Results 1 to 9 of 9
Thread: Passat b6 coding fog lights
    Oct 2018
    Romania
    hy i need help coding comfort module to activate FRONT fog lights i have send a scan of my car ,i have some maps that coding helper does not show me to enable or disable...i dont know what byte i need to modif.my fog light back is working.thank you all
    Tuesday,26,November,2019,10:46:16:28383
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZ6E010668   License Plate:
    Mileage: 234060km-145438mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 18 19 25 36 37 42 44 46 52 53 56 62 72
              76 77
    VIN: WVWZZZ3CZ6E010668   Mileage: 234060km-145438miles
    37-Navigation -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-021-BMM.clb
       Part No SW: 03G 997 021 J    HW: 028 101 211 9
       Component: R4 2,0L EDC G000SG  3898
       Revision: --H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 02723 512 00160
       VCID: 3039ECEE8625BE777A9-8064
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 K    HW: 3C0 614 095 K
       Component: ESP 440 C2     H014 0001
       Revision:  H014       Serial number: 0657057271
       Coding: 0013602
       Shop #: WSC 01681 111 29999
       VCID: 2A0DFE86A0F9C4A7B4D-807E
    02840 - Wake-Up Line from Central Convenience Module
                        Reset counter: 153
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 K    HW: 3C0 907 044 K
       Component: ClimatronicPQ46 041 0101
       Revision: 00041003    Serial number: 00000000000000
       VCID: 290F018AA5FFCFBFBD7-807C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000001937794
       Coding: A4008E2700041800641400641400000046087B4F5C
       Shop #: WSC 00046 412 688128
       Subsystem 1 - Part No: 3C1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 041206 022  0601
       Coding: 00049045
       Shop #: WSC 00046
       Part No SW: 3C0 909 605 A    HW: 3C0 909 605 A
       Component: 0B AIRBAG VW8   028 2321
       Revision: 06028000    Serial number: 0034ZS2YHXF%
       Coding: 0012354
       Shop #: WSC 05311 000 08193
       VCID: 241110BEC2DD12D78E1-8070
       Subsystem 1 - Serial number: 6332MSME35839680
       Subsystem 2 - Serial number: 6342MSMEE7F0B380
       Subsystem 3 - Serial number: 6351HTS62M72TIL2
       Subsystem 4 - Serial number: 6361HTS62M7U9OA3
       Subsystem 5 - Serial number: 6371VTS62M7IAM72
       Part No SW: 3C0 953 549 B    HW: 3C0 953 549 B
       Component: Lenksäulenmodul 004 0010
       Revision: 00004000    Serial number: 3C5953507E
       Coding: 0000111
       Shop #: WSC 05311 000 00000
       VCID: 2B03FB82AF03DDAF4FB-807E
       Component: Lenkradmodul    007 0050
       Part No SW: 3C0 920 870 A    HW: 3C0 920 870 A
       Component: KOMBIINSTRUMENT VD1 2926
       Revision: V0018000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 88888 121 92197
       VCID: 211F19AADDCF07FFE57-8074
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 H
       Component: Zuheizer        031 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Part No SW: 3C0 907 530 A    HW: 3C0 907 951 A
       Component: Gateway         006 0010
       Revision: 00006000    Serial number: 0500C0521402DB
       Coding: 3DFD1D44CE1002
       VCID: 1F1B1F52EBBB310FD33-804A
                        Fault Frequency: 190
                        Reset counter: 177
                        Mileage: 232674 km
                        Date: 2019.09.04
                        Time: 17:41:06
    01304 - Radio
                        Fault Frequency: 219
                        Reset counter: 177
                        Mileage: 232674 km
                        Date: 2019.09.04
                        Time: 22:07:21
       Part No SW: 3C0 959 433     HW: 3C0 959 433
       Component:    IMMO         038 0347
       Revision: 00038000    Serial number: VWZCZ000000000
       VCID: 678B47B2736B39CF6B3-8032
       Subsystem 1 - Part No: 3C0 905 861 A
       Component:    ELV          021 0350
       3C0905861A     ELV          021 0350
    02823 - Requirements for Locking the Steering Column Lock not met
                        Fault Status: 00110000
                        Reset counter: 153
                        Mileage: 233424 km
                        Date: 2019.11.05
                        Time: 22:02:23
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
       Component: Sitzverstellung     0601
       Revision: 00002000    Serial number: 00000000000000
    Address 37: Navigation
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2439
       Coding: 0000503
       VCID: 372BD7F2634B694F3B3-8062
    00100 - Drivers Interior Locking Button (E308)
    00941 - Exterior Mirror Retract Motor; Driver Side (V121)
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.12      1502
                        Mileage: 3960 km
                        Temperature: 57.0°C
                        Voltage: 7.20 V
                        Voltage: 7.00 V
       Component:    KSG PQ46 ELV 038 0434
       Coding: 00900A0801860E76380494157008CF09603D00
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0000502
       VCID: 3829D4CE6E556637329-806C
    00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
       Component: EPB  VC8HC001   012 0001
       Revision:   012
       Coding: 0000011
    Address 56: Radio
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2417
       Coding: 0000144
       VCID: 3333E3E27733856F07B-8066
       Part No: 1K0 959 704 F
       Coding: 0000144
       VCID: 3431E0FE723D82571E1-8060
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
       Component: Parkhilfe 8-Kan 004 0011
       Revision: 00004000    Serial number: 82930503600276
       Coding: 0000014
       VCID: 2809048EBEF5F6B7A29-807C
    Address 77: Telephone        Labels: 3C0-035-729.lbl
       Part No SW: 3C0 035 729 B    HW: 3C0 035 729 B
       Component: Telefon             4709
       Revision: 00006000    Serial number: 0000000004942
       Coding: 0016103
       VCID: 221D16A6D8C91CE7FCD-8076
    00385 - Positive Output Audio Channel for Speech/Telephone
                        Reset counter: 203
                        Mileage: 207901 km
                        Date: 2016.10.25
                        Time: 14:46:03
    00386 - Negative Output Audio Channel for Speech/Telephone
                        Reset counter: 203
                        Mileage: 207901 km
                        Date: 2016.10.25
                        Time: 14:46:03
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.6V)-----------
    Mar 2019
    Poland
    Hello, in central electric 09, select coding 07 then the long coding helper and select in it bayt 0 bit 0.
  3. Likes bonzo liked this post
    Oct 2018
    Romania
    i have bit 0 footwel light,america light,rain sensor....etc...i dont understand my car is a passat b6
    Oct 2018
    Romania
    i think i need decrypted bits that i have on vcds ,because i have bits 00 a lot...
    Mar 2019
    Poland
    Here's your code with the front fog lights; A5008E2700041800641400641400000046087B4F5C
  7. Likes bonzo liked this post
    I guess you have not installed the wiring to [09], then you will see there is no connection.
    You [09] does not support front fog lights.
    Coding is showed for the [09] that support it.
  9. Likes bonzo, Uwe liked this post
  10. #7
    Oct 2018
    Romania
    it say coding rejected ,the wiring is original ,i have changed the comfort module....because water have damaged the old one ,and i dont have the old coding....
  11. #8
    Jul 2014
    Tallinn, Estonia
    Module 09 is not known as "comfort module", but CECM (central electric control module). If you installed a midline CECM instead of previous highline CECM, you can't front fogs to work unless you change the module again to proper highline module.
    See table for what part number suffixes are highline (highend) -> https://www.my-gti.com/2269/volkswag...ol-module-cecm
  12. Likes Uwe liked this post
  13. #9
    Oct 2018
    Romania
    i have followed your advice i have buyed another unit highend and now the fog lights is working.thank you
  14. Likes Uwe liked this post
