Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Engine light (2005 Passat V6)
    Sep 2018
    So, I'm at my wits end.
    I have been concentrating on hoses or pipes because I still have the burned oils smell at stoplights.
    The oil seemes to be at the top of the valvecover!
    I changed the valvecover gaskets. I dont see any leakage around the cam chain tensioners.
    I only see the oil on the passenger side.
    Surely someone has proved what causes this..........
    The cel still comes on after about 50 miles. I was thinking I would try to take out the o2 sensors and test one at a time. Does anyone think that is a good idea?
    Btw, the fault codes pertaining to the drivers door are probably because I replace that door switch/latch.
    Any help would be appreciated.
    Thanks.
    Saturday,07,December,2019,14:10:19:08677
    VIN: WVWRU63BX5P005880   License Plate:
    VIN: WVWRU63BX5P005880   Mileage: 218800km-135956miles
    Address 01: Engine        Labels: 078-907-551-ATQ.lbl
       Part No: 3B0 907 551 DC
       Component: 2.8L V6/5V      G   0020
       Coding: 07551
       Shop #: WSC 00028
       VCID: 678B4783567FCA6F68D-5160
       WVWRU63BX5P005880     VWZ7Z0D9524430
    16825 - EVAP Emission Control Sys
                P0441 - 35-00 - Incorrect Flow
    16805 - Warm Up Catalyst; Bank 1
                P0421 - 35-00 - Efficiency Below Threshold
    16725 - Camshaft Position Sensor (G40)
                P0341 - 35-10 - Implausible Signal - Intermittent
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 35-00 - Efficiency Below Threshold
       Part No: 3B0 927 156 CC
       Component: AG5 01V 2.8l5V  USA 0404
       Coding: 0001104
       Shop #: WSC 00028 028 00001
       VCID: 698F41BB456BFC1F7E9-5160
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 04257
       Shop #: WSC 00028
       VCID: 25170D8BECF3187F9A1-51CE
       Part No: 3B1 907 044 J
       Component: CLIMATRONIC B5GP    0006
       Coding: 17200
       Shop #: WSC 00028
       VCID: 280904BF9BE10517A17-5160
       Part No: 1C0 909 605 C
       Component: 09 AIRBAG VW61 04   0003
       Coding: 12345
       Shop #: WSC 00028
       VCID: 2411108FE7C9E1778DF-513C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 00028
       VCID: 2F3BEFA3BE0F522F60D-5160
       Part No: 3B0 920 929 B
       Component: KOMBI+WEGFAHRSP VDO V04
       Coding: 15235
       Shop #: WSC 00222
       VCID: 26150A8791F5136793B-513C
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70B92CDF63B10DD7397-513C
    Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
       Part No: 3B1 959 760 E
       Component: °301
       Shop #: WSC 00000 065 00000
       VCID: 2F3BEFA3BB0F522F60D-513C
    01008 - Note; Emergency OFF Switch is Active!
       Part No: 1C0 959 799 C
       Component: 09 Komfortgerát HLO 0004
       Coding: 00258
       Shop #: WSC 00028
       VCID: 372BD7C3465F9AEF38D-4B1E
       Subsystem 1 - Part No: 1C0959801
       Component: 09 Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C0959802A
       Component: 09 Tőrsteuer.BF KLO 0202
       Subsystem 3 - Part No: 1C0959811
       Component: 09 Tőrsteuer.HL KLO 0202
       Subsystem 4 - Part No: 1C0959812
       Component: 09 Tőrsteuer.HR KLO 0202
    00957 - Key 3
                09-10 - Adaptation Limit Surpassed - Intermittent
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 G
       Component:    Radio PM6        0016
       Coding: 04031
       Shop #: WSC 00028
    End----(Elapsed Time: 04:04, VBatt start/end: 11.6V/11.7V. VIgn 11.8V)-----
  2. #12
    Have you looked for the oil is most likely from adjuster gaskets ( half moon ) or round seal plug behind camshafts, no?
    Did you know you can qualify each OXS oxygen sensor in VCDS by doing readiness tests for the heater circuit and the probes readings?
    Don't you think it would be best to sort EVAP code & check N80 or LDP for vacuum leaks?
    Did you know if a vacuum leak exists it will affect the FPR in rail and throw off trims too sporadically?
  3. #13
    Sep 2018
    Thank you for your responce! I see oil on top of the valve cover. It looks like it must be being forced out- maybe one of the bolt holes. I have looked over the half moon and the rest of the camshaft area and saw no evidence of leak. I will look for the round seal plugs and examine them.
    I have always hoped that by maybe finding a plugged line, that could be causing the pressure build up and force the oil out the top of the engine and the reason for the cel.
    No, I did not know that, thanks, I will learn that proceedure!
    I have replaced the N80 and all the plastic evap lines.
    Is the LDP the components behind the heads on that 1/2" lines go into? I do not know what those components are or where the LDP might be? Could you help me understand those two questions?
    Thanks again!
    I drove the car for 20 miles and here is the scan. The cel has not come on yet.
    Looks like no fault codes yet. I will do it again at 40 miles
    Sunday,08,December,2019,11:29:11:08677
    Mileage: 218850km-135987mi   Repair Order:
    VIN: WVWRU63BX5P005880   Mileage: 218850km-135987miles
       Coding: 07551
       Shop #: WSC 00028
    Readiness: 0000 0100
       Coding: 0001104
       VCID: 55F77D4BFC1348FFCA1-51CE
    No Faults Found
       Coding: 17200
       Shop #: WSC 00028
       Coding: 12345
       Shop #: WSC 00028
       Coding: 00118
       Shop #: WSC 00028
       Coding: 15235
       Shop #: WSC 00222
       Coding: 00006
       Shop #: WSC 00028
       Component: °301
       Shop #: WSC 65536 065 00000
       Coding: 00258
       Shop #: WSC 00028
       Coding: 04031
       Shop #: WSC 00028
    End----------(Elapsed Time: 04:03, VBatt start/end: 11.7V/12.1V)-----------
  4. Likes Jack@European_Parts liked this post
  5. #14
    That last readiness test is EVAP/LDP, did you know they share that bit test & you can run them manually in VCDS?
    0x01-04-070 EVAP
    0x01-04-071 LDP
