Results 1 to 10 of 10
Thread: Immobilizer measuring blocks ERROR
    Dec 2017
    2001 TTQ has (recently) new battery. Worked OK for some time but now will not start. Has a 17978 Engine Start Blocked by Immobilizer code. Cleared the code and it doesn't come back after subsequent start attempts (also still doesn't start). Went to check the measuring blocks (link below) and it showed "ERROR: Group xxx Not Available" for the ones shown 022, 023, 024 and surfed around to discover some but all were ERROR. How can I see these values?
    Also, checked clutch switch and it changes state. Car key arms immobilizer when car is locked (red LED flashes). Will also try key #2 when I get my hands on it (currently it is out of town).
    And... any other advice for success (have not shorted battery cables together yet)?
    https://www.ross-tech.com/vag-com/ca...ng-blocks.html
    Please advise,
    Jon
    Are you checking those blocks in 25-Immobilizer? IIRC on that car, you need to look in 17-Instruments instead.
    Near Philadelphia, PA, USA
    Sorry to hear of your troubles. Could you post a complete autoscan of the TTQ please? We'd like to see what VCDS is seeing...
  4. Likes PetrolDave, MartinsX liked this post
    Dec 2017
    Good call and thank you, was incorrectly looking at 25. Here are results for 17-Instruments:
    Measuring Block - Values
    022 - 1114
    023 - 1116
    024 - 0000
    And scan:
    Sunday,01,December,2019,16:23:54:02845
    VIN: TRUWT28N211022421   License Plate:
    Chassis Type: 8N (8N - Audi TT (1999 > 2007))
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    Address 01: Engine        Labels: 06A-906-032-AMU.lbl
       Part No: 8N0 906 018 K
       Component: 1.8L R4/5VT     G   0003
       Coding: 06710
       Shop #: WSC 01236
       VCID: 392F2DA12049231FCD7-513C
       TRUWT28N211022421     AUZ5Z0YN153207
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18446
       Shop #: WSC 01236
       VCID: 3E253EBD39670427F85-4B00
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00140
       Shop #: WSC 01236
       VCID: 2809F8E5CBE3AA97A29-2580
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 1005
       Coding: 10103
       Shop #: WSC 01236
       VCID: 77ABEB9956DDF56FFB3-50F4
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N1 920 930 J
       Component: KOMBI+WEGFAHRS. M73 D55
       Coding: 02244
       Shop #: WSC 02101
       VCID: 382928A51B433A17329-4B00
    01039 - Coolant Temperature Sensor (G2)
                30-00 - Open or Short to Plus
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F1BE3399EAD6D2FD33-4B00
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267 A
       Component: Central Lock/Alarm  D05
       Coding: 15884
       Shop #: WSC 01236
       VCID: 3FDB43B93E6D0D2FF33-4F0C
    01616 - Signal Wire to Interior Monitor
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8N8 951 177
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 7CA1F4B56FFBD637961-50F4
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00010
       Shop #: WSC 01236
       VCID: 6597B1D1FC7177FF59F-5184
    End----(Elapsed Time: 02:38, VBatt start/end: 11.8V/11.7V. VIgn 11.6V)-----
  6. Likes Uwe liked this post
    Dec 2017
    Thank you, see above...
    Sep 2016
    Riga, Latvia
    Car does not crank or cranks but does not start?
  9. Likes Uwe liked this post
  10. #7
    Quote Originally Posted by Warmshoe View Post
    022 - 1114
    023 - 1116
    024 - 0000
    Does not seem to be an obvious problem with the immobilizer:
    That is not the immobilizer. That's the alarm, handled by 35 -- Centr. Locks
  11. Likes Jetta ,97 liked this post
  12. #8
    Dec 2017
    Quote Originally Posted by MartinsX View Post
    Does not crank
  13. #9
    Sep 2016
    Riga, Latvia
    In this model immo does not affect starter control.
    Check starter, wiring to it, IGN switch terminal 50.
  14. Likes Zenerdiode, Uwe liked this post
  15. #10
    I believe 35-Central Locking can keep it from cranking if it thinks the car has not been unlocked appropriately.
