VIN: TMBAJ7NP6F7007261 License Plate:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 52
55 5F 69 6C 6D A5 BB BC
VIN: TMBAJ7NP6F7007261 Mileage: 152626km-94837miles
Address 01: Engine (J623-DDAA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 DR HW: 04L 907 309 M
Component: R4 2.0l TDI H22 1935
Revision: B4H22---
Coding: 011D0032047401083000
Shop #: WSC 59889 107 00000
ASAM Dataset: EV_ECM20TDI01104L906026DR 004005
ROD: EV_ECM20TDI01104L906026DR_004_SK48.rod
VCID: 7DB2E9FFEC2A43A7CC-8028
Part No SW: 0D9 300 041 B HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4803
Revision: 05853104 Serial number: TFK01504192409
Shop #: WSC 33361 790 00113
ROD: EV_TCMDQ250021.rod
VCID: 177EDB57EE5689F776-8042
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 61125000000507
Coding: 1D076A9C34200B730779060641C449B8562CD0E0608292F53861F0F8C2A9
VCID: 49DA4D2FE8622F0730-801C
Part No SW: 3Q0 959 435 A HW: 3Q0 959 435 A
Component: VWKESSYMQB 033 0524
Revision: 00033000 Serial number: 0363257405
Coding: 030C0C0703
ASAM Dataset: EV_KessyHellaMQBAB 004027
VCID: 383C38EB8388A68F5F-806C
Subsystem 1 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65015681
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 A HW: 3V0 907 044 A
Component: AC Automat H32 3501
Revision: 20K04000 Serial number: 00000B00002839
Coding: 11010104002100011005104000101100
ASAM Dataset: EV_ACClimaPrehVW37X 002007
ROD: EV_ACClimaPrehVW37X.rod
VCID: 32280AC365F44CDF61-8066
Subsystem 1 - Part No SW: 3V0 907 049 A HW: 3V0 907 049 A
Component: E265KlimaHeck H02 0101
Serial number: 00000000000000000000
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 168
Mileage: 152626 km
Date: 2019.11.23
Time: 17:56:00
Outside air temperature: 12.0 °C
Voltage terminal 30: 11.8 V
System run time-Terminal 15 on: 253 s
Air quality status: ERROR
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011511502438
Coding: 0C031E46C2472AFB4FC440040018172C0800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 004C900B9BD82E4FA7-8054
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 141125 032 0121
Serial number: 00000001411210600836
Coding: 165DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M05D06H09M39S14
Coding: 00084D
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 L HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0132
Serial number: ATW-00112.05.15
Coding: 0071167151
ASAM Dataset: EV_EPHVA2CAU3700000 008017
ROD: EV_EPHVA2CAU3700000_008.rod
VCID: 48DC482BF368D60F2F-801C
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 A HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0130
Coding: 326067DB54FFC428949C804C
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X.rod
VCID: 33260FC79AEE45D76A-8066
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H16 0115
Serial number: 03051541350088
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76A0F6D3C91C10FF8D-8022
Part No SW: 5Q0 959 655 AH HW: 5Q0 959 655 AH
Component: AirbagVW21 005 0125
Serial number: 003P0R000VJJ
Coding: 98CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 06408613B9FC007F9D-8052
Subsystem 1 - Part No SW: ----------- HW: 480 001 704 15
Serial number: 3570000000063AC0A31H
Subsystem 2 - Part No SW: ----------- HW: 480 001 604 15
Serial number: 358000000008F5D0A31S
Subsystem 3 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3510002B11A14CA3534X
Subsystem 4 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3520002AF1A14CA14251
Subsystem 5 - Part No SW: ----------- HW: 480 403 103 15
Serial number: 3550002B51A14CA1713
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 BA HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150508400915
Coding: 6010
ROD: EV_SMLSVALEOMQB.rod
VCID: 70ACC0CBAB783ECF57-8024
Part No SW: 3V0 920 711 HW: 3V0 920 711
Component: KOMBI 305 6421
Coding: 07A5011A7F840008018B7A0B5001000000000000
ROD: EV_DashBoardVDDMQBAB_SK48.rod
VCID: 6D92D9BFBC4AD3277C-8038
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 05051510800742
Coding: 0B0100344F087300EF00025A9C0F00010001070000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72A8CAC3A5740CDFA1-8026
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D1786270415
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 1314864703
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
Component: WECHSELRICHTE H53 0033
Serial number: 0076034
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000078210001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AAC5CFA07237C758-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006OCD17114
Coding: 001000000000010001A080808080000000008181000000D4
Shop #: WSC 33361 790 00061
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_001.rod
VCID: 3B3627E7B2BE8D97B2-806E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0363196756
Coding: 02012103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C3424FBB7B08AAFBB-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0362427474
Coding: 020121
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 050415BD417253
Coding: 001D0920DE00040000001100
VCID: 42C85A03D554FC5FF1-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial number: 0000131235
Coding: 01010011005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 A HW: 3Q0 035 466 A
Component: MIB2_amp_P_SK H02 0110
Revision: 00000001 Serial number: SKZ8Z1FAS0014AN
Coding: 0384010000AA002FAA0000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 2D1219BF7CCA13273C-8078
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 220315BCL06961
Coding: 001D0320DE00040000001100
VCID: 41CA550FD052E747E8-8014
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06D202007F010000
VCID: 40CC500BDB58EE4FE7-8014
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0013
Coding: B30000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0013
Coding: B30000
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 3V0 035 021 HW: 3V0 035 021
Component: MU-H-LND-EU H41 0200
Serial number: A433D0FB000509
Coding: 03840101000000001111120200880A102F0003E4012001009E
VCID: 6484BC9B6F80926F23-8030
Subsystem 1 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H44 1028
Serial number: SKZ8Z9RAM001EG
Subsystem 2 - Part No SW: V03 959 803 TF HW: -----------
Component: ECE 2019/2020 --- 0177
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1008
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 F HW: 5Q0 907 383 C
Component: Anhaenger H14 0137
Revision: 8B001002 Serial number: 0366647810
Coding: 0100000202000000
VCID: 3A3822E3BD84B49FA9-806E
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 04840101A700201F000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
VCID: 77BEFBD7CE1669F796-8022
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 E HW: 5Q0 959 107 E
Component: HDSG-Modul H12 0233
Revision: -------- Serial number: 29998437100000
Coding: 1088
ASAM Dataset: EV_DeckLidCONTIAU736 001009
ROD: EV_DeckLidCONTIAU736_AU73.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 653 C HW: 3Q0 980 653
Component: MQB_B_MFK H08 0060
Serial number: 21041511P10221
Coding: 020408010000040100222347C040A000980000100040
Shop #: WSC 39318 002 1048576
VCID: 362036D3899C50FF4D-8062
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Component: TSG HFS 020 0028
Serial number: 120415BDB01644
Coding: 001C01208000040000001100
Component: TSG HBFS 020 0028
Serial number: 120415BDB01672
End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
