Results 1 to 5 of 5
Thread: Touareg 2019 - No answer
    Nov 2018
    Europe - Hungary
    I can't read out a brand new 2019 Touareg. Only just gateway controller.
    What is the solution?
    Ignition was on (the engine not run)
    I lost a customer...
    Wednesday,20,November,2019,15:45:48:64377
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    Workshop Code: 790 73430 000063
    VIN:    License Plate: RMA-627
    Gateway Installation List:  4N2 907 468 AB
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    Chassis Type: 4N2
    Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 65 6C 6D
              74 81 A5 AC CA CB
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
    Address 06: Seat Mem. Pass
    Address 09: Cent. Elect.
    Address 13: Auto Dist. Reg
    Address 15: Airbags
    Address 16: Steering wheel
    Address 17: Instruments
       Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
       Component: Gateway       H14 0037
       Revision: 8P030005    Serial number: 0588P511319326
       Coding: 0301000300000E407F07000000DB05325A9E00071C000000037D078E10000100
       Shop #: WSC 31414 029 00001
       ASAM Dataset: EV_CGateCONTIAU491 003150
       ROD: EV_CGateCONTIAU491_003_AU58.rod
       VCID: 79AFEE9F2956E55F8E9-802D
       Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 39190000030640069044
       Coding: 2DFFFF
       Serial number: 2981111005
    Address 2B: Steer. Col. Lock
    Address 36: Seat Mem. Drvr
    Address 44: Steering Assist
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 65: Tire Pressure
    Address 6C: Back-up Cam.
    Address 6D: Trunk Elect.
    Address 74: Chassis Control
    Address 81: Gear Shift
    Address A5: Frt Sens. Drv. Assist
    Address AC: Reductant Control
    Address CA: Sunroof
    Address CB: Rear Axle Steering
    End----(Elapsed Time: 00:33, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
    We have other scans from 2019 Touaregs and they work just fine.
    I suggest you try a real PC instead of VirtualBox, which is an unsupported environment.
    Also try opening the hood.
  3. Likes Dana liked this post
    Jun 2017
    Touareg 3 is Audi.
    So open the hood and activate parking brake before doing VCDS.
  5. Likes Uwe, PetrolDave, Dana liked this post
  6. #4
    Nov 2019
    Australia
    Touareg 3 is Audi.
    Ditto. My Touareg won't give any readings unless i have the hood up. I'm pretty sure it is also mentioned in the VCDS HEX-V2 manual.
    2019 VW Touareg Launch Edition
    Reef Blue, Innovision Pack, Sunroof
    http://badges.fuelly.com/images/sig-metric/971321.png
  7. Likes Uwe liked this post
  8. #5
    Mar 2016
    Yep, new security feature on new models. Hood must be up
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
