Results 1 to 10 of 10
Thread: 2008 A8 D3 01044 - Control Module Incorrectly Coded
    Aug 2018
    Ireland
    I'm after installing this into my D3 A8 and it seems to work OK if a little erratically but when I ran a scan I got two faults -
    Address 0E: Media Player 1
    Address 19: CAN Gateway Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B081308038
    Coding: F5F99F7F507A0E00
    Shop #: WSC 11111 123 12345
    VCID: 2D070AA14117892F521-8078
    Reset counter: 64
    Mileage: 211271 km
    Date: 2019.11.16
    Time: 15:21:35
    Do I need to code the Gateway to inform it of the new device, or can I just check the box for Media Player 1 in the Gateway installation list and it can interrogate the device itself?
    Although I think the first step will be to tick the corresponding box in the Gateway's Installation List, it would be easier to evaluate what needs to be done if you would post a complete Auto-Scan.
    United States
    That sounds like a Media Player replacement but the Auto-Scan should shed light. If you saved one before the installation please post it as well.
    Aug 2018
    Ireland
    Pre-install scan is...
    Tuesday,22,October,2019,18:11:52:27508
    VIN: WAUZZZ4E68N012009   License Plate:
                    Address 53: Parking Brake       Labels: 4E0-910-801.clb
    Control Module Part Number: 4E0 910 801 D    HW: 4E0 907 801 B
      Component and/or Version: EPB  A4EC0230   H03 0230
               Software Coding: 0000221
                Work Shop Code: WSC 12345 111 45725
                          VCID: 2019E39506C55447E97-8074
    02596 - Rear Brake Pads Worn
                        Fault Status: 01111000
                        Reset counter: 248
                        Voltage: 5.90 V
                        Count: 61
    Address 53: DTCs cleared
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 0F 15 16 17 18 19 1E 28 34 36 37 38
              42 46 47 4F 52 53 55 56 61 62 67 72 76 77
    VIN: WAUZZZ4E68N012009   Mileage: 210130km-130568miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4E0 910 402 E    HW: 4E0 907 401 D
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H05---    Serial number: AUX3Z0H1342405
       Coding: 0011973
       Shop #: WSC 02313 785 00200
       VCID: 1E65DD6D3CB162B7DBB-804A
    012597 - Intake Manifold Runner Control
                   P3135 - 001 - Lower Stop not Reached
                        Fault Status: 01100001
                        Mileage: 210133 km
                        Date: 2019.06.18
                        Time: 01:23:21
                        RPM: 882 /min
                        Torque: 85.8 Nm
                        Voltage: 13.91 V
                        Duty Cycle: 89.2 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 80.9 %
    004120 - Intake Manifold Runner (Bank 2)
                   P1018 - 001 - Lower limit not reached
                        Mileage: 210133 km
                        Date: 2019.06.18
                        Time: 01:23:21
                        RPM: 882 /min
                        Torque: 85.8 Nm
                        Voltage: 13.91 V
                        Duty Cycle: 89.2 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 80.9 %
    Readiness: 0 0 1 1 1
       Part No SW: 4E1 910 156 Q    HW: 09L 927 156 A
       Component: AG6 09L 3,0 TDI RdW 0020
       Revision: --H01---    Serial number:        4421343
       VCID: 313F16D15D2FEDCF769-8064
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 J    HW: 4E0 614 517 BQ
       Component: ESP 5.7 allrad  H49 0540
       Coding: 0008357
       Shop #: WSC 02313 000 00000
       VCID: 2A0D01BD70F99E17B73-807E
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 907 181 A
       Component:     FBS AUDID3  H12 0200
       Revision: 02005112    Serial number: AUX3Z0H1342405
       Coding: 0412672
       Shop #: WSC 02311 785 00200
       VCID: 58E98B751E15DC87D17-800C
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3670112
       VCID: 2411EF8512DD48678DF-8070
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 769 P    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 343BG087603404
       Shop #: WSC 12345 111 45725
       VCID: 392F2EF1855F258FCE9-806C
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000057428
       Subsystem 3 - Serial number: 0107.02.080000000100010022˙
       Subsystem 4 - Serial number: 010022˙
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000142589
       Coding: 0018449
       VCID: 1C61D7652AAD70A735F-8048
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 7
                        Mileage: 210133 km
                        Date: 2019.06.18
                        Time: 01:23:28
                        Voltage: 13.80 V
    00065 - Rear Left Footwell Heater (Z42)
                        Reset counter: 7
                        Mileage: 210133 km
                        Date: 2019.06.18
                        Time: 01:23:29
                        Voltage: 13.90 V
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
       Component: ILM Fahrer      H16 0240
       Coding: 0143121
       VCID: 38292BF5BE553C87317-806C
       Subsystem 1 - Part No: 4E2 910 113 C
       Component: Wischer WWS D3  H60 0440
       Coding: 00000036
       Shop #: WSC 02313
       Component: REGENLICHTSENSORH04 0002
       Coding: 00139548
       Shop #: WSC 02313
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276V8201001
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 E    HW: 4E0 959 655 K
       Component:    Airbag 9.41  H01 4210
       Revision: 91H01421    Serial number: 003CU0009H4W
       Coding: 0431707
       VCID: 2809FBB56EF5AC07A17-807C
       Subsystem 1 - Serial number: 63328RB40385D5FB
       Subsystem 2 - Serial number: 63428RB40385D5F6Y
       Subsystem 3 - Serial number: 63528RB40385D620H
       Subsystem 4 - Serial number: 63628RB40385D4D3U
       Subsystem 5 - Serial number: 63729RB4036A343FR
       Subsystem 6 - Serial number: 63829RB4036A3447L
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
       Revision: 00H05000    Serial number: 90055080020110
       Coding: 0112041
       VCID: 2615F58D64E1BA7793B-8072
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 J    HW: 4E0 920 951 J
       Component: KOMBIINSTR. VDO H84 0620
       Revision: D03         Serial number: AUDID3H1100158
       Coding: 0000423
       Shop #: WSC 01190 210 175197
       VCID: 2C0107A57A0D802745F-8078
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
       Component: Heizgeraet      H08 0140
       Revision: 0000000C    Serial number: 00000009013887
       VCID: 1A6DD17D20990E97273-804E
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0390
       Revision: 00046002    Serial number: AUZ5ZBH4079611
       Part No SW: 4E0 910 158     HW: 4E0 919 158 C
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000020    Serial number: 00000000066686
       Coding: 0000000
       VCID: 619FA6914D4F1D4FA69-8034
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 K    HW: 4E0 907 553 H
       Component: LUFTFDR.-CDC    H07 4590
       Coding: 0015510
       VCID: 2B0304B97F03871F4C5-807E
       Component: Sitzmemory FS  H02  0010
       Coding: 3670122
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1060
       Revision: 00000000    Serial number: 364B$087757576
       Shop #: WSC 00121 210 90977
       VCID: 3B2334F98F63179FDC5-806E
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H05 0090
       Serial number: 00000802500105
       Coding: 0035968
       VCID: 1D67DA6131B779AFC21-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 802 F
       Component: Türsteuer.FS BRM005 0180
       Coding: 0028462
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
       Component: Komfortgeraet   H10 0030
       Revision: 00300010    Serial number:  W040802050195
       Coding: 0004317
       Subsystem 1 - Part No: 4E0 907 719
       Component: Neigungssensor  H05 0020
    Address 47: Sound System        Labels: Redir Fail!
       Part No SW: 4E0 910 224 B    HW: 4E0 035 223 H
       Component: Amp.-Basis      H41 0150
       Revision: 00000000    Serial number: 000000A7528223
       Coding: 0000013
       Shop #: WSC 00388 210 91840
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 D
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000018639
       Coding: 0010101
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 801 F
       Component: Türsteuer.BF BRM005 0180
       Coding: 0028462
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0000221
                        Reset counter: 248
                        Voltage: 5.90 V
                        Count: 61
       Part No: 8P0 907 357 H
       Coding: 0000006
       VCID: 3FDB40E99B7B0BBFF0D-806A
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 396B2087589646
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000002093
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  2802010529
       Coding: 344530393135313035412056413032383032303130353239
       Shop #: WSC 11111 111 45725
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
       Component: Türsteuer.HL BRM005 0180
       Coding: 0028462
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H46 0630
       Revision: 00000000    Serial number: 00000802010560
       Shop #: WSC 12336 024 394758
       VCID: 363525CDB441CAF723B-8062
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0028462
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08740802404001
       Coding: 0201008
       VCID: 2313EC9917D34F5FF45-8076
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 D    HW: 4F1 862 335
       Component: BTA             H10 1120
       Revision: 00H10000    Serial number: 00000007559681
       Coding: 0060001
       VCID: 2517F28119E7B16F9A1-8070
    End----------(Elapsed Time: 02:07, VBatt start/end: 13.9V/13.9V)-----------
    Aug 2018
    Ireland
    Post install scan is...
    Thursday,21,November,2019,00:18:00:27508
    Mileage: 211810km-131612mi   Repair Order:
    Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
              38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77
    VIN: WAUZZZ4E68N012009   Mileage: 211810km-131612miles
    0E-Media Player 1 -- Status: Not registered 0001
       Coding: 0011973
                        Fault Frequency: 130
                        Mileage: 210492 km
                        Date: 2019.11.03
                        Time: 22:02:15
                        Torque: 0.0 Nm
                        Voltage: 12.08 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 20.5 %
                   P1018 - 001 - Lower limit not reached - Intermittent
                        Fault Status: 00100001
                        Fault Frequency: 110
                        Mileage: 210492 km
                        Date: 2019.11.03
                        Time: 22:02:15
                        Torque: 0.0 Nm
                        Voltage: 12.08 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 20.5 %
    Readiness: 1 2 0 0 0
       Coding: 0008357
       Coding: 0412672
       Subsystem 1 - Part No: 4E0 905 852 E
       Component: ELV                 2040
       Coding: 3670112
       Coding: 0018449
                        Reset counter: 64
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:22:50
                        Voltage: 11.80 V
                        Fault Status: 00101100
                        Fault Frequency: 56
                        Reset counter: 118
                        Mileage: 211272 km
                        Date: 2019.11.16
                        Time: 19:50:13
                        Voltage: 13.70 V
       Coding: 0143121
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
       Coding: 0431707
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                        Fault Status: 11101010
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:17:07
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:17:07
       Coding: 0112041
       Coding: 0000423
                        Reset counter: 69
                        Mileage: 211442 km
                        Date: 2019.11.17
                        Time: 18:58:01
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 106
                        Mileage: 211323 km
                        Date: 2019.11.16
                        Time: 23:48:07
       Coding: 0000000
       Coding: 0015510
    01772 - Signal from Level Control Pressure Sensor (G291)
                        Reset counter: 119
                        Mileage: 211726 km
                        Date: 2019.11.20
                        Time: 23:02:44
       Coding: 3670122
       Coding: 0028462
       Coding: 0004317
       Coding: 0000013
       Coding: 0010101
       Coding: 0028462
    02129 - Automatic Day/Night Exterior Mirror
                        Fault Status: 00100111
                        Fault Frequency: 0
                        Reset counter: 105
                        Mileage: 211264 km
                        Date: 2019.11.16
                        Time: 19:53:20
       Revision: --H03---
       Coding: 0000221
                        Reset counter: 8
                        Voltage: 5.90 V
                        Count: 61
       Coding: 0000006
       Coding: 0028462
       Coding: 0028462
       Coding: 0201008
       Coding: 0060001
    End----------(Elapsed Time: 02:19, VBatt start/end: 12.5V/12.4V)-----------
    There is no 'Media Player 1' at all in the first scan, so the gateway now has detected a device at this device location on the bus and is wondering what's going on?
    Quote Originally Posted by dangerdred View Post
    Yep. So the first thing to try is:
    [Select]
    [19-CAN Gateway]
    [Installation List]
    Scroll down to 0E-Media Player 1 and put a check-mark in the box next to it, then:
    [Save Coding]
  7. #7
    Aug 2018
    Ireland
    I did the above and then cleared the code fro the gateway and ran a scan...
    Friday,22,November,2019,14:31:24:27508
    VIN: WAUZZZ4E68N012009   Mileage: 211870km-131649miles
       Coding: 0011973
                        Fault Frequency: 141
                        Mileage: 210492 km
                        Date: 2019.11.03
                        Time: 22:02:15
                        Torque: 0.0 Nm
                        Voltage: 12.08 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 20.5 %
                        Fault Frequency: 118
                        Mileage: 210492 km
                        Date: 2019.11.03
                        Time: 22:02:15
                        Torque: 0.0 Nm
                        Voltage: 12.08 V
                        Duty Cycle: 88.8 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 20.5 %
       Coding: 0008357
       Coding: 0412672
       Component: ELV                 2040
    00190 - Driver's Door Handle Touch Sensor (G415)
                        Fault Frequency: 7
                        Reset counter: 122
                        Mileage: 211808 km
                        Date: 2019.11.21
                        Time: 00:19:56
       Coding: 3670112
       Coding: 0018449
                        Reset counter: 64
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:22:50
                        Voltage: 11.80 V
                        Fault Frequency: 68
                        Reset counter: 82
                        Mileage: 211272 km
                        Date: 2019.11.16
                        Time: 19:50:13
                        Voltage: 13.70 V
       Coding: 0143121
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
       Coding: 0431707
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:17:07
                        Mileage: 211271 km
                        Date: 2019.11.16
                        Time: 15:17:07
       Coding: 0112041
       Coding: 0000423
       Coding: F5F99F7F707A0E00
       Coding: 0000000
       Coding: 0015510
                        Reset counter: 121
                        Mileage: 211726 km
                        Date: 2019.11.20
                        Time: 23:02:44
       Coding: 3670122
       Coding: 0035968
       Coding: 0028462
       Coding: 0004317
       Coding: 0000013
       Coding: 0010101
       Coding: 0028462
       Revision: --H03---
       Coding: 0000221
                        Reset counter: 8
                        Voltage: 5.90 V
                        Count: 61
       Coding: 0000006
       Coding: 0028462
       Coding: 0028462
       Coding: 0201008
       Coding: 0060001
    End----------(Elapsed Time: 02:06, VBatt start/end: 12.2V/12.1V)-----------
  8. #8
    Well, your CAN Gateway is happy now.
    I'm not sure what's up with the "Cannot be reached" on that Media Player module though.
    PS: Since this car did not have that module to begin with, I've moved this to Retrofits.
  9. #9
    Aug 2018
    Ireland
    ...PS: Since this car did not have that module to begin with, I've moved this to Retrofits.
    Thanks for the help.
    This car was never sold with this device so that's why I hadn't considered it a 'retro' fit.
  10. #10
    Apr 2016
    United Kingdom
    Where is its location within the most loop?
