
   Shop #: WSC 00028
   Coding: 04031
   Shop #: WSC 00028
End----------(Elapsed Time: 04:03, VBatt start/end: 11.7V/12.1V)-----------
That last readiness test is EVAP/LDP, did you know they share that bit test & you can run them manually in VCDS?
0x01-04-070 EVAP
0x01-04-071 LDP
