Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: VW caddy injectors
    Dec 2018
    Manchester UK
    VW caddy injectors
    Hi All
    Usual 1.6tdi Caddy problems 5 years old 30000 miles and three injectors gone.
    First cylinder 3, replaced under warranty.
    Second cylinder 2, new injector.
    Third cylinder 1, I thought i would try a reconditioned injector.
    The first two injectors no problem yet the third has left the engine noisy.
    There were no faults on auto-scan so i assume its ok not to post.
    I ran a Injection amount deviation, and this is were you guys come in and help me understand the values.
    I am i right in thinking cylinder 1 should be a similar deviation to the other cylinders
    	cylinder 1		cylinder 2		cylinder 3		cylinder 4
    	  mg/stroke		  mg/stroke		  mg/stroke		  mg/stroke
    	0.55	-1.5566		0.65	0.2349		0.77	0.4008		0.88	0.7722
    	1.45	-1.446		1.55	0.1155		1.65	0.5715		1.77	0.7707
    	2.3	-1.0988		2.4	0.0895		2.52	0.5609		2.62	0.7524
    	3.14	-1.4991		3.24	0.1247		3.37	0.4514		3.49	0.7242
    	4.02	-1.4918		4.14	0.0917		4.24	0.5484		4.37	0.7952
    	4.93	-1.1695		5.02	0.1166		5.14	0.6019		5.24	0.7729
    	5.8	-1.4054		5.93	0.1166		6.02	0.6088		6.14	0.574
    	6.71	-1.4716		6.8	0.1357		6.92	0.4576		7.02	0.7198
    	7.6	-1.5017		7.68	0.1199		7.8	0.5429		7.9	0.733
    	8.43	-1.1464		8.55	0.1254		8.65	0.5909		8.74	0.5744
    	9.3	-1.4823		9.42	0.1511		9.52	0.4418		9.65	0.6953
    Thursday,21,November,2019,15:18:10:05886
    VIN: WV1ZZZ2KZFX021268   License Plate:
    Mileage: 55860km-34709mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
    VIN: WV1ZZZ2KZFX021268   Mileage: 55860km-34709miles
    Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 TK    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9977
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00254014032500080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023TK 003001
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: 025E838A748E7EF7DF3-8056
       Part No SW: 0AM 300 065 M    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6560
       Revision: 00043014    Serial number: CU501406086579
       Shop #: WSC 49678 001 1048576
       VCID: 392C24665558FD2FCE9-806C
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 433C400D092403FBC20D02EA9021C081A1000020
       Shop #: WSC 35110 377 00144
       VCID: 7EA6F77A00F61A17BBB-802A
       Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
       Component: AC Manuell    H20 0607
       Revision: 00001004
       Coding: 0010004002
       VCID: 0748929E5FAC5BDF88D-8052
       Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
       Component: BCM PQ35 M+   122 0174
       Revision: BD122001
       Coding: 491A583E8025F16A088800829000016403017288524F8160648000000040
       VCID: 44D245922E9AB0C7ADF-8010
       Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 13051  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 2K0 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0004
       Revision: --------    Serial number: 32901417500455
       Coding: 108101
       ASAM Dataset: EV_EPHVA14VN3370000 001006
       ROD: EV_EPHVA14VN3370000.rod
       VCID: 70BAD9424A227C67397-8024
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag02Q H07 0013
       Revision: --------    Serial number: 003HL00RE4NN
       Coding: 000000000000000000000000000000003251
       VCID: 3534285675C0194F2A1-8060
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20190206300055
       Coding: 1892160000
       Shop #: WSC 01286 386 08256
       ROD: EV_SMLSNGVOLWS.rod
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0010626
       Coding: 830000
       Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
       Component: KOMBI         H03 0905
       Coding: 180800
       VCID: 3330164E7BB4077F045-8066
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 250614F2002453
       Coding: 357401
       Component: IMMO          H03 0905
       VCID: 6A8ECB2A6CFE86B7773-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000560
       VCID: 48CA51A21EB294A7417-801C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000560
       VCID: 47C8529E13AC9BDF48D-8012
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H05 5006
       Revision: -----09S    Serial number: VWZ4Z2P1257858
       Coding: 05000200010013
       VCID: 72BED34A44AE4E77CF3-8026
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666392933
       Coding: 0A01010000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C223D7256EAC807D5F-8068
    End----------(Elapsed Time: 01:08, VBatt start/end: 12.3V/12.2V)-----------
    Thanks Boothy
    Please post an auto-scan..........
    Quote Originally Posted by Boothy View Post
    It would still be helpful. There's a lot if info in an Auto-Scan besides just fault codes. Things like the exact ECU variant, the software version that the ECU has in it, and so on.
    Sep 2016
    Riga, Latvia
    Are all replaced injectors adapted/coded as required?
    Do the reconditioned one is reconditioned by qualified workshop having test stand and do it has got new trim code after repair?
  5. Likes Jack@European_Parts liked this post
    Is fuel for your region with Ethanol in the diesel fuel?
    Have you considered adding lubricants in fuel to support proper pump/injector function and an additional inline water separation trap, that can be drained periodically?
    https://www.theaa.com/driving-advice...nment/biofuels
    https://www.google.com/amp/s/www.aut...recourts%3famp
    Aug 2018
    Ireland
    In Ireland those are covered with lifetime warranty from VW provided software fix has been done.
    Dec 2018
    Manchester UK
    Thanks for the replies.
    All of the new injectors have been coded.
    The reconditioned injector has passed there in house calibration, although their data sheet showed it failed on the Flush and NOP (nozzle opening pressure) test.
    I did query theses failures and they said it would work fine.
    I do use a redex diesel additive and use Costco UK fuel.
    In the UK we are given two year warranty post fix.
  9. #8
    Sep 2016
    Riga, Latvia
    According Your log posted in first post injector for cylinder 1 may not be ok. To test try replacing it or swaping to another cyl.
  10. #9
    Ethanol in diesel? I don't think so, and this isn't the first time I've questioned it.
  11. #10
    Yeah I been questioning it too & almost on a daily, it seems fuel suppliers are indeed putting Ethanol in bio diesel and not even telling people it's bio diesel Uwe and sometimes with no ref to it in some regions at all, did you see the links?
