Results 1 to 3 of 3
Thread: Esp Error b7 Passat 2011
    Pirate
    Nov 2019
    Hi all big fan of the forum and been very useful in the past. Although i thought it was time to register as I've got an issue i can't resolve.
    Got an esp error the other day. Wouldn't start at all.
    Did some research and found it might of been low battery voltage as was only 11.9v. Replaced the battery with a halfords start stop one (couldn't code it in though as there was no BEM no.?)
    Anyway seemed to start ok after changing it out.
    Next morning had the same esp fault again when turning ignition on.
    Lights on dash include the skidding car, parking brake and tyre pressure light flashing.
    Sometimes if i just wait for a little bit the coil light will pop up and disappear allowing me to start the car. Then it drives fine, switch off then on again and alll the errors have disappeared?
    Sometimes it shows start stop error as well as esp But when started and working the start stop works ok.
    First time i noticed this issue was morning after having the front os tyre resealed onto the alloy? (slow leak)
    Anyway scan is below and was hoping someone could point me in the direction of what needs to be checked/replaced.
    Fair few faults lol
    Thanks in advance.
    Removed.   Data from a clone/pirate copy of VCDS is not welcome here.
    May 2017
    Firstly, please post an unedited FULL autoscan with headers.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
    Let us know if/when you get one and we'll adjust your forum status.
  4. Likes downtime liked this post
