Results 1 to 10 of 12
Thread: Passat B8 Led low to Led high retrofit problrm
    Verified VCDS User aXu's Avatar
    Nov 2019
    Hello everyone
    Need some help with GTE Passat. Factory installed headlights were LED Lows and now I have retrofitted those to OEM high ones. Adapters and aLWR module from Kufatec. Also coded with Kufatec-dongle.
    Problem is that the main beams and static cornering lights are not working at all. Dipped beams, dlr's and turn signals are ok. AFS fault is showing in MIB
    Any idea?
     Wednesday,20,November,2019,11:11:51:55961
    Dealer/Shop Name: T.R
    Workshop Code: 103 05311 000001
    VIN: WVWZZZ3CZGE160285   License Plate:
    Mileage: 63079km-39195mi   Repair Order: forum
    Chassis Type: 3C-VW48 (5QE)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 51 52 55
              5F 69 6C 75 8C A9 BB BC C6
    VIN: WVWZZZ3CZGE160285   Mileage: 63079km-39195miles
    Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
       Component: R4 1.4l TFS   H22 3379
       Revision: X3H22---
       Coding: 011D001A647405083000
       Shop #: WSC 40850 222 12345
       ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
       ROD: EV_ECM14TFS_006_VW48.rod
       VCID: 6695B68ED8EA64A753B-8032
    Readiness: 1110 0001
       Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1601
       Revision: 00031033    Serial number: TFK01511280148
       Shop #: WSC 40850 222 00000
       ROD: EV_TCMDQ400021_VW37.rod
       VCID: 382928F6C2DE2257317-806C
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 3Q0 907 379 S    HW: 3Q0 907 379 G
       Component: ESC           H42 0823
       Revision: 00000000    Serial number: 63425000000230
       Coding: 0FEC408F3826336C0779060841C849F0021CCCE0608292F118A1F078C202
       Shop #: WSC 45182 002 1048576
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
       ROD: EV_Brake1UDSContiMK100OMG_002.rod
       VCID: 4ACD623EAC32A0C7573-801E
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0392284624
       Coding: 000F0F0F03
       Shop #: WSC 05311 115 00300
       VCID: 392F2DF2F9D43B5FCE9-806C
       Part No SW: 5GE 907 044 E    HW: 5GE 907 044 E
       Component: Climatronic   H04 1301
       Revision: 00001K07
       Coding: 1202100420010101001550000010180A
       Shop #: WSC 00015 115 08193
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       VCID: 3E253EEEE0FA1C67FBB-806A
       Subsystem 3 - Part No SW: 3Q0 963 231 A    HW: 3Q0 963 231 A
       Component: J848 HV-PTC  200 0202
       Serial number: -00100.2T.1B20340259
       Air quality sensor:
    H02
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580601161522
       Coding: 00031C46C3D102F72F8C5094B13C07381C80000000000000000000000000
       Shop #: WSC 17873 123 50804
       ROD: EV_BCMBOSCH_015.rod
       VCID: 03538F1ACB98B18FD45-8056
       Component: WWS    151208  042 0607
       Serial number:         160109213215
       Component: RLHS  037 0059
       Serial number: S3Y16M01D13H20M57S48
       Coding: 90A8DD
       Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
       Serial number: 27 10 2015  10001293
       Serial number: 000000000ZY153210SL3
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000064437426
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391601204423
       Coding: 0071151911
       Shop #: WSC 05311 115 00093
       VCID: 44D14C068E1676B7ADF-8010
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0192
       Coding: 5200678A11FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311CC6DEB6C6371DF-8060
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR01SDR7
       Coding: 88CCC000002000005C5400CF004800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50F970564A6E9A17197-8004
       Belt Pretensioner left:
       Serial number: 3G1857705G0156Q01110
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 3G1857706G0183Q00202
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 000 601 16
       Serial number: 35700000000F0924281D
       Subsystem 4 - Part No SW: -----------    HW: 480 000 601 16
       Serial number: 35800000000739242819
       Subsystem 5 - Part No SW: -----------    HW: 480 401 012 15
       Serial number: 35100029B1E3EAA41316
       Subsystem 6 - Part No SW: -----------    HW: 480 401 012 15
       Serial number: 3520002AF1E3EAA2E22N
       Subsystem 7 - Part No SW: -----------    HW: 480 402 909 16
       Serial number: 3550002A1229A29501E.
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160114500578
       Coding: 0410
       Shop #: WSC 00015 115 00001
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D2739E2EDFC077FE21-8068
       Part No SW: 3G0 920 794 D    HW: 3G0 920 794 D
       Component: KOMBI         401 4191
       Coding: 07AD0B182FC000080C886F111600002000000000
       VCID: 2D0709A23D9C97FF521-8078
       Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
       Component: STH-MQB       007 0072
       Coding: 13C1
       Shop #: WSC 15486 002 1048576
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001301585
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3245
       Revision: --------    Serial number: 12011610800494
       Coding: 020300172EF21000FF00527E5C1F00000001070100010000000300000000
       Shop #: WSC 05311 103 00001
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013.rod
       VCID: 48C95836B23E52D7417-801C
       Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Serial number: 29150002460490115504
       Coding: 2DFFFF
       Subsystem 2 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 5543008303
       Analog clock:
       Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430011074
       Coding: 05720100431900020002060500
       Shop #: WSC 17300 205 00000
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
       VCID: 4FFB732A575085EF00D-801A
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861141215125525
       Serial number: 15000180983012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD5D2E124B31F369-8024
       Serial number: 101115BK904191
       Coding: 003F0E208000028000001000
       VCID: 43D34F1A8B18718F945-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000569007
       Coding: 01000010005101
       Shop #: WSC 00015 115 00300
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       Part No SW: 3G0 907 080 E    HW: 3G0 907 080 D
       Component: LE Gen 3.3H10 0072
       Revision: 00H10000
       Coding: C0020000000000000000
       Shop #: WSC 09502 002 1048576
       ASAM Dataset: EV_DMCM08530113G0907080E 001017
       ROD: EV_DMCM08530113G0907080E.rod
       VCID: 270BFB8A1F60BDAFA8D-8072
       Serial number: 071115BK611649
       Coding: 003F00208000028000001000
       VCID: 42DD4A1E940278879F3-8016
       Component: AFS-ECU       H01 0120
       Coding: 039A00000F200200
       VCID: 3FDB43EAE7F0156FF0D-806A
       Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Coding: E02400
       Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    5545009 - LED Headlamp Power Output Stage; Left
              B149C 31 [137] - No Signal
                        Reset counter: 58
                        Mileage: 63079 km
                        Date: 2019.11.20
                        Time: 11:04:37
    5544753 - LED Headlamp Power Output Stage; Right
              B149B 31 [137] - No Signal
                        Reset counter: 58
                        Mileage: 63079 km
                        Date: 2019.11.20
                        Time: 11:04:37
       Part No SW: 5NA 035 022 D    HW: 5NA 035 022
       Component: MU-H-LND-EU   H55 1367
       Serial number: A846J0JS022231
       Coding: 028482010000000051110001008808101F0109F441A002009C
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H50 9120
       Serial number: VWZ6ZHT1600142
       Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2  --- 1017
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0203
       Revision: 8A001003    Serial number: 0392243933
       Coding: 0100000202000000
       VCID: 3B2337FAF3E8094FDC5-806E
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 0184020163002217000041
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
       VCID: 77ABEBCA8F40ED2FF8D-8022
       Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
       Component: OCULowMQBEU   012 0715
       Coding: 0284720110169A0300F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
       Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
       Component: K8C           H05 0520
       Serial number: 20111515010233
       ASAM Dataset: EV_BECM09620213Q0915227P 002009
       ROD: EV_BECM09620213Q0915227P.rod
       Battery Junction Box:
       Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
       Component: A2 HVSMBJBECU  H08 0410
       Serial number: 00000007111514010009
       Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC1  H04 0442
       Serial number: 15914ZKK311A01040871
       Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC2  H04 0442
       Serial number: 15914ZKK311A01040670
       Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC3  H04 0442
       Serial number: 15914ZKK311A01041076
       Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC4  H04 0442
       Serial number: 15914ZKK311A01040384
       Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC5  H04 0442
       Serial number: 15914ZKK311A01040248
       Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC6  H04 0442
       Serial number: 15914ZKK311A01040322
       Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC7  H04 0442
       Serial number: 15915ZKK311A01040183
       Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC8  H04 0442
       Serial number: 15917ZKK311A01040047
       Part No SW: 3G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 151116200427
       VCID: 698FBDB2C9F44BDF7E9-803C
       Serial number: 091215BL901256
       Coding: 000E00200100028000001000
       Shop #: WSC 13623 002 1048576
       VCID: 45D75102852C4FBFBA1-8010
       Serial number: 091215BL901253
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
       Component: OBC KOSTAL    H31 4006
       Revision: --------    Serial number: 0607160G40004D
       Coding: 115068222000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
       ROD: EV_OBCSinglPhaseKLOMQB11P.rod
       VCID: 57EB8B4A6F80CD2FD8D-8002
    End----------(Elapsed Time: 02:24, VBatt start/end: 13.2V/13.2V)-----------
    Jul 2014
    Tallinn, Estonia
    https://www.kufatec.com/en/volkswage...assat-b8-42225 <- this adapter?
    High LED headlights have CAN between the lights and module 55, which is missing a couple of submodules. Are you sure you connected the CAN twisted pairs to the correct LWR module pins?
    Module 55 should also show submodules as follows:
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
  3. Likes Uwe liked this post
    Nov 2019
    Thank's for your reply.
    Yes, that's same adapter I have. And yes I am sure about CAN-connections. If I disconnect for example CAN-high wire connected to LWR pin 4, I will lost all submodules. I have tried this also.
    If I disable "multifunction LED" bit on HEX55, I will get all four submodules visible with no faults. For some reason SW and HW information is not recognized.
       Coding: 039A00000F030200
       Subsystem 1 - Part No SW: ID-L fehlt     HW: -----------  Labels: ID-55-01.CLB
       Component: LED LeiMo li.  ... ....
       Coding: FFFF00
       Subsystem 2 - Part No SW: ID-R fehlt     HW: -----------  Labels: ID-55-02.CLB
       Component: LED LeiMo re.  ... ....
       Coding: FFFF00
       Coding: E02400
       Coding: E02400
    Nov 2019
    Anyone? I’m in stuck with this.
    May 2017
    I have an autoscan from a friends GTE Passat with factory fit high leds. This is what it says about 55 module :
       Coding: 039A00004F210200
       Shop #: WSC 05311 000 08193
       VCID: 3FB4CDB6A63574BEB3-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Coding: E02400
       Coding: E02400
    Coding at least seems different than on your car.
    I would check the wiring as well. Kufatec's adapters are very popular in having incorrectly connected pins.
  7. Likes m87a, PetrolDave liked this post
    Jun 2017
    Quote Originally Posted by aXu View Post
       Coding: FFFF00
       Coding: FFFF00
       Coding: E02400
       Coding: E02400
    I read about that issue before.
    The submodules are either wrong, or have no parameters.
    I assume the LED modules are brand new??
    Nov 2019
    Non functional modules are brand new and labelled: 7PP 941 572 AB. Thats correct one according to ETKA... BUT there is two variants with same part number, 7PP941572AB Z01 (to 11/2016) and another one ending Z08 (from 11/2016)
    At the same time AFS module 55 was changed to multifunction module 4B. My car is fitted with module 55 so I should have variant Z01.
    So my new LED-modules might have wrong shareware inside and need to be flashed somehow to older Z01-version?
  10. #8
    Jun 2017
    Parameterization of these modules is only possible via ODIS when the car had High LED from stock.
    I recommend to buy some used modules instead of trying to get the brand new ones working.
    There is no solution for this afaik.
  11. Likes Uwe, aXu liked this post
  12. #9
    Nov 2019
    I did found couple of used modules with really reasonable price. Orginally fitted to Passat MY2015, so should work to my car.
  13. #10
    Jun 2017
    Feedback is very welcome!
