I have installed a new Climatronic Control Module (J255) in my Q7. I ran the Basic Settings but it still will not allow any of the functions work. Is there a security access code necessary?
Wednesday,20,November,2019,18:18:20:60779
VCDS Version: 19.6.2.0 (x64)
VIN: WA1VMAFE4DD003074 License Plate:
Mileage: 299890km-186343mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE4DD003074 Mileage: 299890km-186343miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H18 0012
Revision: 54H18--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 44723 002 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 224B98B035229A5F91-8076
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 001 3399
Coding: 001378
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7BF585D4F2080B97F2-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
Shop #: WSC 31414 790 00001
VCID: 34676EE857D604EF73-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702016240
Coding: 0000135
VCID: 254183ACEC0C6D67F4-8070
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000030251507
Coding: 00000001
VCID: 254183AC2C0C6D67F4-8070
Reset counter: 156
Mileage: 299899 km
Date: 2019.11.20
Time: 19:14:28
Bin. Bits: 01111
01487 - System Function Test
001 - Upper Limit Exceeded
Fault Status: 01100001
Reset counter: 156
Mileage: 299892 km
Date: 2019.11.20
Time: 11:43:51
02084 - Component Protection
Fault Status: 01100101
Reset counter: 0
Date: 2004.12.21
Time: 12:00:00
Reset counter: 156
Mileage: 299892 km
Date: 2019.11.20
Time: 14:56:16
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6ED3BC80797A6E3F45-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55901218600142
Coding: 25011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34676EE89FD604EF73-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD0A53F/
Coding: 0014131
VCID: 2B5575948AE85B1722-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME181C3E78T
Subsystem 3 - Serial number: 6342QSME181C21427
Subsystem 4 - Serial number: 6352QSME7F1A1472O
Subsystem 5 - Serial number: 6362QSME181C0842E
Subsystem 6 - Serial number: 63734SME2913487A2
Subsystem 7 - Serial number: 63834SME0E150E665
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H08000 Serial number: 90026121930043
Coding: 0012242
VCID: 285F8A989B1E700FCF-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGE526J7D
Coding: 8BD664040900CF05020205
VCID: 428B3830DD62BA5FF1-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M12705006A
Coding: 00C303
VCID: 3F8D31C4AE90D7B79E-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790770585
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000030251613
Coding: 0000006
VCID: 68DFCA985B9EB00F0F-803C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 156
Mileage: 299899 km
Date: 2019.11.20
Time: 19:14:33
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000033124566
Coding: 00581B00000011110000
VCID: 326B68F06DC20ADF61-8066
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E537C80B9FA2E3F05-807A
Component: J0770_SWA_Slave_H02 0050
Subsystem 3 - Serial number: 5F25.06.1200H020003C910239ÿ
Subsystem 4 - Serial number: 910239ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000034145418
Coding: 011F57205E40440004
VCID: 489F2A18FB5E900F2F-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01790062700000
Coding: 3569949
VCID: 387F5AD84BBEE08F5F-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000023382
Coding: 030000
VCID: 29598F9C40144907D0-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190190320
Coding: 0758477
VCID: 23459DB4E23893579A-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000114757
Coding: 0012001
VCID: 5EB3EC4089DAFEBFF5-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000034531975
VCID: 479D2924F6409F7726-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156G%0C7617518
Coding: 020007010000000000
VCID: 214997BC3824814788-8074
Part No SW: 4L2 035 746 A HW: 4L2 035 746 A
Component: H-BNT-NA H43 0552
Revision: -------- Serial number: 224H-0C7502945
Coding: 180200060004E3EF510023456F632003140000000100000000
VCID: 2C5776884FE65C2F2B-8078
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130GO0C2504239
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002030170
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000034585337
Coding: 010E57204040230004
VCID: 46832420F14A867FDD-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000179753559
Coding: 0200000000000000
VCID: 316967FC68C431C718-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H07--- Serial number: 525PA8-J2740V9
Coding: 1021201
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7B6884F669C2F6B-8038
Subsystem 2 - Serial number: .
ó
Subsystem 3 - Serial number: RD20.07.12--H57001002G0355ÿ
Subsystem 4 - Serial number: 2G0355ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 129056608-----
Coding: 0003595
VCID: 264384A0910A667FFD-8072
Component: J_245_EE16_SKB10H12 0220
Component: J_394_EE16_SKB10H12 0220
Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000034585319
End-------------------------(Elapsed Time: 03:43)--------------------------
No it is long coding in his Autoscan, see coding in OP Autoscan: 00000001Sorry, but didn't find any coding with 0304A06 .
Only numbers are used in this modules for coding
My understanding is that even brand-new modules need to be married to the CP constellation in the car.Is it typical that a new control unit would come with the Component Protection on it?
