Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Audi Q7 (V8 TDI) DPF measuring blocks
    Nov 2019
    Sheringham, England
    Good morning gentlemen.
    Im brand new to vcds so please go easy on me!!
    I have just bought Hex v2 in order to look at my 2007 4.2tdi Q7 dpf situation. I have a dpf warning on the cluster display which wont clear from driving. Don't seem to have any fault codes associated with this. Im hoping that I can carry out a forced regeneration in order to try and clear it (two dpfs fitted!) if one is indeed blocked or otherwise diagnose the fault.
    My current problems are: From my understanding I cant look at the "advanced measuring blocks" function (greyed out) as my engine control module is an older format and as such I need to look at my dpf parameters via the "measuring blocks" function. I have tried many groups that I have found to be applicable from searching online. Problem is I cant seem to get any data from any group here. What am I doing wrong??
    I have a glow plug fault code. Could this be stopping the car from automatically cleaning the dpf, and thus caused the problem??
    Any help would be massively appreciated.
    Regards Ben.
    Sunday,24,November,2019,09:00:19:21534
    VIN: WAUZZZ4L97D103181   License Plate: OE07NKL
    Mileage: 304480km-189195mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1E 34 36
              37 3C 42 46 47 4F 52 56 57 61 62 67 69 6C 6D 6F 72 76 77
    VIN: WAUZZZ4L97D103181   Mileage: 304480km-189195miles
       Part No SW: 4L0 910 409     HW: 4E1 907 409 B
       Component: 4.2L V8TDI  G000AGMŖ0020
       Revision: --H04---    Serial number:
       Coding: 0011779
       Shop #: WSC 31414 790 00001
       VCID: 678BBC8E436895DF68D-8032
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 001 - Open Circuit
                        Fault Status: 01100001
                        Mileage: 304358 km
                        Date: 2019.11.19
                        Time: 09:40:00
                        RPM: 1008 /min
                        Torque: 147.8 Nm
                        Duty Cycle: 0.4 %
                        Voltage: 13.60 V
                        Duty Cycle: 27.6 %
                        Temperature: 6.3°C
       Part No SW: 09D 927 750 FE    HW: 09D 927 750 FE
       Component: AL 750 6A           1050
       Revision: 00H64000    Serial number:
       Coding: 0000504
       VCID: 76B5E1CA14C27C57E3B-8022
       Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
       Component: ESP ALLRAD MK25E1   0010
       Revision: 00H30001
       Coding: 0103585
       VCID: 290FFAB695FC63AFBE9-807C
                        Reset counter: 120
                        Mileage: 304484 km
                        Date: 2019.11.23
                        Time: 15:35:37
                        Count: 64
                        Count: 8261
                        Count: 128
                        Count: 42752
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100732192
       Coding: 0000151
       Shop #: WSC 00694 210 84841
       VCID: 6393A89EB750F9FFB45-8036
       Subsystem 1 - Part No: 4F0 910 131 G
       Component: FBSAUDIC6 KSG   H27 0080
       Subsystem 3 - Part No: 4F0 910 220 K
       Component: FBSAUDIC6 IDG   H01 0040
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Fault Status: 01111011
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory BFS  H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0078944
       VCID: 619FA296AD4CEBEFA69-8034
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731 D    HW: 4E0 035 729 A
       Component: Interfacebox    H43 3450
       Revision: 00000000    Serial number: 387DS077547013
       Coding: 0002002
       Subsystem 2 - Serial number: 00000001836152
       Subsystem 3 - Serial number: 0106.05.110000000100010535˙
       Subsystem 4 - Serial number: 010535˙
                        Reset counter: 153
                        Mileage: 304437 km
                        Date: 2019.11.21
                        Time: 08:58:37
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Revision: 00---012    Serial number: 00000000110632
       Coding: 0001048
    02508 - Temperature Sensor for Refrigerant (G454)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:05
                        Reset counter: 160
                        Mileage: 304479 km
                        Date: 2019.11.22
                        Time: 15:23:03
                        Temperature: 90.0°C
                        Temperature: 20.0°C
                        Temperature: -55.0°C
                        RPM: 1600 /min
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 14.0°C
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0111101
       VCID: 303917D2B6261267797-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 110 A    HW: 4L0 035 110
       Component: MP3-Changer     H43 0350
       Revision: 00043000    Serial number: AUZ5ZBG1055173
       VCID: 1D67DE66D1B48F0FC21-8048
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276V7100915
       VCID: 2411EB82F2DEBEC78DF-8070
    Address 11: Engine II        Labels: Redir Fail!
       Component: 4.2L V8TDI  G000AGSŖ0020
       Coding: 0011779
       Shop #: WSC 95147 753 45725
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH39 0120
       Revision: 06H39000    Serial number: 0037GD09BZPX
       Coding: 0013105
       VCID: 2C0103A29A0E768745F-8078
       Subsystem 1 - Serial number: 6332QSME216B1D01A
       Subsystem 2 - Serial number: 6342QSME28563119B
       Subsystem 3 - Serial number: 6352QSME2856264FP
       Subsystem 4 - Serial number: 6362QSME245A783FW
       Subsystem 5 - Serial number: 63734SME20647837
       Subsystem 6 - Serial number: 63834SME224B533B0
       Revision: 00H08000    Serial number: 90054071020272
       Coding: 0112142
       VCID: 6695B18A44628CD753B-8032
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H18 0170
       Revision: 00400000    Serial number: 5HJ14AH47
       Coding: 2593448
       Shop #: WSC 00011 888 96745
       VCID: 2313E89EF7D0B9FFF45-8076
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 D
       Component: Heizgeraet      H08 0080
       Revision: 0000000C    Serial number: 00000009014264
       VCID: 6099A792A646E2E7A97-8034
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D0732781C5
       Coding: F7DBFFDF747E02
       Shop #: WSC 00385 210 90017
       VCID: 6C81C3A25A8EB68705F-8038
    Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785     HW: 4E0 035 785
       Component: SG ext.Player H09 0170
       Revision: 00000000
       VCID: 6597B686B56487CF5A1-8030
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 C    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7660
       Revision: --H03001    Serial number: 15.1528-0096.2
       Coding: 0015520
       VCID: 2A0D05BA90FA68B7B73-807E
                        Reset counter: 158
                        Error Code: 13
    01577 - Turn-Off due to Over-Temp
                        Fault Status: 00100001
                        Reset counter: 160
                        Mileage: 304473 km
                        Date: 2019.11.22
                        Time: 14:52:28
                        Error Code: 68
       Component: Sitzmemory FS   H01 0100
       Coding: 0074858
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
       Component: MNS ECE         H49 1030
       Revision: 00000000    Serial number: 399D$077571393
       Shop #: WSC 00385 210 71556
       VCID: 3E2539EA7C72F417FBB-806A
    02927 - DVD Read Error
                        Reset counter: 160
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 14:06:29
                        Hex Value: 0x5DD7
                        Hex Value: 0xEBA0
                        Hex Value: 0x0401
                        Hex Value: 0x0000
       Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH07 0070
       Revision: 00H07000    Serial number: 6PZ 009 014-00
       Coding: 0011101
       VCID: 2D070EA6A1147F8F521-8078
       Subsystem 1 - Part No: 4L0 910 568 B
       Component: J0770_SWA_Slave_H06 0070
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F18.12.0600H0600000010121˙
       Subsystem 4 - Serial number: 010121˙
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0150
       Revision: 00-00000
       Coding: 0019163
       VCID: 2F3B14AEAB180D9F60D-807A
       Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
       Component: Komfortgeraet   H07 0040
       Revision: 0040 ---    Serial number: 01038117300000
       Coding: 7610619
       VCID: 333318DE4730297F045-8066
    03073 - Rear Lid Closed Sensor 1
                        Reset counter: 120
                        Mileage: 300688 km
                        Date: 2019.08.22
                        Time: 12:59:56
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H03 0150
       Revision: PROD_01     Serial number: 00000000027137
       Coding: 0000023
       VCID: 2809FFB28EF65AA7A17-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Revision:             Serial number: 00000000044557
       Coding: 0011101
       VCID: 5EE5996A9C32D4179BB-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0150
       Revision: 00-00000
       Coding: 0019163
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 388D4077617969
       VCID: 2E0509AAAC1204976BB-807A
    Address 57: TV Tuner
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000020235
       VCID: 6491AB82B25EFEC74DF-8030
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  205VA03B78
       Coding: 344530393135313035412056413032303556413033423738
       Shop #: WSC 00011 888 06946
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:00
                        Reset counter: 158
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:00
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0018442
       VCID: 313F12D6BD2C1B6F769-8064
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000703300389
       Shop #: WSC 12336 024 394758
       VCID: 363521CA54423C5723B-8062
    No Faults Found
    Address 69: Trailer        Labels: 4E0-910-383.lbl
       Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
       Component: ANHAENGERELEKTR 004 0060
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7342AL
       Coding: 1031001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD19.04.07--H21001001B0258˙
       Subsystem 4 - Serial number: 1B0258˙
       Revision: AAH05061    Serial number: 002658822-----
       Coding: 0003587
       VCID: 2615F18A84E24CD793B-8072
       Component: J_245_EE15_SKB09H10 0180
       Component: J_394_EE15_SKB09H10 0180
       Component: J_392_EE15_SKB09H10 0180
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0018442
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330710004718
       Coding: 0231146
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007652521
       Coding: 0010900
    End----------(Elapsed Time: 02:43, VBatt start/end: 13.9V/13.9V)-----------
  2. Likes Uwe liked this post
  3. #2
    Documentation for those V8 TDIs is rather rare. The fact that fact that VCDS shows "Redir Fail!" usually indicates that a label file exists in some language, but I'm not able to locate it at the moment.
    One thing I notice is that both your ECUs have software version 0020 and there is an 0040 available for them.
    Also at over 300,000 km, the DPFs are likely due for a manual cleaning or even replacement.
  4. Likes Dana liked this post
  5. #3
    Nov 2019
    Sheringham, England
    Jolly decent of you to respond to my thread Uwe. Interesting that you say data files for the v8 TDI are difficult to get hold of. Is that to say i wont be able to look at any engine control parameters other than generic fault codes?? or will i be able to somehow get vcds to work with my v8 tdi engine control system at some stage??
    Regarding the software update that you think might be available. Can this be done via vcds or are we talking main dealer??
    Regarding the dpf manual cleaning, If you think its the right thing to do, i will pull them both off the car and soak them in a bucket of industrial oven cleaner for a couple of days! does this sound like something that might work?? (really wish i could use vcds to see which, if either, was blocked- thats one of the reasons i bought it in the first place!)
    I am very grateful that you are prepared to give up/share your precious time and expertise to help. Top Man👍🏻
    Regards, Ben.
  6. #4
    Please stand by a bit until we've got our staff back in the office during the week. You can definitely see everything there is to see with standard measuring blocks, the only problem is that I don't know where to tell you to look.
    Nov 2019
    Sheringham, England
    Understood sir. I don’t mean to be impatient. Very appreciative of any advice that you can throw my way. Have a great evening...
  8. Likes Dana liked this post
  9. #6
    Did you know manual chemical cleaning or with block plate to pressure wash in reverse & with removal of oxygen sensors is also possible of the DPF's in the car too?
    Check out Wurth and Lubro-moly products.
  10. #7
    Nov 2019
    Sheringham, England
    Really appreciate the input Jack. frustrating that i cant currently look at the dpf parameters with vcds. However, Im determined to have a go at “deep cleaning” both filters if i cant get any diagnostics info. dont know what else to do really. I will look at your suggestions (they sound good) and formulate a plan. I am prepared to just remove them both and soak them in a bucket of something harsh. Regardless of manhours involved. But do you really think that there is a better option?? just want to give the process the best chance really.
    Very grateful to you guys for helping me out...
  11. #8
    Manual removal clean is always best but most labor intense.
    This is why I been coming up with beat the flat rate clock ideas & since my beginning of automotive time?
    I like to block turbo ports and EGR & reverse PSI into a reclamation tank & out the forward OXS sensors, filter it with strainer etc. then dispose of properly?
  12. Likes Dana liked this post
  13. #9
    OK, in ECU #2 at address 11:
    MVB #102: Exhaust gas cleaning Bank 1
    Field 1: EGT after Pre-cat
    Field 2: EGT before DPF
    Field 3: Pressure Difference across DPF
    Field 4: Differential Pressure Sensor Offset
    MVB #103: Exhaust gas cleaning Bank 2
    MVB #105: Particulate filter Bank 1
    Field 1: Oil Ash Volume
    Field 2: Soot Mass Calculated
    Field 3: Soot Mass Actual/Measured
    Field 4: Distance since last regen
    MVB #106: Particulate filter Bank 2
    Show us what you have there. :-)
  14. #10
    Nov 2019
    Sheringham, England
    HI. I'm really pleased that you have acquired this information Uwe- Awsome work. I will plug into the car first thing In the morning. Hopefully I can look at these parameters on ECU module #2. Fingers crossed. I will report back asap, hopefully with this data for you chaps to cast your eyes over. Be great if I can find out whats going on in there!
    Cheers Guys.
  15. Likes Dana, Uwe liked this post
